Question about Dometic Refrigerators
Ac wont come on - Dometic Refrigerators
    Top Expert:
  • Dometic Master
  • 8,488 Answers
Check in back at outlet and check for 12 volts to board
Posted on Jun 21, 2016
WONT CHANGE OVER FROM HEAT TO AC
that could be the blending actuator its part vacuum powered
Oct 02, 2014 | 2002 Mercury Sable
2011 nisian verda ac wont run
1st is the proper freeon installed as well the vacuum done properly sometimes replacing parts cause dirt to go through the lines and plug up the system so if all was done properly and the ac was working before ! then the ac clutch is not responding so check all fuses in box easy to do then when the ac engaged check the connection at ac compressor to see if its getting power but you have to be sure that the ac system is charged properly if not it wont work
May 06, 2014 | Cars & Trucks
Ac wont turn off
replace the switch.
Sep 23, 2012 | 1998 Nissan Maxima
My a6342p cpu wont come on
Have you check the AC adapter? if teh AC adapter is good then check teh power jack that is where the AC adapter goes.
Thank you
Mar 30, 2012 | Computers & Internet
Blower wont blow out ac on 97 gmc jimmy
pop the hood and check to see if your ac pump is turning or just free spinning if it isn't spinning then u might have tripped the low ac pressure switch and may need to be checked for leaks and recharged
Jul 19, 2009 | 1997 GMC Jimmy
AC compressor wont power on.I did checkm the AC
did put a gauge on it u can get from any parts store to see if its low on freon
Apr 15, 2009 | 1991 Oldsmobile Cutlass Supreme
Dell inspiron 1501 work fine turn off last night now wont turn on
You mentioned trying a different battery, try a different AC adapter.
When plugging in the ac adapter to the wall, see if the POWER LED comes on on the adapter, then when you connect it to the computer, see if the LED stays on.
If the issue occurs with both AC adapters (No battery installed) then the motherboard has failed. If one ac adapter works but the other doesn't then the adapter is bad
Feb 01, 2009 | Dell Inspiron 1501 Notebook
Toshiba satelite A100 rejects AC... often.
Just to humor me, are you using any peripherals with your laptop when this happens, such as a wireless mouse, USB connections such as digital cameras? Try to take these away when recharging.
There seems to be 2 issues here.
1) Recharing batteries: To prepare the batteries for long-term use (I do not know how long you've had the batteries...try draining the batteries (both of them), and then recharging it to full 2x before using them without the AC Adapter. This should clear the problem.
2) AC Adapter only works every other day: When you swapped the power pack, was it with a new AC adapter, or another used one? Also, have you tried using a different outlet than the one you normally use? Let me know how this turns out.
Nov 17, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba satellite a100 wont take on power or boot
the battry is not charging and check the model of the battry whether its the same
Nov 16, 2008 | Computers & Internet
No power
Unplug All External Devices Unplug the AC Adapter From the Wall Outlet. Disconnect the AC Adapter From the Laptop Reseated the power cable to the adapter.
Remove the Battery Connect the AC Adapter Directly to a Known Good Outlet, But Not to the Computer Verify That the AC Power Adapter Has a Solid Green or Blue Light.
The AC adapter status light is solid green. The AC adapter status light is solid green.Press the Power Button and Check for POST. Post means if you see the dell logo,remove the battery, plug the ac if still it wont turn on or doesnt have any light,Reseat the Memory if after reseatting the memory still the same problem it might be a bad motherboard.
Oct 23, 2008 | Dell Inspiron XPS M140 Notebook
Refrigerators Logo
26 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
