Question about Spirit Esprit ET4 Treadmill
Spirit ST200 Programable treadmill
Baldor motor heats up to the extent that you can't touch it and it begins to smell after approx 30 minites of use..everything else seems to be working OK...Doses the underside of the track need to be oiled??
4 Suggested Answers
  • 192 Answers
SOURCE: Your Problem: Spirit Treadmill motor will not turn on
I'd start by attaching a voltmeter across the motor contacts to see if you get any voltage when the unit is turned on. It's probably an AC motor but I'd check the label to be sure. If you get voltage but no turning either the motor or a startup capacitor is bad. If this is the case try moving the tread by hand with the unit turned on. If it moves on it's own after you start it moving then the start up cap needs to be replaced. Otherwise it may be time to replace the motor. If you don't have voltage across the motor contacts when the machine is turned on, I'd unplug the unit and trace the lines back from the motor to somewhere on the PC board. I'm guessing there's probably a relay on the PC board that controls the motor. I'd use an ohm meter to make sure the relay coil hasn't turned into an open circuit. Next I'd put a voltmeter across the relay coil, plug the unit back in, and turn the treadmill on and off several times. Ideally you should see the voltage across the relay coil go up and down as you turn the treadmill on and off. This voltage could be AC or DC depending on the type of relay used. If you get the proper voltage across the coil but the relay contacts aren’t' opening and closing to provide power to the motor then you need to replace the relay. If you don't get the proper voltage across the relay coil the problem is further back on the PC board.
Posted on May 15, 2009
russw8
SOURCE: WANT TO REMOVE THE MOTOR FROM SPIRIT TREADMILL TO
Remove cover at front of treadmill,4 pillips screws on each side, 2 screws at front. Lift off plastic cover. Loosen motor belt tightener at top of motor mount ,remove 4 11/16 " nuts holding motor to treadmill base, remove red and black motor wires from control board. Lift motor out.
Posted on Aug 05, 2009
  • 33 Answers
SOURCE: Belt won't turn.
HI, please replace the control board
Posted on Oct 02, 2009
Smell of propane
call the company back explain to them about the smell and where you smell it and would like another test of the lines and appliances that are hooked up as to your medical seek a doctor
Apr 19, 2017 | Heating & Cooling
Motor gets Hot
I'm not familiar with the treadmill specifically, but here is some general information that might be helpful. When a motor is under heavier load, it draws more current and therefore gets hotter. If for example, you were able to stop the motor shaft from rotating with an extreme load, it would draw what is called STALL CURRENT which is very high. So the problem seems to be that the load is out of specification. I'm assuming it would probably get hot if it was running with nobody on it as well. That would mean that the drive mechanism driven by the motor is not moving freely. If you can somehow decouple the motor from the treadmill drive system so that it has no load, and then move the mechanism by hand to see if it feels like there is a lot of resistance in the belts, pulleys or whatever drives the treadmill, then you need to lubricate to make it move smoothly. Or if you cannot decouple the motor, just look for all the bearings and pulleys and lubricate those but be careful not to get oil on drive belts or surfaces that require friction such as the surface of the belts or treadmill band. Don't ignore that the motor could get hot enough to start a fire so it is important to resolve this. It is possible that there are shorted windings and the motor is no longer good. If you can decouple the motor and run it no load, and it still gets hot, that would be an indication of such a shorted winding problem. Hope this is a little helpful. G
Feb 07, 2014 | Spirit Esprit ET4 Treadmill
Hot smelling DC Brushless fan
DC seems to run little hot when an inverter is too large or is sending too much power, it\'s like an accidental overclock. As long as it\'s not hot to the touch or grinding, you should be fine.
Jun 17, 2013 | Computers & Internet
After approx a minute a regular squeak begins, occasionally missing a beat.Heating is fine.
If the "frequency" of the squeaking is a low frequency, the I would suspect the turntable motor or stirrer motor (if so equipped).
If it is a higher frequency, I would suspect the cooling fan or hood fan motor.
Dec 11, 2012 | Neff H7871 Convection/Microwave Oven
Over heating brakes in hot weather with a strong smell
When was the last time your brakes where replaced. Your rims can get hot sometimes even on short trips depending on how often you need to use your brakes. But if your pads are low and "burning up" you may want to look into getting them replaced before they cause rotor damage. You will also loose braking performance and loose stopping power.
Jul 12, 2010 | 1994 Honda Accord
Overheating/burnt rubber smell
classical sign of a bad motor. the motor has a thermal switch on it telling the unit to shut off when it gets hot. after it cools down, the switch will tell the motor to turn back on again. good luck, i'm pretty sure that's your problem. contact me for further help if needed. thanks :)
Jul 06, 2009 | Kenmore 73952 Gas Dryer
Burning smell
thermal switch is not working...upon reaching a certain temperature limit it should switch off then switch on again after a moment to maintain the set temperature..what happened here is that your thermal switch didn't switch off so the temperature continue to rise to the extent that the heating element burnt and smell like that..adjust the setting in such a way that it switches off after reaching the desired temperature..
Jun 18, 2009 | Rowenta Irons
Spirit Esprit ET4 Treadmill Logo
49 people viewed this question
Top Spirit Exercise & Fitness Experts
MrJunk
Level 1 Expert
Electro Med Services...
Mister G
Mister G
Level 1 Expert
Are you a Spirit Exercise and Fitnes Expert? Answer questions, earn points and help others
