Question about MSI Computers & Internet
Problem charging samsung l735 camera - MSI Computers & Internet
L735 samsung manual
You may download a copy of the manual from here.
Jan 29, 2013 | Samsung SL102 Digital Camera
Tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 | Cameras
What does it mean when the projector goes on and off again
please check 200w lamp and 220w lamp is it same looking or not? You could send me picture if have. the problem is either lamp or ballast.thanks
If you have any question, do not hesitate to contact me.Mobile: 86-0-15915755963Web:http://www.yylamp.com http://www.yylamps.en.alibaba.comMSN: mickeywoo20@hotmail.com skype:mickeywoo1988Mickey Woo
Jan 15, 2013 | Panasonic Replacement lamp for PT-L735;...
Keyboard keys won't work toshiba L735
Check the (5V) supply line to the panel board is present. If is, replace all the micro switches on the control panel board at one time.
Aug 14, 2012 | Toshiba Satellite L735-S3370 13.3-Inch LED...
Can i use a usb to charge my l200 samsung camera?
No you cannot use USB to charge camera, as it doesn't support USB charging.
Apr 03, 2010 | Samsung L200 Digital Camera
How do you charge the samsung SL202 camera
You charge the rechargable battery in the camera by turning the camera off and connecting to a USB port on your PC (not a USB hub). If the red LED is on the battery is being charged. If the green LED is on the charge is complete. If the red LED is flashing there is an error and you should check the seating of the battery. The USB port must provide 5V and 500mA for a complete charge. the manual for your camera is at http://downloadcenter.samsung.com/content/UM/200909/20090930164417500/SL202_English.pdf
Mar 02, 2010 | Samsung SL202 Digital Camera
PT-L735 U projectors. Green screen and stretched
The green is the result of the blue device failing. Happens about 4000 hours or so. LCDs can't handle the heat. Check the scaling of the image of the second projector. 16x9 vs 4x3.
good luck
Jun 25, 2009 | Panasonic PT L735U Multimedia Projector
Charging battery samsung l200
it should be off...and if this will be the first time you're going to charge it, you should charge it for 8 hours straight
Feb 15, 2009 | Samsung L200 Digital Camera
Samsung L200 10.2
I called 1-800-samsung, and they sent me a new battery. After the problem insisted, they asked me to ship the camera back to them (still under warranty). The concluded that the cable was defective, and they shipped me a new one within 1 week. That was fast!!!
Aug 20, 2008 | Samsung L200 Digital Camera
Samsung L730
My son has a Samsung digital camera and bought a Samsung SAC-45 USB Digital Camera Charger and a Samsung USB Data & Charger Cable Type4 SUC-C2.
He is able to charge his camera by plugging the cable into a USB outlet on his computer, but cannot get the camera to charge when using the SAC-45, which plugs into a wall 110 volt AC socket on one end and the cable on the other.
So far we have tried three SAC-45 units, keeping the same cable, and Samsung says they are shipping a fourth SAC-45 unit.
I think there is some problem with the cable, but haven't been able to get Samsung to send another cable.
Apr 06, 2008 | Samsung Digimax L730 Digital Camera
Computers & Internet Logo
32 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
