Question about Pride Health & Beauty
Flashes 5 times then pause error code
Pride destiny flashes 5 times then pause error code
  • Pride Master
  • 9,742 Answers
Go to Pride's website to download the service manyal for your scooter. It will tell you what the flashes and codes mean and how to fix them.
Posted on Feb 24, 2015
4 Suggested Answers
gewiz
  • 1263 Answers
SOURCE: hello, what the flash codes mean?
hi
this link will download the manual , see page 38 for the flash codes
http://www.pridemobility.com/pdf/owners_manuals/US_Scooter/US_Hurricane_om.pdf
Regards
GeWiz.
Posted on Dec 28, 2009
  • 79 Answers
SOURCE: my dad's pride celebrity scooter has new
Hi. The batteries for these things seem to go bad rather quickly when they are not used, but here is something to try..... So called "smart chargers" are what everything is going to. They analyze the condition of the battery and if everything is good, charge it. If everything is not good, according to the parameters of that charger, they don't. My suggestion is to take the battery out of the unit and try an old-fashioned analog battery charger for a little while, set to the proper voltage for the battery, of course, and monitored closely to measure the effects. If the batteries seem to take a charge, put them back in and run it a bit, then try the on-board charger again, just don't wait until the batteries are completely drained this time.
Posted on Sep 09, 2011
Testimonial: "thanks for response. i told him even new batteries should be charged before use."
  • 118 Answers
SOURCE: NO DRIVE ON MY PRIDE REVO MOBILITY SCOOTER
You can try to do this with the cover off, just in case it is not seated properly and holding the lever from fully engaging. The actual swithc is a small microswitch down at the brake, and it can get dirt in it and that will stop it from working, or it may even fail, and need to be replaced. So I would:
1) try it woth the shroud off the motor using.
2) look for dirt around the switch.
3) take a paperclip and jump the scooter side of the switch to bypass the microswitch on the scooter, be careful not to short the jumper to the scooter frame.
Let me know how you make out.
Dan
Posted on Jun 11, 2012
How do i repair a speed pot on a pride destiny scooter i have put new batterys on it the ihe green light flashs 7 times
Hi u have to replace it if it is faulty / remove it & check it's resistance in ( ohm's ) with a multimeter.. Cheers
Oct 16, 2017 | Pride Health & Beauty
My flash code is SEVEN PAUSE SEVEN which indicates JOYSTICK FAULT.
PDF]INFINFB2043_Jazzy_600-600XL_Troubleshooting_Rev B ...
www.pridemobility.com/download.php?...Jazzy_600-600...
Pride MobilityWhat if the systems on my Jazzy 600/Jazzy 600XL seem to be "dead" (controller does not ... Each controller will flash a code via the battery ... 7. Joystick error. Contact your authorized Pride Provider. Four yellow LEDs ... This is indicated by the VR2/VSI speed ... flash in a numbered sequence followed by a 2-second pause
Jan 18, 2016 | Pride Jazzy 600 JAZZY 600
Why won't my pride legend start?
The legend has a Curtis controller. The flash codes you provided points the problem to a faulty throttle pot. If a new throttle does not fix the issue, then your problem is the controller itself.
Sep 03, 2014 | Pride New Mobility Legend 4 Wheel Scooter
Getting an error code of flashing 9 times then pause then flashing
Pride Mobility Products Corp Product Owners Manuals Specification Sheets Click on "Celebrity X"
9-flash usually indicates a blown controller. The larger pride scooters are known for blowing controllers and having melt-downs when they are pushed or towed too fast. EVEN WITH THE KEY OFF the controller still monitors the safety systems. If the system detects a "roll-away" situation, the controllers turn on and go into dynamic braking mode in attempt to slow or stop the scooter. If the scooter is being towed or pushed and this happens, the scooter tries to stop the motion, overheats and burns up. Catastrophic failure and 9-flashes will result.
