Question about Royal wes50 surround sound wireless headphones
Where is battery compartment for wes50 headphones
We got new headphones, they light up red but its been three days and they are still red? Any suggestions. No sound. nw101@live.com
Locate the battery compartment. Inspect the battery contacts - sometimes the MFR puts plastic covers on them to prevent battery discharge damage after long durations of storage. Remove the plastic. The batteries may need to be charged.
Feb 19, 2011 | Sony MDR-RF970RK Headphones
New out of the box and the cover for the batteries will not open? Does the cover screw off? I know it is counter clockwise but it will not turn???
from what i read i think you need to apply pressure to the compartment then turn counter clockwise .
check out the manual link here , page 7.
on the link page just type the numbers shown below , you don't have to give email
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Feb 09, 2011 | RCA WHP141 Consumer Headphones
Where do the batteries go
The batteries are in part of the headphones that go on your ears, the left one.
There should be a little button towards the bottom that says "PUSH".
Press that button and the battery compartment lid should come off. (see picture)
Hope this helps!
Jun 05, 2010 | Sony MDR-RF970RK Headphones
RCA headphones - nicad or alkaline batteries WHP141
BATTERY INSTALLATION AND INFORMATION
Your wireless headphone unit requires two rechargeable AAA batteries.
Rechargeable batteries are uncharged when you purchase them. Before
you can use the wireless headphones, the batteries must be charged for
16 hours. Follow these steps to install and charge the batteries.
Installing the Rechargeable Batteries
Take care to follow these steps to correctly install the batteries.
1. On the right headphone, locate the battery compartment (1).
Use the finger depression on the compartment to turn the battery
compartment cover counterclockwise to remove the cover.
2. Insert two AAA rechargeable batteries, carefully following the
markings inside to ensure the batteries are inserted properly, with
the + and - ends in the correct positions.
3. Replace the battery compartment cover.
Charging the Rechargeable Batteries
To recharge the headset unit, follow the directions below. Note: The
cradle/transmitter on the WHP141 is not a recharging cradle, although
you may place the headset in the cradle during recharging.
Follow these steps to recharge the NiMH rechargeable batteries.
1. Make sure the ON/OFF switch (2), located on the right headphone,
is in the OFF position.
2. Connect the AC/DC main power adapter to the DC IN power
supply socket (11), located on the back of the cradle/transmitter.
3. Plug the adapter into an electrical outlet.
4. Connect the charging cable (10), located on the back of the
cradle/transmitter to the recharging input (3), located on the right
headphone. The headphones can either be placed in the
cradle/transmitter or placed next to the unit. If the headphones are
connected correctly, the charging LED indicator light on the
cradle/transmitter (8) illuminate.
Mar 27, 2009 | RCA WHP141 Consumer Headphones
I have an Arkon HP1180 Cordless Headphones with no instructions.
hello know the green light stays on only goes of when you take head phones of unit
Mar 22, 2009 | Unwired Audio Players & Recorders
Sharper Image CT411 head set batteries?
you peal off the soft part of the headphones that cover your ear you'll see the battery compartment from there
Feb 25, 2009 | Sharper Image (CT411) Consumer Headphones
I can't open the battery compartment
Had same problem. Try pressing the heel of your hand on the battery compartment lid and rotate. Worked for me.
Dec 27, 2007 | RCA WHP141 Consumer Headphones
Royal wes50 surround sound wireless headphones Logo
Top Royal Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Royal Audio Player and Recorder Expert? Answer questions, earn points and help others
