Question about Camping, Backpacking & Hiking
Could you tell how many Watts this uses/camping & rv
HOW MANY WATTS DOES A 60 LITRE CAMPING FRIDGE USE
That info will be posted on a back plate on the refrigerator.
And if you cannot find anything on the back or inside then hook up ammeter to the unit and measure the amps used after it has been running for about 15 minutes. Then using formula watts = amps times volts (115 in USA) you can arrive at the wattage of unit.
Mar 16, 2015 | Freezers
What's a camp cupboard?
Camp cupboard will allow you to keep items safe and well organized, what should make the searching process very short. Camp cupboards are advised to be used only for trip with a car or a RV.
Sep 04, 2012 | Bass Pro Shops Camping, Backpacking &...
I'm going on a RV trip, which camping chair is recommended for me?
If you're going to a RV trip right to a campsite you can choose between two types of camping chairs, the basic camping chair and the comfortable camping chair.
How many Watts will 1350 btu RV roof model use? I have a Dometic 641815 model . I want to buy this Yamaha 2400 watt generator.
Hello, I have the same exact generator, 2400 Yamaha. It works fine for my Ac, and then some. After it first kicks on, is the biggest surge. Then I have even after ac is running, I have had tv on and even used microwave. But as far as running you ac on your rv , not problem. I do it all the time. Mine is ulta quite, and 8 to ten hours run time on about a gallon of fuel. Mike
Oct 29, 2011 | Dometic Rooftop RV Air Conditioner
How many watts does a 59516-751 model require to run?
Answer
Simple Answer is just to know two formulas
Ohm's Law
V = IR
Power
P = IV
From those you can calculate voltage, amps, watts, ohms
V = Voltage (volts)
I = Current (amps or amperes)
R = Resistance (ohm's)
P = Power (watts)
Just solve for what you are missing.
Voltage times amps being drawn shows watts produced.
Watts divided by voltage shows amps being drawn or watts
divided by amperage shows voltage applied.
Sep 28, 2010 | Dometic Rooftop RV Air Conditioner
My air cond is blowing the 20 amp breaker when camping but runs just fine for the dealer. It blew 11 times in 48 hours last weekend.
Ifr you are plugging into a external source for power, they or whereever you are camping has the wiring issues, to small of wire
Jun 17, 2010 | Dometic Rooftop RV Air Conditioner
I have a coleman model 8333A8664 a/c unit on a fleetwood camp trailer and was wondering what watt generator would be needed to run it properly?
Because it won't be powering just your AC, I would recommend 5000W. It's that big amp draw when compressor kicks in that will pull it way down, if not strong enough. Take for example the fact that a dedicated 20 amp breaker and cable are the norm for RV's to use for AC now. Double check also that the generator your purchasing will take a momentary surge draw of up to 20+ amps without tripping breaker on generator. I say 20+ because once RV is plugged in or wired to generator, it will be powering any other hydro operated appliances, lights, converter etc that the trailer has on board. I bought a cheapie rated at 4000W, and 3000 running watts, but it kicks out the breaker just trying to start my portable air compressor, rated at 15 amps.
Jun 10, 2010 | Heating & Cooling
Full black water holding tank
Add some digester from any rv store & hope it breaks up, otherwise, get your stick out.
Jul 26, 2009 | Dometic Rooftop RV Air Conditioner
Portable generator pops breaker when temp is over 75 degrees
I take it you have RV plugged into generator. Hopefully direct with no extension cords. Are you using a 30 to 15 amp adapter to plug into generator? What is the rating of the breaker on the generator that keeps tripping, suspect it's only 15 amp?
Jul 20, 2009 | Dometic Rooftop RV Air Conditioner
Camping, Backpacking & Hiking Logo
74 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
weirdtop
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
