Question about D-Link Computers & Internet
How to conect motorola modem sbv5121 to a D-Link router
One Piece
  • 53 Answers
SOURCE: ativa router
ok, fine....
Reset the Ativa router to factory defaults. This is normally accomplished by holding the reset button down for 10 seconds or more with power on for most routers.
Once you do that, you need to connect the computer directly to the motorola modem and configure it to be in "bridge mode".
Putting your modem into bridge mode means to bypass the router function and make it work as a simple modem. And, yes, if you do that then you must configure your wireless router to make the internet connection. If you don't want to do that, you can leave the modem as it is, I think the Ativa wireless router can still work even if your modem is still in PPPoE & you can still configure the router as an ethernet switch & wireless access point.
Now you can connect the router (after powering EVERYTHING down), turn on the modem, wait for steady connect, turn on the router, wait two minutes, boot the connected PC.
After you get a wired machine connected, you can enter the Ativa setup and configure the wireless security.
Open up IE or Firefox. On address bar, type in "192.168.2.1" and click enter.
Ativa wireless setup should load up. On top right, there is a Log In button. If this is your first time login in, leave it blank and submit.
Check up on the following: a) Internet WAN > Connection Type > select Dynamic; b) Wireless > Channel and SSID > Disable ESSID Broadcast, also set wireless channel to AUTO; b) Wireless > Security > set up your security, you should know what to do.
Now for the most important thing. Click Firewall, and DISABLE IT!! By doing this, it said that you'll will be vulnerable to hacker etc...blah blah, but with security keys to access wireless and virus program/window firewall should be enough to make you stop worrying. Apply changes, then the thing restarts.
*** also leave MTU setting to 1454 & set it to auto connect; leave the DNS & MAC settings alone; also leave LAN settings as it is.
i would greatly appreciate if you could give me the modem's exact model no. (such as SB4200, 2100 etc.) and the router's as well....
Posted on Apr 24, 2008
dhruv765
  • 53 Answers
SOURCE: motorola router
Modem light goes RED if No external Ethernet device has been attached and detected OR The Ethernet link is down.
in your case it is going to be the DSL MODEM ....
Second cause could be The WAN interface has been disabled by the firmware.
TO enable it log on to your router's address http://192.168.10.1.
and look for WAN options.
http://broadband.custhelp.com/cgi-bin/broadband.cfg/php/enduser/std_adp.php?p_faqid=17058&p_sid=rTOCxT5j&p_lva=17178&p_accessibility=&p_redirect=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9ODAsODAmcF9wcm9kcz02MzAsNjQ0JnBfY2F0cz0mcF9wdj0yLjY0NCZwX2N2PSZwX3BhZ2U9MQ%2A%2A&p_li=
Thanks ,, please let me now it worked or not
Posted on Jun 09, 2008
dante777
  • 623 Answers
SOURCE: How to connect Wireless router to Cabel Modem and Vonage Modem?
First of all: it would be good to know which devices you are using. This would help to be more specific.
But anyways:
  1. Connect a normal Ethernet cable from your DSL or Cable modem to the Internet (or WAN) port of your vonage router.
  2. Then connect another Ethernet cable from one of theLAN ports of the vonage device to the Internet (or WAN) port of your Linksys (The one that is separated from the 4 LAN ports.)
  3. Make sure that the Linksys is set to DHCP (Dynamic IP Address), soit can get it's IP address from the vonage router! (Look at your manual. If you don't have one, you can get it here. Choose the right version number - you can find that on a sticker at the bottom of the router - and download the user guide)
  4. Connect your computer to one of the LAN ports on the Linksys.
If you have any more questions or this desciption is not clear to you,just come back here and leave a comment - I'm happy to help.
Posted on May 23, 2009
daryn720
  • 113 Answers
SOURCE: need to connect my old Linksys modem to a new Motorola SBV5121 cable modem.
THE MAIN LINE GOES INTO THE WAN PORT FROM THE MODEM PROVIDED FROM YOUR MOTOROLA .....THEN THE 4 PORTS ARE TO CONNECT THE COMPUTER ....HAVE FUN
Posted on Jun 02, 2009
  • 86 Answers
SOURCE: how to open port for motorola cable modem SBV5121
If you are not using a router, you probably have one built into your modem provided by your ISP. You would need to either reply back with the make and model of the modem or contact your ISP and ask them how to do it.
Posted on Jun 03, 2009
Router 8 digit pin number
Look on the sticker for the Network Access Key. Sometimes they don't have 8 numbers.
Aug 21, 2013 | Motorola Computers & Internet
Wirless conection dosnt work
it could be a driver issue with your wirless adapter what wirless router are you using
May 15, 2010 | Arris SURFboard SB4100 Modem
I Have a D-link DI-524 wireless router and verizon Broadband modem w/USB conection the G router only has ethernet connections .How can I make this Combo work?
If your Broadband modem is only with w/USB connection you have to change modem/router, you won't connect it with usb to di-524.
Jul 05, 2009 | D-Link AirPlus DI-524 Wireless Router
Need to connect my old Linksys modem to a new Motorola SBV5121 cable modem.
Jun 02, 2009 | Linksys Wireless-G WRT54G Router
How to open port for motorola cable modem SBV5121
May 21, 2009 | Arris SURFboard SBG900 Wireless Router...
I just bought a laptop and im trying to conect to the internet with a sb512 modem that is conected to my computer. is this possible or what do i need to do. Please help
you need to plug the ethernet cord from the calb emodem into your laptop unless you have a wireless router- once you have done this you will need to unplgu the power cord from the cable modem and plug it right back in.
May 17, 2009 | Arris SURFboard SB5120 Modem
Motorola router
Jun 09, 2008 | Arris WR850G Router (DHWR850G)
Motorola router
first check your computers internet connection settings.and also check for any updates that could pretain to your modem/or computer.the problem is with your main computer,and not with the router.second check your firewall,make sure the correct port is open to let the traffic in.
Dec 28, 2007 | Arris Wireless G Broadband Router (wr850g)
Computers & Internet Logo
22 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
