Question about Epson Stylus NX400 InkJet Printer
MY PRINTHEAD IS CLOGGED - Epson Stylus NX400 InkJet Printer
The cartridge that came with the printer will not dispense ink
Clean first the catridge printhead with an alcohol.
Then try to print after cleaning.
if still not working, then you go back again to the printhead and clean it again,if still there is a stain left on printhead after many times you clean it, then that stain causes of clogged on your very tiny hole of printhead, then all you ganna do is to replace your printhead so you can use it again
Oct 04, 2015 | Office Equipment & Supplies
My printer is not printing red. It is all new ink cartridges, all in correct position and lit up. How do I fix this
The problem you describe is the result of a clogged printhead. The ink may be new/fine, but the printhead is clogged and won't allow the mixing colors (magenta and yellow are mixed for red) for the red to come thru. Here is a video of a similar Canon model, where it shows how to clean the printhead. Hope this helps.
Oct 28, 2014 | Canon Pixma MX922
Printhead error #768
The print head problem occurs if the drain tubes being clogged and is preventing the pump from sucking the ink out of the print-head. It could also happens if the ink lines allowing air into it.
There are few troubleshooting steps in trying to fix this issue. Click here for a detailed checkup.
Oct 19, 2011 | Paxar Monarch 9850 Thermal Printer
It won't print in black. We have tried 3 differant cartridges. At times it prints a shasding of the image. All the other colors work fine.
Use the HP Printing Assistant software to run a few "print-head-cleaning-cycles".
The BLACK ink-jets are CLOGGED. So, no ink from any of the 3 different cartridges reaches the paper.
Mar 15, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
Cyan ink will not print changed inks and still wont print epson sx515w
This sounds like the printhead is clogged with dried ink. To remedy this, you will have to remove the ink cartridges, remove the printhead. Put some warm-hot (not boiling) distilled water in a cereal dish, put the printhead in the dish with the printhead slots in the water. Let soak for a couple of hours and repeat the process. Blot (don't rub) the water off the printhead and set it aside to air dry (you can accelerate this by using a hair dryer on the warm setting). One the printhead is dry, reinsert it and the ink cartridges. This should clear the clogged nozzles.
Let me know if you have any other questions. Thanks.
Jan 18, 2011 | Epson Office Equipment & Supplies
New ink not working three different times buying it and taking back ink very light or none at all no red it shows up yellow?
Have you done the cleaning the printhead? if not please run your clean printhead, if your using 5100 printer you can only do clean printhead by launching your home center, just click the help icon(?) under that click maintenance for you to able to see clean printhead
Now if you already done with this torubleshooting and still you haved incomplete color or incorrect colors printouts it means you printhead is defective., YOu need to call kodak tech support for printhead replacement i think its free of charged 1 800 421 6699 ext 05 toll free
Nov 16, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Red is coming out pink
try to clean the printhead 2x you can do this using the computer and launching the home center software Just click the help icon(?) then lokk for maintenance and under maintenance click the clean printhead.
Or if you using the ESP3 you can press and hold at the same time copy and cancel button, if you hear mechanical sounds release the buttons and the clean printhead begins.,
If cleaning the printhead will not resolve the issue it means the printhead is already clogged please call kodak tech support toll free for printhead replacement 1 800 421 6699 ext 02,. I think printhead is free of charged
Nov 16, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
It will not print the black ink
Have you clean the printhead and reseating the ink cartridges?
heres the you need to do
-Reseat both ink cartridges
-Calibrate the printhead (Press menu button and look for calibrate printer to do it)
-Clean printhead (press menu then look for clean printhead choose deepclean)
-Press and hold Photo and copy botton at the same time to print your DEMO PAGE!
-If the black is absent it means the nozzles of the printhead is clogged you need to call kodak for printhead replacement Toll Free 1 800 421 6699. GudlucK
Nov 04, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Color
The magenta section of your printhead is clogged. Or you may need to replace the printhead.
Jul 29, 2008 | Brother MFC 420CN All-In-One InkJet...
Follow up of clogged printhead
DO use the 1:10 mix and try the powerpurge.
Mix 1ml printhead cleaning solution (search internet) with 10ml of dye ink.
DONT USE ALCOHOL or any other kind of chemical solution except the printhead cleaning solution.
If you wont have success after doing it twice the ph is clogged and cant be fixed anymore!
The printheads construction is like a sandwich: In front of the nozzels is a filter to clean the ink before pressing it through the nozzels onto the paper. That is the main reason why some ink chanels will clog. You cant open the printhead to clean the filter.
Drop some ink into normal water and watch the flow:
dye ink will mix with water (like dropping a paintbrush with watercolors into the cleaning glass) while pigmented ink wont do so:
http://www.druckerchannel.de/artikel.php?ID=469
(translate german by help of google)
The 1:10 mix wont affect the quality though ink always consists of 98-99% of water! It prevents the ink from drying out.
The bk part of the printhead has another stand-alone construction and doesnt need any "support" by help of additives.
Oct 23, 2007 | Brother MFC 210C All-In-One InkJet Printer
Epson Stylus NX400 InkJet Printer Logo
11 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
