Question about Pride Health & Beauty
5 flashes scooter will not move wots 5 flashin green lights fault code
gewiz
  • 1271 Answers
SOURCE: The lights indicate there is
Hi can you tell me the flash code ? how many imes it flashes before there is a pause etc.
to help you with this check the manual
http://www.pridemobility.co.uk/docs/UK_Celebrity_X_om.pdf
goto page 35.
Regads
Gewiz.
Posted on Jan 02, 2010
  • 177 Answers
SOURCE: need manual for craftmatic scooter
Hi. How many flashes between the pauses? Let me know and I can tell you what is wrong with it. Neil.
Posted on Jul 13, 2010
  • 692 Answers
SOURCE: i have a golden companion
The L.E.D. located on the tiller
dashboard will indicate with flash codes what problem is occurring.
L.E.D. Flashes 1 time and pauses, 1 time and pauses…. Batteries are low,
scooter will still operate.
L.E.D. Flashes 2 times and pauses, 2 times and pauses…. Batteries are very
low, scooter will not operate.
L.E.D. Flashes 3 times and pauses, 3 times and pauses….Over voltage to
controller.
L.E.D. Flashes 5 times and pauses, 5 times and pauses….Brake is in the
freewheel position or connection to brake is open.
L.E.D. Flashes 6 times and pauses, 6 times and pauses….Paddle or speed
potentiometer problem.
L.E.D. Flashes 7 times and pauses, 7 times and pauses….Paddle or speed
L.E.D. Flashes 8 times and pauses, 8 times and pauses….Motor
disconnected or faulty.
L.E.D. Flashes 9 times and pauses, 9 times and pause….Controller fault.
I hope this helps they are pretty standard codes I got this from Golden Tech Web Site
Posted on Aug 18, 2010
  • 692 Answers
SOURCE: scooter battery shows full charge but scooter does
Plamont unfortunately that flash code usually means a controller error. The controller is the brains of your scooter. Take the seat off and remove the rear shroud that covers the batteries and motor/gearbox assembly. Check all the wiring connectors for damage or loose connections. After checking the connectors turn the scooter on and see if you still get 8 flashes.
Did Medicare purchase the scooter? If so they will pay for most of the repair costs. You can contact your provider that sold you the scooter or a repair service Repair Xpress@ 1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 Hope this helps you
Posted on Sep 13, 2010
wcdoc1953
  • 280 Answers
SOURCE: wigwag fault code flashing on
The throttle potentiometer error code is caused by a damaged or worn potentiometer. The fix for this problem is to replace the throttle potentiometer. The part is available from Pride based on the model and serial number. Hope this helps.
Posted on Mar 20, 2011
Testimonial: "Yes..we discovered this was the problem ..thank you!! "
My lynx 3 scooter wont go .power gage is full. But no movement.green kight flashes 5 x after i push the horn.
I expect the green light is telling you what the fault might be. If your instruction book doesn't provide the code you should contact the dealer or visit the manufacturer's website.
May 18, 2016 | Lynx Health & Beauty
My dad has a merits 4 wheel pioneer that flashes 5 times what fault code is this
This flash error code for the dynamic controller indicates a park brake fault. Try moving the brake lever back and forth in each direction to clear the fault. You may have a faulty brake or brake microswitch. You can test the brake with a voltmeter. It should read 40 to 60 ohms and not shorted or open. You can test the microswitch by pushing it and checking for switch closure using a voltmeter. You need to turn the scooter on and off to clear the last fault. Hope this helps.
Mar 08, 2016 | Electric Mobility Merits Pioneer 3 Hd ...
How to fix scooter when red light flashes 5 times
hi, i need you tell me what controller type is fitted to that scooter before i can be more precise with fault info ,, the controller is a black, or blue or silver box located under the rear cover of the scooter ,, the wires lead to this unit...
Regards
Rob
www.gewizrepairs.co.uk
Apr 10, 2014 | Drive Medical Phoenix 3 Wheel Compact...
Golden companion II full charge turn key on press lever to go forward it dont move hear clicking sound green light on dash blinks
John count the number of flashes by the green light and it will be the fault code indicating the problem Your owners manual should list the fault codes to be able to determine what the problem is. Ie 4 blinks pause 4 blinks pause. The clicking you hear is the electric brakes being engaged. Hope this helps
Mar 01, 2011 | Golden Technologies Companion II Travel...
I have a golden companion scooter and it wont move it flashes a green light but i haave no info on where to obtain the trouble codes
controller.
Aug 17, 2010 | Golden Technologies Golden CompanioN II -...
Battery new cahrging good green light flashes
Hi. How many times does the light flash betwwen pauses? this is a fault code. Check free-wheel lever. Check motor and battery leads and connectors.
Check the resistance through the motor with a multi meter.
Good luck. Neil.
May 09, 2010 | Pride Sonic 3 Wheel Portable Scooter
No drive,flashing green light
Are you sure the FREELEVER is in the right position ? , to test try to push the scooter ?
Battery Low ?
Mar 12, 2009 | Electric Strider Midi 4 Wheel Mobility...
Health & Beauty Logo
12 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
