Question about Xerox Phaser 7400DN Laser Printer
Phaser 7400DN prints have ghosting and blotches on the entire print. The LCD screen says all components are ok. Suggestions?
  • 2072 Answers
SOURCE: Problem printing in color on Xerox Phaser 8200 from Mac
That actually should make magazine quality color.
What are you experiencing? Do the colors not match? Are there smears or light streaks?
I will gladly work with you to revolve your problem, I just need a frame of reference to start.
Let me know.
You may simply need to download and install a different driver.
They are on www.xerox.com you should be running the PS version of a driver for better graphics.
Posted on Apr 02, 2008
  • 2072 Answers
SOURCE: phaser 8560 blurr
There is an encoder on teh drum motor that picks up lubricant from the maintenance kit and causes those blurs. It eneeds cleaned or replaced
Posted on Jul 12, 2008
  • 122 Answers
SOURCE: Since a paper jam the other day, our phaser 6110
take the cartridges out and put it back in and see if it works
Posted on Feb 14, 2010
JackHeath
  • 1049 Answers
SOURCE: printing/ghosting ink randomly?
ghosting and Horizontal streaks are usually the toner cartridge or the drum; vertical steaks are usually the thermostat or the fuser. Before you spend a lot of money on a new fuser...If you are getting horizontal streaks or ghosting and changing the toner cartridge out fixes the issue temporarily, I suspect you just have people taking the blank pages that print out after printing and feeding them back through the printer to save paper.
The old paper picks up a charge when fed through the first time, pulls toner up the second like a magnet, and deposits the toner onto the toner drum. When the next sheet comes through, the image itself or a black line of toner can be pulled from the last sheet (or the sheet before) and is transferred over the new image. Change your toner and print several pages to the printer, see if the problem fades and goes away.
If it does, just tell people to either stop feeding the blank pages through, or to at least turn them over and put them at the bottom of the paper stack. This will give it time to dissipate the charge before feeding back through.
Posted on Mar 09, 2010
  • 99 Answers
SOURCE: Xerox Phaser 8560DN printer will not print duplex.
email me printerman007 at gmail.com
Posted on Mar 13, 2010
I keep getting a magenta line on my Xerox 7400DN. Even after changing the magenta imaging unit. What could be causing this?
have you run the maintenance ie. clean printer head and print a test page this will usually give you an indication as to what could be faulty .
Oct 31, 2016 | Xerox Phaser 7400DN Laser Printer
Why is my printer not printing the right color? its very faded
Is your printer set to Economode in the printer settings? It may be and so its printing at low quality.
Jul 16, 2014 | Xerox Phaser 7400DN Laser Printer
Xerox Phaser 7400, lines on solid colours
Are the streaks evident when printing actual images? I was told by an experienced Xerox service tech that those solid-fill test pages can be misleading -- mine does the same but prints photos beautifully. I suggest printing some full page photos, check for the streaks. You've already done just about all you can.
Jun 19, 2014 | Xerox Phaser 7400DN Laser Printer
Can I print to the edge with Phaser 7400
No this is phisically impossible, try a larger sheet of paper and cut it
Mar 17, 2013 | Xerox Phaser 7400DN Laser Printer
Xerox phaser 7400DN jabs at fuser
The printer trays accommodate most sizes and types of paper, transparencies, or other
specialty media. Follow these guidelines when loading paper and media in the trays:
- Envelopes, labels, and glossy paper can be printed from Tray 1 (MPT) only.
- Transparencies and custom size paper can be printed from Tray 1 (MPT) and Tray 2.
- Fan paper, transparencies, and labels prior to loading them in the tray.
- Use only paper envelopes. All envelopes should be printed single-sided only. Some
wrinkling and embossing may occur when printing envelopes.
- Do not overload the paper trays.
- Adjust the paper guides to fit the paper size.
- If excessive jams occur, use paper or other media from a new package.
Mar 06, 2011 | Xerox Phaser 7400DN Laser Printer
Not getting enough heat for phaser 7400
If you mean the toner is not fully melting on the pages that you print. Then make sure you are selectin the corect paper type you are printing on. If you are printing on some kind of thick paper select heavy wieght or card stock. The fuser heats to different temps for the type of paper used. thiner paper dosen't need to be heated a much as thicker paper. Check your settings.
Apr 30, 2010 | Xerox Phaser 7400DN Laser Printer
Its printing patchy and ghosting
it will yes. I know with fusers and xerox you can usually reset the fuser. When servicing the machine the techy will do this for you:)
Nov 18, 2009 | Xerox Phaser 7400DN Laser Printer
Xerox Phaser 6360N ghosting images on each page
Is it a ghost of the image or just a repeating defect? In the menu, there is a repeating defect information page that you can print out. Depending on the spacing of the defect, you can determine which component it is.
Mar 10, 2009 | Xerox Phaser 6360/N Printer
Xerox phaser 7400DN right side "A" door adjar
YOu will need to replace the cover. There is a small tab or a magnet that actuates a switch. If its a tab type cover, the tab snapped off, if a magnetic cover the magnet has fallen off.
Jul 16, 2008 | Xerox Phaser 7400/DXF Laser Printer
It looks like it's ghosting - shadows
Most likely the fuser needs replaced. The heat roller is worn and causing reprint.
Jun 27, 2008 | Xerox Phaser 7400DN Laser Printer
Xerox Phaser 7400DN Laser Printer Logo
52 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
