Question about Ovens
Lamona manuals Can't get the oven to turn off auto child presses all the buttons
5 Suggested Answers
SOURCE: Oven display blinks between 0:00 and auto.
Power had gone out. And the oven don't work when the clock is not set. So I ajusted the clock and bingo! everything in order!
Posted on Sep 01, 2009
SOURCE: Defy thermofan flashing 0.00 and auto. I've tried pressing key 4
Hi
Can somebody please help
Thanks Terry
Posted on Jun 19, 2010
SOURCE: what buttons do i use to set lamona oven clock
How do I set a clock on a single electric oven
Posted on Sep 01, 2011
SOURCE: Lamona HJA4560 oven manual
Try this link it might help
http://www.docstoc.com/docs/71826497/Lamona-Double-Fan-Oven---HJA4560-Lamona-Built-Under-Double-Fan-Oven
Posted on Jun 06, 2013
How do I remove the child lock message on my Panasonic Inverter Microwave?
Press {Stop/reset} button 3 times to unlock the unit. Or un-plug it for a little while. To put the unit into child lock press the start button 3 times.
Aug 20, 2011 | Ovens
How to unlock child lock form cylinda 265
Turn on the stove.. then press the + & - buttons at the same time and then again hold the - (minus button) until the LOCK L turns off.
May 09, 2011 | Ovens
My neff oven error -5-. How do i turn this off?
I also had an error 5 on my Neff B1691 cooker. This indicates that a child lock has been set. To unlock you just push and hold the central control button in for about 7-8 seconds. Do the same again to set the lock again...
Mar 21, 2010 | Neff B1421 Electric Single Oven
Cannot set time and Oven will not operate
Depending on the make of oven, you have to press the buttons in a certain sequence if it is a digital one, try pressing the buttons in sequence, sometimes you have to press 2 together, and a third one at the same time,if it is a anologue timer, then make sure you can see the symbol of a hand in the display.
If you cannot get the timer of auto, then it is probably faulty.
Please rate my solution.
Thanks.
Jul 19, 2009 | Ovens
How to set the timer
1. Set the oven to the required
temperature.
2. Press the g button.
3. Set the total cooking time with the +
button (see the example in the
illustration right, showing 1 hour and
30 minutes).
4. Press the h button.
5. Set the cooking finish time with the +
button (the example in the illustration
shows 12.30 hrs.).
After setting the display shows the
time of day and indicates »AUTO«.
The oven cooling fan will start
immediatley.
At the pre-set time, the oven will be
automatically switched ON.
The settings can be corrected at any
time.
When the pre-set cooking finish time
is reached, a signal sounds and the
oven is automatically switched OFF.
To turn the signal off, briefly press the
h button.
6. Turn the oven selector switch to the
0 position.
7. The »AUTO« symbol blinks.
Important: It must be switched OFF
by pressing the E button.
Also here is the manual.
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Good Luck
Jan 20, 2009 | Neff U1721 Double circotherm Electric Oven
Child lock code -5- has appeared.
Here is what worked for me.
Turn left to light on, then off
on/off (light)
on/off
on/off
(4-5 times)
do not run through the complete cycle of options
just to the light and back off.
Ken
Aug 16, 2008 | Neff U1661 Double circotherm super...
Tricity bendix double oven
My oven's fan is working but no heat what so ever what shall i do
May 07, 2008 | Ovens
Auto Timer
hi there switch your oven off at the mains switch for one minute thenswitch back on and set the time this will disable the auto on the timer.
Dec 09, 2007 | Neff U1661 Double circotherm super...
Ovens Logo
110 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
