Question about Kenmore 14.8 cu. ft. / 419 liter Chest Freezer 11531
Kenmore c675 instructions for restarting after unplugging for defrosting
Kenmore upright freezer. About 15yrs old. For the last 5yrs we are have big build up of ice where the basket is we cant put anything in the basket, or it gets frozen in.model number is.C675-28732-1L
You mean it build up full of ice and no room for any thing...?
If so. Unplug it and let the door open for 24 hours then clean it up and plug back into power. You should be good for a while.
Good luck
Mai
Jul 20, 2017 | Kenmore Freezers
How do I convert a Kenmore c675 chest freezer to a kegerator. also, in what range can the temperature range be controlled after conversion
sorry but I don't think it can be done as the compresser needs to be properly located so it gets oiled .why would they sell both if it could be done ?
Jan 02, 2015 | Kenmore Freezers
How do you activate the flash defrost function on a Kenmore 16082 model? I can't find any flash defrost button.
Hi
Not all these models were fitted with a flash defrost plunger, if fitted it is inside the lid on the left hand side.
You will need to remove all the product from the freezer and store it elsewhere.
1. Pull out the flash defrost button
2. Put a chock of wood or similar to prevent the lid from closing (if the lid closes it will stop the flash defrost)
3. Wait until all the ice has melted then clean out the casing, some of these models have a drain plug in the base, (put a shallow tray under the outlet to catch the water) others you will need to mop out the water.
4. Push in the flash defrost button and wait for a couple of hours and then you can reload the freezer.
If there is no flash defrost button then follow the above instructions after you have emptied the freezer, all you need to do is switch off and unplug the freezer then go to 2. above. When finished plug back in and reload.
Regards
Gordon
May 05, 2011 | Kenmore Chest Freezer 16082
Kenmore upright freezer quits working but can restart when the unit is unplugged and plugged back.
check the freezer back wall @ bottom if frosted up 1-bad heater (a-glass tube heater or cow rod. 2-bad times 3-bad defrost senor 4- bad fan motor
Aug 15, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Have lost instruction booklet and do not know how to defrost.
Easiest solution is to get an ice chest and put all your frozen items in it and turn the unit off or unplug it and leave the door open and let it defrost itself. If you really want to speed it along use a hair dryer to speed up the process. Or put a circulating fan in front of it and put it on high facing the inside of the freezer.
Remember folks KISS, "Keep it simple stupid"
And No I'm not saying anyone is stupid.
Mar 23, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Kenmore 15.2 upright freezer coils freezing up
Check the bi-metal switch. when cold, it should have continuity also.
If both heater and bi-metal are good, change the defrost timer
I hope this helps.
Please leet me know if I can assist you further
Vic
May 31, 2009 | Freezers
Kenmore upright freezer Model # C675-287140J Serial # 08462430AJ water is freezing in bottom tray and building up.
defrost drain may be plugged.shut freezer off,melt ice with blowdryer,and unplug drain.drain probably located behind inner back wall beneath coils.
Mar 08, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore Chest Freezer C675-18012-1G purchased april 2000
Average freezers last for several years, usually 10 or more. The compressor should not run all of the time, maybe less than 10 to 20 percent of the time if it is working properly. Not sure what you mean by the bipass, some freezer have a manual defrost, and in this mode it will not cool. Insure the location where you have the freezer allows for ample air circulation, sometimes folks put them in little spaces that prevent air circulation to the condensing/compressor unit and they overheat and do not work well and fail very quickly.
Nov 27, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Kenmore 14.8 cu. ft. / 419 liter Chest Freezer 11531 Logo
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
