Question about Mitsubishi 4 Fuso Truck Fe 2005 / 2008 Air Filter
Mvcu light comes on
What is this light
Why does my Kenmore intuition vacuum 31810 Red light stay on ?
Here's a couple options
http://www.ehow.com/way_5513470_kenmore-vacuum-troubleshooting.html
http://www.shopyourway.com/questions/1128413
Jul 28, 2014 | Kenmore Intuition 31810 Upright Bagged...
Check engine light
The PCV system in the 3.6 is a cyclonic separator (like a Dyson vacuum) integrated into the valve cover on the passenger side. It can get clogged, but it's rare.
Nov 08, 2013 | aFe 2006 Volkswagen Passat - 3.6L V6 - Air...
Brake light comes on when braking
If you have a high level brake light, that may be the problem location
Dec 13, 2012 | Hyundai Hynda XG350 2003othrYrs/Mds...
NO TAIL LIGHTS 1996 F450
tail lights work off different wire than brakes hazards, etc. .It could be in the wiring, or simply the tail light side of the bulb itself has blown. Check the bulbs, it will have to separate filaments, if one of them is burnt into, tail lights will not work
Nov 27, 2012 | Ford F 450 Super Duty Cars & Trucks
Red light comes on after cleaning S1730 GP Sharper Image
Make sure filter is positioned correctly and fully seated.
If it does not come on with a clean dry filter it may be a faulty high voltage component.
Feb 05, 2012 | Sharper Image Ionic Breeze GP SI730 Air...
Oo.comAFTER CLEANING UNIT AND INSERTING BLADES UNIT BLUE LIGHT COMES ON FOR LESS THAN A SECOND AND THEN RED CLEAN LIGHTS COMES ON. REPRESSING ON BUTTOM ONLY REPEATS PROCESS, BLUE LIGHT THEN ALMOST...
This is a common problem and if it's still under 1 year warranty, contact Ionic Pro at 800-875-8577 for a replacement that will cost you $20 for shipping to/from.
The high-voltage supply has died and cannot be repaired by the average repair person as parts just are not available.
When they get these back, they go into the trash and send you a new one.
TO PROLONG ITS LIFE, plug this into a surge protector as the electronics that are in this don't have any protection against even a small surge.
Sep 22, 2011 | Ionic Pro CA200B Air Purifier
Green purifier light no longer comes on
the plates are damage you need to replace it and be careful wen it`s to much humidity because that can damage the plates,and the ligth its the uv ligth you can get parts at ecoquest
Apr 03, 2010 | Ecoquest Living Air Classic Air Purifier
Have a red light on in front - looks like something needs serviced. I rinsed the filters that pull out and light stays on. Might be a filter further in the unit or something might need to be reset??? ...
To the left of the little red light is the reset button. It's disguised as another light that isn't on. :) Press and hold it for about 10 seconds and the red light will turn off.
Mar 03, 2010 | Honeywell QuietClean HFD-110 Air Purifier
Pilot light lights, yet I can't seem to get unit to light off.
it may be a weak pilot flame or a bad thermocouple you can tesst the thermocouple should be 30mv or disconnect pilot tube from valve and blow pressure thru to clear. or have a service company look at (probably the safer option)
Nov 29, 2009 | Air Purifiers
Mitsubishi 4 Fuso Truck Fe 2005 / 2008 Air Filter Logo
309 people viewed this question
Top Mitsubishi Air Purifiers Experts
Andrew Taylor
Andrew Taylor
richie46
Rob
Rob
Are you a Mitsubishi Air Purifier Expert? Answer questions, earn points and help others