Best regards
Mar 16, 2014 | Pride Celebrity X 4-Wheel Electric Scooter...
Pride destiny error codes
Pride's website has a service manual for download. It will define the error codes and tell you how to fix it.
Feb 06, 2014 | Pride Hurricane 4 Wheel Personal Mobility...
What does a flashing yellow light mean on the joystick? the light looks like the shape of a wrench.
Hi Judy,
According to Pride's troubleshooting documents the service indicator (wrench icon) will flash when a fault is detected by the dynamic controller.
The number of flashes, followed by a 2 second pause, indicates the issue. You will need to count the flashes to determine the cause and a possible solution.
I have typed the flash codes below, but you can also see them on a larger table here: http://www.fixya.com/support/p3641679-pride_jazzy_614_hd_jazzy_614hd/usermanual-6B42026-pdf
FLASH CODES
Code #1
  • Flash Code: One, pause, one
  • Cause: Possible Stall Timeout
  • Possible Solution: Turn joystick off, then on.
Code #2
  • Flash Code: Two, pause, two
  • Cause: Battery Fault
  • Possible Solution: Charge batteries, check battery connections and fuses.
Code #3
  • Flash Code:Three, pause, three
  • Cause: Left Motor Fault
  • Possible Solution: Make sure the left motor is plugged in.
Code #4
  • Flash Code: Four, pause, four
  • Cause: Right Motor Fault
  • Possible Solution: Make sure the right motor is plugged in.
Code #5
  • Flash Code: Five, pause, five
  • Cause: Left Park Brake Fault
  • Possible Solution: Make sure the left brake is not in freewheel mode.
Code #6
  • Flash Code: Six, pause, six
  • Cause: Right Park Brake Fault
  • Possible Solution: Make sure the right brake is not in freewheel mode.
Code #7
  • Flash Code: Seven, pause, seven
  • Cause: Joystick Fault
  • Possible Solution: Check the joystick connection.
Code #8
  • Flash Code: Eight, pause, eight
  • Cause: Power Module Fault
  • Possible Solution: Check connections to the power module and batteries.
Code #9
  • Flash Code: Nine, pause, nine 9
  • Cause: Controller Communication Fault
  • Possible Solution: Check bus connections from the joystick to the power module.
Code #10
  • Flash Code: Ten, pause, ten
  • Cause: Controller Fault
  • Possible Solution: Contact Technical Service for assistance.
Code #11
  • Flash Code: Eleven, pause, eleven
  • Cause: Incompatible Device Fault
Sep 05, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
My Power Chair is flashin three code
hi, if it 's stays three pause three then the error "Left Motor wiring fault" , now I suggest you remove the lead from the controller and refit check the connections are clean and tight.
Regards
Feb 17, 2013 | Pride Mobility Pride Jazzy 614 HD
Flash code is 5 flashes pause then 5 flashes what does 5 flashes mran
What controller??? For a Dynamic Controller it is an error code 5: left park brake fault. Check the brake connections.
Jan 15, 2013 | Pride Mobility Products Jazzy Select 14 XL...
Flashing error codes
Carefully count the number of flashes that occur in each sequence; for instance, it will flash 5 times, pause, and flash 5 times again. Go through several sequences to make sure your count is correct as it will always be the same number of flashes. Here is the owners manual, go to page 37 to find the flash code page and look up your number. Then post that back here for more information on how to proceed.
Jan 10, 2013 | Pride Celebrity X 3-Wheel Electric Scooter...
Jet 7 will go backwards, but cuts out and powerlight indicator flashes, when trying to go forward Bunnyxjs@Yahoo.com
bunny You will need to count the number of flashes 5 flashes pause 5 flashies etc This is a flash code and you can tell by that what the problem is. If you have your users manual it should have a section on flash codes. Hope this helps you
Sep 24, 2010 | Pride Mobility Products Pride Jet 7 Power...
Health & Beauty Logo
134 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
