Question about Keurig Vue Brewing System
Stays in preheating mode
When I plug it in and turn it on it stays in preheating mode and I am not able to brew
Keurig V700 will not preheat
That is not acceptable. If the timing circuit fails, that will require replacement of the circuit board or thermal switch. Return ASAP for a replacement.
Feb 13, 2014 | Keurig Vue V700 Brewing System - 110774
Vue 700 brew length problem
Honestly, contact Keurig. Why would you try to fix something that is only 10 days old? Keurig has awesome customer service. You can contact them here:
http://www.keurig.com/contact-us
Dec 13, 2013 | Keurig Vue Brewing System
Preheat light on Keurig Vue stays on
Needs cleaning, see instructions in manual.
Mar 05, 2013 | Keurig Vue Brewing System
Kerig Vue will not come out of the preheat mode
This worked for me: 1) Turn off machine 2) Remove lower tray. It pulls right out. make sure it is clean. RE-insert. 3) Remove upper tray. It's a little trickier, put it also pulls down and out. Mine was full of coffee grounds. I rinsed it out with tap water. 4) Replace upper tray. 5) Take a used V-cup and take the foil and filter out leaving only the plastic tray. Clean it thoroughly of coffee grounds with water. Replace it in the V-cup insert. 6) Power on the Vue. It should come on pretty quick and say " Ready to Brew" run 6 to 8 oz through with just the blank V-cup. This will clean out any remaining debris. 7) Now put in a new V-cup and brew your coffee!
Oct 04, 2012 | Keurig Vue Brewing System
How do I program the stay or go coffee maker to turn on at a certain time, I worked the past few evenings, but the green light will not come on, I did have trouble the other times also
To Program Automatic Brew
1. Make sure clock is set for correct
time of day.
2. Press PROG button and digits will
flash.
3. Press H and M buttons until desired
brewing time is reached.
4. Press PROG button to confirm setting.
Digits will stop flashing and
return to set time of day.
5. Once brewing time has been set,
follow this procedure:
• Follow steps in "How to Make
Coffee."
• Push AUTO-ON-OFF button once
and "Auto" will be shown in display
indicating the brew cycle will begin
at the set time.
NOTE: If AUTO-ON-OFF is pushed
twice, the light will glow and brewing
will begin immediately. Press AUTOON-
OFF once to turn off and once
more to set programming mode.
Jan 13, 2011 | Hamilton Beach Stay or Go 45234 Coffee...
Glo plugs don't seem to be getting hot when I hold the button down ... it will however start with star ya bastard ... once the enging is hot it will start no problems
GLOW HAS TO BE WORKING.BECAUSE ENGINE STARTED.GLOW PLUGS ARE USED ON COLD START UPS.GLOW PLUGS PREHEAT THE AIR IN COMBUSTION CHAMBER SO DIESEL FUEL WILL START TO BURN ON START UP.WHEN YOU TURN ON IGNITION SWITCH THE GLOW PLUG LIGHT WILL TURN ON FOR MINUTE UNTIL PREHEAT DONE.GLOW PLUGS WILL STAY ON UNTIL THE COOLANT TEMPERATURE GET OPERATING TEMPERATURE.THEN THEY TURN OFF.
Mar 21, 2010 | 1997 Nissan Pickup
Temperature problems in Bosch range
I would check to make sure you are using a 220 plug.
Jan 09, 2008 | Ovens
Keurig Vue Brewing System Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
