Question about Drills
Hilti te 17
Hammer notworking
rowdy45176
  • 2176 Answers
SOURCE: Hilti TE-60 hammer drill
what I would do if you have a fax machine is call 1-800-879-8000 and request a schematic on this tool first. Some of their products are not that easy to disassemble. I never have worked on the TE-60 but have on some of their other products and they are all different. Hope this helps
Posted on Dec 19, 2008
  • 123 Answers
SOURCE: hilti te-72 hammer failure
Do not put it in hammer mode and try to unscrew the chuck! This will break the housing internally. To remove the chuck you will have to put a chisel in the chuck. Lock that chisel in a big vice. You will then have to put a pipe wrench on the chuck to unscrew it. It is regular threads but there will be loctite on it. Once that is off your will have a spring and two roller bearings to remove before you can slide the bell off. You will then have 8 5MM screws to remove. This will remove the chuck. You will then have a snap ring to remove. After that you can remove the whole cylinder assy. More then likely your connecting rod is broken.
Posted on Oct 09, 2009
  • 123 Answers
SOURCE: Hilti TE 17 Rotary Hammer repair switch fix
If you are talking about the wire going from the switch to the stator it difficult to get to. You have to remove the motor end cap, cooling fan and handle holding the switch. this will get you to the brush holders. These can be brittle so you need to be carefull. Turn the motor over and tap the end of the armature on concrete checking the brush holders every couple of taps to see if they are coming out of the motor housing. after they clear they will just come out. If you havn't done so already remove the wires going to the brush holders. Your stator will simply slide out after your brush holder comes out. This will give you access to the wires to repair.
Hope this helps.
Posted on Oct 29, 2009
Testimonial: "worked well for me"
ftw1952
  • 10319 Answers
SOURCE: Hilti TE 12. It will not hammer.
the rotory cam has been broken inside if not producing the hammer effect
Posted on Mar 11, 2010
  • 123 Answers
SOURCE: HILTI TE 72
It could be that your connecting rod is broken. You can check by taking your shift lever off of the top of the gear housing and then removing the snap ring to remove the shift boss. That will allow you to look at the crankshaft and connecting rod. If it is broken I would check with Hilti to see if they still carry parts for the TE 72.
Posted on Mar 13, 2010
Repair hilti te-17 hammer drill
Sounds like the clutch or gears have gone.
Feb 27, 2014 | Hilti Drills
I have a hilti hammed drill te 17 and i need a dustcap for it
suggest calling them direct at 1-800-879-8000 for the part number and they can give you a local source for the purchase of the dust cap. Let me know if you need more assistance.
Apr 20, 2011 | Hilti TE 70 Hammer Drill Performance...
Need on/off switch for Hilti TE 17 Hammer Drill
Parts for the TE17 have been discontinued for over 15 years. The switches and the oilite bearings for the motor were the first to run out.
Jan 07, 2011 | Hilti Hammer Drill, 8.4 Lb 3 Mode, Te 16 C
Hilti TE 17. Hammer doesnt work. Rotary does.
Most likely the O-rings are worn - tool has no compression to move the hammers inside.
Less likely: the connecting rod for the piston is broken so piston isn't moving - or 2nd hammer is broken into pieces.
I would open it up & check the orings first
Jul 31, 2010 | Hilti Drills
Will the bits from the te-c3x fit my te-17
Yes. New bits will fit old Hilti drills. Old Hilti bits do not fit the new (last 15 years) Hilti drills.
Apr 07, 2010 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
Mar 11, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
NEED PARTS FOR HILTI TE 17
hi i have a 30 year old hilti te17, yes i know but its great but i need the bit holder ( chuck i think its called, the thing that hold the drill bit in for this hammer drill, otherwise its works perfect, built to lasst these things, but parts are hard to come by in aystralia, anyone help me if you can please
lulu
Mar 09, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Will a Hilti TE 17 to drill 1" holes in sandstone?
The TE 17 is at least 29 years old. It will do up to an inch. However there are no parts available for this tool. Also be carefull if it has a black fill cap on top of the gear housing then it does not have a safety clutch. If it has a red one then it does have a clutch.
Mar 05, 2010 | Hilti Drills
Need rear moter bushing for TE-17
Hilti has not carried parts for the TE17 for about 15 years. That tool was produced from the 60's up until the early 80's. The part you are looking for is an Oilite bushing that is held in the motor end cap. Even though the part is no longer available a good machine shop should be able to make you one.
Oct 25, 2009 | Drills
Drills Logo
26 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
