Question about OCE Office Equipment & Supplies
Oce tds320 plot leaves 3/4 wide black lines across print
SOURCE: Black line across page when printing or copying
Did you try wiping clean the glass? also wipe the strip by the scanner glass?
Posted on Jan 09, 2009
leroyal
  • 2120 Answers
SOURCE: mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Posted on Mar 10, 2009
  • 135 Answers
SOURCE: hp laserjet 4 plus - keep getting a horizontal black line
yes you have to catch printer making the line and then as a page is being printed you need to open door to stop paper after green cylinder(drum) as it is entering fuser, then you need to remove paper from printer without pulling through the fuser, if you see the line then rub your finger across line up and down page, if it smears at all then its the cartridge if not then the fuser
Posted on Apr 27, 2009
j0llyc
  • 8 Answers
SOURCE: Solid black line when scanning or copying from KODAK ESP-3
Get a damp soft cloth and clean the scanner glass. If that doesn't resolve the issue there is a chance the scanning unit itself is damaged.
Let me know.
Cheers, Chris
Posted on Jun 21, 2009
komguy
  • 2306 Answers
SOURCE: Ink leak?
It's not the cartridges, the waste ink is coming up thru the bottom to the exit rollers. The only fix is to have a shop open it up, clean up the ink mess and install a shield that stops the ink from coming back up when it should go to the absorbers. The new machines all have this shield and the ink tube cut back to make the ink go where it should.
Posted on Feb 21, 2010
Oce Colorwave 600ps errorcode 16702 what does it mean?
The media output sensor didn't detect the media in time.
Ensure that you are not pulling your plot out before the CW600 actually delivers it. The CW600 stops printing, cuts the plot, delivers it to the top delivery tray, but pauses for a second before fully delivering it to the tray. See if you get the same problem if you output to the rear. If this problem persists, please call an authorized Oce/Canon service representative.
Apr 06, 2017 | OCE Office Equipment & Supplies
Why am I getting the error code 22550
It would be helpful to know the exact model number of your printer and the software level. If this is a PW300, it is an Initialization Error. Something is out of place that is not allowing the printer to start up properly. Opening and closing the lids may temporarily solve the issue but if it keeps on returning without having jams, there is either a sensor problem or the code level may need to get upgraded. New code levels have fixes that prevent false jam indications.
Jun 24, 2014 | OCE Check Plot Bond Paper, 20 lbs., 34" x...
Oce tds 400 random black lines on demo print
Check the developer and clean the charge corona and the transfer /separator corona assy.Clean the PH unit lens.
Jan 29, 2013 | OCE Office Equipment & Supplies
I consistently get a paper jam error at the same point in a plot job i have re rendenderd the job to different size paper and reformatted the document several times, but the plotter crashes at the same...
I've had the same problem, and through some experimentation and reading in the service manual, I believe the actual cause is a failing CR motor, although I haven't yet replaced it. Try things that will reduce head speed and the speed at which it changes directions. For example, if you aren't using the entire width of the media, try adding a black line something similar to the print in the far margin to force the printhead to move farther. You can also try changing print modes. I've found that unidirectional printing is far more likely to have problems than bidirectional printing as well as the high speed 360x360 modes. Best luck is usually with 720x720 or 720x1440 in bidirectional mode, and if it fails, try changing the width of the print.You might also check that the printhead moves freely all the way across the printer. You could have a bad bearing. The printer detects a paper jam anytime the amperage goes too high on the CR motor, and it seems pretty sensitive.
Dec 11, 2009 | Epson Stylus Pro 10000 InkJet Printer
Wide black lines down the paper. I have changed
Have you changed the Drum unit. Also there is a cleaning pad that you slide across the corona for cleaning. If you leave it in the middle it will give a black line, should be moved all the way to one side.
Nov 18, 2009 | Brother IntelliFAX 3800 Plain Paper Laser...
Oce 3121 coping machine make random black line shadows
if you are getting copy quality issues on all aspects of the machine, IE, printing, copying, ADF, it looks like then you might need a new drum installed. please contact your local service department for service and make sure if you need supplies, to have those on hand before calling a tech to come service the machine. drums, developers, and toner are considered a supply item and are NOT carried by technicians unless otherwise stated in your local contract.
Jun 23, 2009 | OCE Office Equipment & Supplies
Put wrong toner in machine now prints are black
There is only one way to solve the problem. Call a oce service rep. to come out and have them vac. out all of the wrong toner out of the hopper & developer unit and give the bill to the person that put the wrong toner in to begin with.. Good Luck...
May 27, 2009 | OCE Office Equipment & Supplies
Repeating wide smudgy horizintal line across my printed pages
I had the same problem, replaced the PCR in the cartridge, the small black drum that pre charges the drum and erase the old image.
After that print was all back ok.
Regards
Dec 11, 2008 | HP Q2613A OEM Genuine Black Laser Toner...
117 people viewed this question
Top OCE Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
fares
Level 1 Expert
Are you an OCE Office Equipment and Supply Expert? Answer questions, earn points and help others
