Question about Cobra Digital Prism 3 In 1 Photo Converter Ps900
3 in 1 Photo Converter can't find OVT Scanner
Ovt scannerx86. Installs.Windows 7. Doesn't work. Help!
Driver issue. If none available from scanner manufacturer then you are in deep doo doo.
Nov 16, 2015 | ION Audio SLIDES 2 PC Slide and Film...
Error message
Incorrect or incompatible driver. See if there is an updated driver.
Mar 08, 2014 | VuPoint Solutions Digital Film Converter...
OVT Scanner won't run with Windows 7. Vupoint
We suffered this initially on a new laptop with Windows 7. I can't tell if the driver on the Vupoint website has been updated, or is the old XP/Vista driver, but we installed this (1/2011). In Picasa or the Photoimpressions software which comes with the scanner, we were then only able to acquire solid black images. However, when we tried all of the USB ports on the computer, we found that one of them (a USB2 rather than USB1 port) was able to function like normal. We suspect there is a funny issue with the amount of power going to the scanner from different USB ports, and maybe this interacts with the driver in some way.
Jul 07, 2010 | Office Equipment & Supplies
My computer has Windows xp Home Edition Version 2002 Service Pack 3. Initially I was able to do first stage of installation install ovt Scanner but next stage of Arcsoft photoimpression started and then...
For a scanner driver it should not matter whether you have XP Home or XP Pro. Most probably there's a simple problem with the disc.
You can ask the vendor for a replacement disc, or go to manufacturer's website and find downloadable drivers & software there. However, on the website there may not be the full software set available, as usually scanners come with some bundled extra 3rd party software that cannot be made available online by the manufacturer for everyone to download.
The essential thing is to install the drivers properly, the other bells & whistles are not needed, you can use applications either built into the system, or available free online for image scanning and manipulation.
Jun 15, 2010 | Office Equipment & Supplies
Repeated message "windows cannot load OmnisuperCam" Followed instructions and reinstalled carefully twice. Photo Impression 6 loads and is active. OVT does not appear in control panel 'scanner and camers'
Hi.
This often happens because Image Copier installation must be done in exact order as described in the instruction manual. To fix the problem you need to uninstall and reinstall everything back in right order.Also remember to restart the system when required.
  1. Unplug the image copier
  2. Uninstall the driver (remove from installed scanners and remove driver files).
  3. Uninstall PhotoImpression6
  4. Restart your computer.
  5. Install the driver,.
  6. Restart computer
  7. Reinstall PhotoImpression6 software.
During installation ensure that you authorize the system changes when asked. If possible disable any security software.
If that does not fix the problem, then the registry must be cleaned of any entry related to the scanner software. This is rather difficult to be done manual. You can try doing a system restore to a recent date before the problem started after uninstalling everything, and then uninstalling again if needed (application and scanner are there after SR), and finally reinstalling everything in order. If that does not work you can try a registry cleaner or reinstall the system.
Here a copy of the manual.
Jun 22, 2010 | Computers & Internet
It does not recognize my memorease digital slide scanner. I am using windows 7 and the lates drivers from Pacific Image and Adobe elemnts is supposed to see the slide scanner bbut doesn't
If your scanner is like mine, the software is defaulted to look for the OVT scanner. Go into properties and change the default to Cyberview CS Memor-ease.
Jan 15, 2010 | Office Equipment & Supplies
IScanner not communicating w/ PC
If your scanner is like mine the software comes defaulted to look for the OVT Scanner. Go into properties and change the scanner default to Cyberview CS Memor-ease.
Dec 30, 2009 | Pacific Image Electronics Memor-ease...
Computer restarts when trying to aquire photo's
go to control panel, then system,advanced tab, startup and recovery. look under startup and recovery then uncheck the block that says automacilly restart then ok. you are experiencing a software- hardware failure and when you do this you may be able to provide enough info to lead to the repair. could be as simple as an incompatible driver
Jul 06, 2009 | BenQ ScanWit 2720S Film Scanner
OVT scanner does not calibrate nor allow "acquire picture"
I had a similar problem. Driver of scanner was ok.
Went to configuration->device manager-> in list checked the USB controllers and updated the Enhanced usb2 controller. Reboot and re-install de scanner driver. Most likely this will solve your problem
regards, Andre
Jun 20, 2009 | BenQ ScanWit 2720S Film Scanner
Vupoint FS-C1-VP scanner installed
i have vista home and mine worked fine until i installed a web cam and then it just gave up. But now it works great - here is what i did
unpluged both the scanner and the web cam
uninstalled everything to to w/ the scanner and the web cam.
Installed the driver from the CD and restarted my machine
Install the Photo 6 software
plug in the scanner - works like a champ.
have not reinstalled the web cam
Oct 02, 2008 | Office Equipment & Supplies
Cobra Digital Prism 3 In 1 Photo Converter Ps900 Logo
Top Cobra Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Cobra Office Equipment and Supply Expert? Answer questions, earn points and help others
