Question about Chevrolet 03-05 Chevy Silverado 1500/ SS Upper Stainless Steel GrilleC75717T 71648
Head gasket puking antifreeze out my drivers side exhaust and burning coolant in about 20 minutes
  • 30 Answers
SOURCE: leaking antifreeze
A quick check you can do to help your troubleshooting is to remove the radiator cap then start the vehicle. (Ensure radiator filled so you can see fluid level). Watch the fluid inside the radiator. Initially after you start the vehicle you will get some small air bubbles but they should go away in less then a minute. If after a couple minutes you have bubbles continually coming up or it starts bubbling out of radiator then you can bet on the Head gasket. If you do not get the bubbles it dosen't rule out either one but if they are there as described then you can look at the head gasket.
Posted on Aug 16, 2008
tripletauto
  • 1450 Answers
SOURCE: coolant in exhaust pipe but not the oil
THIS SOUNDS LIKE YOU ARE TALKING ABOUT EGR PIPE. AND NO IT WONT CAUSE COOLANT
Posted on Dec 30, 2008
polarcycle
  • 1392 Answers
SOURCE: replaced intake gaskets.ran fine before. burns antifreeze now
Sounds like the gasket is not sealing correctly, or you have a cracked head. Did you use a factory gasket from the dealer? If not, this is most likely the reason. Haven't had much luck with the aftermarket stuff working correctly on those.
Posted on Jun 02, 2009
buffalonyman
  • 1865 Answers
SOURCE: One of the head gaskets
Go to autozone.com and register yourself and your car (its free). Then you will be able to access the online repair manuals for your vehicle. It will show you how to replace your gasket
Posted on Sep 20, 2009
  • 1244 Answers
SOURCE: i have a 1998 chevy 2500 4x4 6.5 diesel pu.truck
the head gaskets are blown you can believe that anytime on any engine gas or deisel that you get oil in the radiator and there water/ antifreeze in the oil pan the gaskets and or cylinder heads are bad
Posted on Jan 20, 2010
Blown head gasket
big job! need to pull heads out and send them to machine shop to have them check need new gasket and head bolts
Jan 05, 2014 | 2001 Chrysler 300M
Engine over heats after antifreez is added
How are you adding coolant, why, and how is the engine overheating ?
It could be that you have a blown head gasket and the engine is burning the coolant out the exhaust.
Feb 04, 2013 | Cars & Trucks
How do I locate a leak that lets antifreeze and oil mix inside the oil pan?
Most likely a head gasket. The coolant is forced into the oil chambers and mixes. This too leaks into the exhaust gases and burns off as you describe. You usually get oil in the coolant reservoir. This can be checked with a test strip available at automotive supply store. It measures the acidity in the coolant.
Feb 21, 2012 | Cars & Trucks
Car overheats, losing antifreeze...the overflow coolant reservoir leaks out onto the ground when I try to put antifreeze in there - so could this cause my car to overheat? I have had the antifreeze drained...
Hello, if your car has a blown head gasket and exhaust is entering the coolant system, it will continue to run hot until it is repaired. Using pure antifreeze will make it worse. It should be at least 1/2 water. If the coolant reservoir didn't leak you could probably drive a few more miles, but not many, before it overheats again. All that is doing is giving you a little more capacity. If you continue to run the engine hot you are going to do more serious damage to it.
I suggest you have the head gasket replaced. That stuff you put in there seldom works, and if it does work, it's only temporary.
I hope this helps.
Sep 17, 2011 | 1985 Honda Civic
There is white smoke coming out the tailpipe no smell of antifreeze
If it doesn't smell like sweet then you most likely got a bad tank of gas. Just to be safe keep an eye on your engine temp. and coolant levels.
Mar 26, 2011 | 1993 Dodge Intrepid
Blowing anitfreeze out the tailpipe. I know this means a head gasket. When the engine runs, it blows antifreeze out the passenger side of the engine at the exhaust manifold by the middle cylinder. Does...
could be just head gasket and bad exhaust manifold gasket (coolant leaks past head gasket into exhaust port then leaks out of exhaust manifold gasket)
or it possible that head is cracked too
Only way to know for sure is to remove head and inspect it
Jan 06, 2011 | 1986 Ford Bronco II
White smoke from exhaust pipe..
White smoke is a sign of coolant being burned in the exhaust.
Jul 05, 2010 | 2003 Ford Explorer
My 2004 kia's engine pops and stalls before starting. Antifreeze is leaking somewhere that can not be seen. Exhaust smells like antifreeze
blown head gasket. Your coolant is leaking into the combustion chambers and you are burning it. If you can still drive it you might want to try putting in K&W block sealer. Follow the directions carefully and this may prolong the inevetable. Need your heads inspected and new head gasket.
Oct 13, 2009 | 2004 Kia Sedona
1999 VW Jetta:it uses a whole can of anti freeze every other week
either the water pump is bad and water is leaking out of the weep hole on the bottom of the water pump while the engine is running OR you have a blown head gasket that is letting coolant seep into a cylinder and it is being burned by the engine. Have another car follow you on the highway while doing about 60 MPH or 100KPH and then floor the gas on the car and see if the car following you can see any smoke or mist looking exhaust coming from your car. If they do see mist or smoke coming from your exhaust, you most likely have a blown head gasket that is allowing coolant to be burnt by a cylinder.
If you can't afford to repair the car at this time, if you keep your eye on the coolant level and refill it when it needs coolant, you could continue to drive the car until you save the money for the proper repair.
Much good luck.
Jan 06, 2009 | 1999 Volkswagen New Jetta
Chevrolet 03-05 Chevy Silverado 1500/ SS Upper Stainless Steel GrilleC75717T 71648 Logo
65 people viewed this question
Top Chevrolet Wine & Spirits Experts
Don Hart
Dave braun
Dave braun
Don A
Don A
Are you a Chevrolet Wine and Spirit Expert? Answer questions, earn points and help others
