Ariston repair manual
Washing machine knob came off how do I put it back on
  • 1294 Answers
SOURCE: ariston margherita wont drain and selector knob keeps turning
Plug off the wall first. The spin normally does not work when the outlet filter is clogged; be prepared for a flood of water. If the filter is clean you should then check your pipe coming out from under the tub. Last check your outlet pump, could be blocked with something. Refit carefully, you might need a nice pair of pliers to get the grip clip on and off the pipes.
You can also drain water from the tub thru the rear hose in the wall. Keep bucket handy. The outlet pipe into the wall stands at a particular height, refit exactly to this height, about 3 feet from ground. Do not push the pipe too much down the stand pipe.
Posted on Nov 30, 2007
SOURCE: ariston margherita washing machine
I have an old Margherita washing machine year 2000, my problem I don't have user's manual. Can you please provide me or teach me how to operate the machine?
Thanks & regards
ray salac
Posted on Sep 03, 2008
  • 353 Answers
SOURCE: Need User Manual for Ariston Margherita 2000 AB 40
Temperature control or speed control for spin
Posted on Dec 15, 2009
SOURCE: Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Posted on Jan 23, 2010
SOURCE: do you have a manual foe AV61 ariston washing
Manual for this machine can be found at:
http://www.instructionsmanuals.com/u2/pdf/lavadora/Ariston-AV61-en.pdf
Posted on Feb 16, 2010
Ariston aq9l 29 u Wash cycle selector knob free-wheels?
Either the knob or the switch is faulty. Can you pull the knob off and see if you can set the program with pliers on the shaft?
Dec 05, 2014 | Ariston Technologies Washing Machines
Program knob
Maybe replacing the knob will be the answer.
Mar 19, 2014 | Ariston Technologies Ariston AWD12 Front...
Hi, I had purchased second hand MARGHERITA 2000-AB63 Washine Machine. BUt i dont have manual to operate. Pls Help.
i have ariston marghrita 2000 AB 63 it does not clean cloths and does not dry cloths.whenever i takeout cloths they are so wet that water drops out of these cloths. pl tell me what shall be position of different buttons and knob when i wash wash cotton/tetron mix cloths
Oct 25, 2010 | Ariston Technologies Ariston AWD12 Front...
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
What do i do
try manually moving the knob through each cycle until it gets back to the finished cycle. or the timer may need to be replaced
Jul 30, 2009 | Ariston Technologies Ariston AWD12 Front...
Washing machine programme knob has been pushed into machine
Turn the D Shaped spindle with a pair of grips until your machine will do a spin cycle only .
When it can do that put the knob on the shaft with the marker on the knob pointing to the mark on the facia saying Spin
Jun 05, 2009 | Washing Machines
How do I translate the manual?!?
hi i have this machine ,when you open the draw on the left hand side ,the detergent goes in the largest section ,fabric softner in the mesh one ,pre wash (bleach etc in other one)now for washing just use cycles 1,2.3,or 4 one being the longest cycle 4 being shortest middle knob is temp, last knob is dryer, if you want it to dry automatically after a load of washing put it on the iron or other to window looking symbols ,otherwise if not drying have it on 0.i would send u a manual but i've lost mine hence why i'm on his site at all.Hope this helps get u started.
Jan 24, 2008 | Ariston Technologies AW125NA 13 lbs. Load...
Ariston 6kg washing machine
Do you have the "easy iron" feature on? If so, the clothes will stay in water until you manually rinse it.
Oct 07, 2007 | Ariston Technologies AWD 121
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
