Question about Bosch BC130 - 30 Minute 9.6v - 24v Charger
Charger smokes wen pluged into outlet - Bosch BC130 - 30 Minute 9.6v - 24v Charger
Hi I got a Toyota corolla 160i gle and it was parked very long so wen i started it wen ideling no smoke BT wen hit da fuel it smokes and on take off BT wen driving it does nt smoke
Generally, it may smoke on startup for a few seconds then quit and seem to run fine, then you hit the gas and it smokes again, so Is it white smoke gray smoke or blue smoke? Because IMO it's either a bad head gasket, bad valve guides, rings are going bad ot dumping to much fuel into carb or injectors.
Mar 14, 2015 | Toyota Corolla Cars & Trucks
I plugged it into a wall charger to charge it and it enlarged the screen and i cant reset the setting to disinlarge it i guess
is the printer still working???if it is then switch it of for 1hr and wait it to cool t seems u have flashed the memory wen u pluged the power.
Dec 20, 2010 | Office Equipment & Supplies
Acer 3860 no power
Contact your manufacturer for further assistance.
Jul 29, 2010 | Acer Aspire 3680-2682 Notebook
My acer aspire 3680 wont power on. i pluged it in and the wall outlet kind of sparked and now my computer wont come on at all
Hi did you try plug in other wall outlet to see if its the charger that is bad? and you can try using another charger 1 you sure is working this will determine if it is the charger or computer is damage.
thank you
if my advice is helpful kindly vote for me
hbristol173
Mar 31, 2010 | Acer Aspire 3680 Laptop
The charger that pluges in the wall failed and melted the wires and the outlet in the wall. sould i buy another phone or charger.
You definitely need to purchase another wall charger.
However, before you purchase another phone, use a car charger to determine if there is a problem with your phone. If the car charger does the trick then you should be able to purchase just another wall charger.
And, make sure when you purchase your new wall charger that it is an OEM (original equipment manufacturer) charger and not a cheap knock-off.
Feb 02, 2010 | Inter-Tel ECX 1000 Telephone
I have a externial GPS system that will not work in the cars accerse, but will work when pluged in to a house out let, not sure if the GPS to car connecting wire is bad ,or something in the car (fuse) is...
while its plugged in to the car outlet, make sure the green (some have red) light is on, on the adapter.if it is not on, try a charger you know is good in the same outlet to verify the outlet is good. if it is, check the end of the charger that plugs in to the car outlet. check the fuse in the tip of the car charger(adapter) by unscrewing the silver tip off the charger and remove the fuse and see if its blown. take the fuse to a local electronics store for a replacement.
Sep 22, 2009 | Magellan RoadMate 1470 GPS Receiver
White smoke wen starts from cold an hunts 20 secs.
sounds to me like your idiling too high
May 28, 2009 | 1998 Volkswagen Golf
Power gone on nintendo ds lite
Hey if you have a warranty nintendo might repair or raplace the Ds.I thought about replacing the charger or place the charger in another power outlet.I hope I helped.
Dec 30, 2008 | Nintendo DS Lite Console
Nitendo ds lite
Ive done this.......
1.Blow into end of DS charger...
2.Dip end into salt.*DO NOT STIR IT AROUND...dip in and pull out*
3.tap end onto a hard surface LIGHTLY untill excess salt is out/off of tip...
4.Blow into end/tip of charger again...
5.Plug in your charger...
***WHEN PERFORMING THE STEPS ABOVE MAKE SURE CHARGER IS PLUGGED-IN TO OUTLET***
Oct 11, 2008 | Nintendo DS Lite Console
Bosch BC130 - 30 Minute 9.6v - 24v Charger Logo
Top Bosch Electronics - Others Experts
Mike
ray gallant
Are you a Bosch Electronics - Other Expert? Answer questions, earn points and help others
