Question about GE WBSR3140DW Top Load Washer
Washer agitates the drum back and forth violently, everything eles is ok
SOURCE: GE Washer Tub has sunk and is grinding on bottom
I had the same problem and as near as I can tell, we ran a load the was simply too big and the upper chasis "droooped" just enough from the weight to cause the metal to bow. As a result, the bottom of the tub assembly was rubbing against the lower metal chasis, creating a loud grinding noise. Metal filings indicated the wear point. I took a piece of wood that is about 1"x3x height and wedged it in front and slightly to the left of the motor, running straight, up and down. the board stands straight to take out the bowing- lifting the tub about 1/4" more. This was just enough to provide the clearance needed to prevent grinding. If the vertival board is too long, you won't be able to get the front cover back on.
Posted on Jul 26, 2009
FixinFax
  • 3085 Answers
SOURCE: GE washer model WJRE555OH1WW - agitator free-wheels.
You need a new agitator dog. Ask your appliance parts guys about it.
Pull off the softener body, remove the cap and remove the 7/16" nut and pull the agitator top off.
You might have to use some penetrating oil and a block of wood to tap the top half before it will come off.
Transmissions are pretty tough and usually don't break.
Posted on Oct 22, 2009
FixinFax
  • 3085 Answers
SOURCE: GE washer whdsr315 will not agitate, everything
Pull off the softener cup
pull of the cap underneath
unscrew the bolt
pull up on top of agitator...it might need persuading
Posted on Nov 02, 2009
  • 82 Answers
SOURCE: washer agitates so vigorously water sloshes out of
sounds like to much water check diaphram switch this controls the amont of water taken in this is not normal operation also check that the drum dampers are working ok or have not come adrift, when empty if you was to push the drum back and forth you should feel quite a bit of resistance if it moves easly then i would check the dampers
Posted on Jan 16, 2010
lscf150
  • 443 Answers
SOURCE: GE Washer WWSR3090T8WW does not agitate
Sounds like a transmission failure to me?
Good Luck !
Posted on Feb 10, 2010
When i load my washer drum in washer will not agitate or spin off tract.
if noisy like plane taking off bearings gone check play on drum by pushing drum back and forth look for large gap between drum and door seal and listen for scratching noise when turning also some machines wont spin if the load is uneven
Dec 12, 2014 | Samsung WF330ANW 4.3 Cu. Ft. Front Load...
Hotpoint washer spins but does not agitate
CHECK THE WATER PRESSURE SWITCH AND THE DOOR SWITCH, ANOTHER THING TO CHECK THE CAM DOGS INSIDE THE AGITATOR? CAN U TURN THE AGITATOR INSIDE DRUM MANUALLY AND SEE IF IT ENGAGES THE DRUM, TURN IT BACK AND FORTH AND IT SHOULD LOCK AND GRAB THE TUB?
Sep 02, 2014 | Hotpoint Washing Machines
Does the whirlpool ultimate care II washer agitate like regular washing machines?
it sure doesnt, whirlpool agitation should be a very fast, short and rather violent looking/sounding back and forth motion unlike most other brands where it is a long smooth sweeping motion back and forth
Oct 28, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
GE Washer WJRE5500GWW drum spins back and forth on agitation. Had the Shaft tube assembly replaced 10 months ago. Did it blow again?
Nah, your drum brake/clutch just started slipping. Just replace that and you'll be back to good.
Mar 24, 2010 | GE 3.2 cu. ft. Washer
Washer agitates so vigorously water sloshes out of the overflow tube on large,extra large and super cycles. Tub slams back an forth on agitate cycle is this normal?
Jan 16, 2010 | GE Profile WPRE6100G Top Load Washer
I have a GE washer that will not agitate. The washer thinks it is agitating and goes through the cycle. The drum turns but the agitator doesn't. What could be wrong with it and how hard is it to fix?
Pull the agitator off and check the plastic block attached to the shaft top. Is it split or has sheared splines inside it? Remove the mounting screw to expose the shaft. Does it turn back and forth when it should be agitating? If no, possible transmission problems.
Jul 15, 2009 | Zanussi FJS1225W Front Load Washer
Agitator stopped moving back and forth
dismantle the agitator and see if the shaft of the gearbox is moving.its either the gearbox or the agitator
Feb 23, 2008 | Maytag Atlantis MAV6451 Top Load Washer
GE WBSR3140DW Top Load Washer Logo
22 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
