Question about Lowrance Boating
Flashing at speed
Lose Lose sonar after boat planes out
4 Suggested Answers
  • 111 Answers
SOURCE: No depth reading while on plane.
Depending on your transducer type, you may have a liquid filled type that simply needs refilling. If this is the case check for leaks and get it redone. If not it could be transducer placement or cavitation under the hull.
Posted on Jan 22, 2010
  • 5520 Answers
SOURCE: boat won't plane
Check your prop hub. If you have a larger motor there are rubber bushings in the hub which can slip. This is a safety feature like shear pins. You may need to rebush the prop.
You also need the proper length motor for your transom. And you need enough power to overcome the drag and weight of a loaded boat. Check and see if the angle settings for the locking pin will provide an upward thrust to the hull and not plow the hull down.
Posted on Mar 17, 2010
paul4_judith
  • 1190 Answers
SOURCE: Boat does not plane
the engine is a bit small but make sure its fully tilted down on the tilt pin adjustments ! how much gear or fuel tanks etc are at the rear of the boat and do you sit central of boat with steering and remote gear/throttle controls or at rear , weight moved forward will help and you could also fit doel finns to the cavitation plate above the prop which looks like a dolphins tail and these will increase lift and get you on the plane ! really a bigger engine like 75hp would be the answer ! what max hp rating is the boat ? try the above first and any more info you can give me would help give suggestions !
Posted on May 30, 2014
My lowrance elite 4 HDI goes black when i get on plane so my backtrack feature doesnt work
The speed of your boats travel only directly affects your sonars ability to read the water depth.
your backtrack feature is GPS based. These is not affected by your boat being on plane.
Your screen being black sounds like your sonar is losing bottom contact due to air bubbles passing under the transducer. This is a common occurrence with most boats.
Add some details regarding what your seeing and we can help you get a better handle on your difficulty.
May 24, 2015 | Lowrance Boating
Y does my 2003 mercury outboard 200 efi take so long to get by 21 foot pro craft out on a plane it is really slow
Check the size and pitch of the prop. By reducing the pitch you will get better hole shot out of the water ,but my be lose a little top end speed. This will be stamped or cast into the prop eg: 15x21 which stands for 15 inch diameter by 21 inches pitch.
Jan 26, 2015 | Boating
What to do to get boat to plane out
Try adding a plane to the lower unit of the outboard motor.
SE Sport 200 Hydrofoil
This will plane out the boat quite well.
Jan 05, 2015 | Boating
My 88hp Johnson won't tilt up when moving in water unless I am going slow therefore I can't get topend speed what would cause this?
outboard motors some times are designed to not run at speed while tilted as the water pump inlet is above the water line and the engine will over heat and the pump impellor will be destroyed.. With an engine tilted the load from the propeller tends to lift the nose of the boat high and makes it unstable on the water . The best situation is to have the propeller tend to drive the nose down thereby promoting a planeing action that improves economy and speed Once the boat is on the plane you can cut back on the throttle and still maintain the same speed . Moving with the leg tilted should only be used to navigate shallow water at very slow speeds
Jan 26, 2014 | Cars & Trucks
What is powerboating?
From Wikipedia: Power boating describes activities performed in a motorized boat. Generally, a power boat has a high power-to-weight ratio and a hull design that allows for easy planing, which allows for higher speed and improved handling. Also, the shape of the actual boat is usually very streamlined, which minimizes air resistance and drag, therefore increasing speed. Power boats are often used recreationally, includingwaterskiing and wakeboarding.
Powerboating appeared as an event in the 1908 Olympics.
Jan 17, 2013 | Boating
My fishfinder will not continue to read shallow depths as well as in shallow depths when drifting and occasionally running across the water. My unit is a lowrance 522c color gps/fishfinder.
Hello. Your observation is spot on and it is actually a characteristic that is always true when using sonar. Yes, your Lowrance uses the same sonar as a nuclear powered submarine does. The two factors you focus on, water depth and boat speed are perhaps, the two biggest factors when it comes to the quality of the fishfinder. The boat's engine should be in gear at an idle or just above. Experiment with your boat to find the best throttle location for good arches. Usually, a slow trolling speed works best. The depth of the fish can determine if the fish will arch on the screen. If the fish is in shallow water, the fish is not in the cone angle very long, making it difficult to show an arch. Typically, the deeper the fish, the easier it is to show an arch.
If you would like a complete tutorial on Lowrance sonar, go to this link. Enjoy. http://www.lowrance.com/Support/Tips-and-Tutorials/Sonar-Tutorial/
Nov 20, 2009 | Sport & Outdoor - Others
Furuno 1833C/Dgps37 Plotter creeps
Try adjusting the GPS position offset in the GPS Sensor Settings Menu.
Jan 11, 2009 | Furuno 1833C/NT GPS Receiver
Proper set up for lowrance sonar
Where do you use your boat?
There are so many variables it's hard to fit it all here, but there are some excellent tutorials on the Lowrance website. The most important thing is to pick the right frequency, for the depth of the water. (200khz for less than 70', and 50 khz for greater depths). Depending on how serious you are about fishing, there are a lot of extras that you may never use. The key is to figure out which features will help you the most and forget about the rest.
You may also get some help at this link: FixYa Service Directory
It's common for SONAR to lose contact with the bottom at high speeds. The better the transducer installation, the faster you can go. Turbulence and bubbles will cause the SONAR to drop out. Lowrance's transducer installation guide explains it very clearly.
Jan 03, 2009 | Boating
Jun 18, 2008 | Raymarine A65 Combo GPS...
Boating Logo
26 people viewed this question
Top Lowrance Boating Experts
Phil Walker
Phil Walker
Jerry Greenberg
Jerry Greenberg
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
