Question about Nixon The Genie Watch
Nixon genie watch beeping
I pressed in the side button that sticks out that is normally the stop watch button and now my watch keeps beeping every 5 seconds and flashing a black screen and it will not stop. Not sure what is going on or how to reset it PLEASE HELP it wont stop
escapement
  • 2334 Answers
SOURCE: how to change the battery on a Nixon Scout Watch?
Strap is attached to case by spring pins. Both ends of spring pin are inserted into holes into the case lugs,
. Take the knife and push the spring pin end inwards to release the watch strap.
Do not forget to rate, please.
Posted on Feb 10, 2009
SOURCE: nixon super rover..need to know how to reset the chronograph
Pull the stem all the way out...like your setting the date. Then hit the upper button and that will move the hand 1 second at a time until it gets here you want.
Posted on May 20, 2009
  • 2501 Answers
SOURCE: I lost the manual for
Go to http://www.nixonnow.com/mens-watches/ and scroll down until you find yur watch.
Clcik on the picture and you will find an enlarged illustration; at the bottom of the page there is a link "download user manual" click on this and you will find the instructions you need.
I found the site a little flakey, so you may have to be a little patient; the download seems a little slow, so it may pay to wait for it to respond to mouse clicks.
Posted on Dec 12, 2010
SOURCE: I have a Nixon LowDown
Hey, this just happened to my nixon watch (I have the nixon housing - same setup as the lowdown) and what you have to do is simply hold in the light display button for about 3 seconds and the display won't disappear after the light times out.
hope this helps :)
Posted on May 10, 2011
SOURCE: my new nixon 42 20
  • Undo & pull the crown all the way out,then
  • undo the adjuster button (the one underneath the crown)
  • push the stop/start adjust button one push at a time and it will move in slight increments,keep going till you get the second hand on the 12 mark
  • then push the top adjuster and it will go back to the 12 mark.
  • Push the crown in and wind your adjusting buttons up and you have finished
Posted on Sep 19, 2011
Backlight Problem
I would exchange it for another.
Jun 18, 2014 | Nixon The Genie Watch
Wont stop beeping
OMG me too!! Just got the watch today and none of the features to stop/start or reset respond!!! It's crazy...
Feb 06, 2014 | Nixon The Genie Watch
Turn off the hourly beep on my Nixon The unit?
For the actual time press the "B" button once, the top screen should say "AL". Now Press the "D" button until the alarm/chime goes away.
Aug 04, 2013 | Nixon The Unit Watch
My partners Nixon Outsider (code: A109 000) has woke up up with a short beep every 45 secs. what does this mean and is there a code with buttons to stop it? tried pressing all buttons but nothing happning,...
I have found the instructions on their web site but this alarm is not mentioned.
I suspect that it is a battery low indication; this would be consistent with a battery that is over a year old .
Try having the battery replaced.
May 18, 2011 | Nixon OUTSIDER WATCH
I stop using mi nixon watch " THE 51-30" for a month and now it doesnt work.
Your watch is an automatic type which means that it is a mechanical self winding watch powered by a spring. It is wound up by a weight that moves when you are walking about and this watch must be worn to keep it operating.
If not worn, these watches will stop in 2 -3 days because the spring has run down.
Some automatic watches can be wound using the crown wheel (winder) but if yours cannot be wound in this way, then swing it from side to side gently for a few minutes and the watch will wind up.
These watches thrive on being used.
Oct 27, 2010 | Nixon 51 30 Watch
How to i turn off the hourly beep on my nixon lowdown watch
This is not done in the alarm section. In the time view, press and hold the wave#/reset button (lower right) until it beeps (3 seconds). That's it. The watch should be silent now when cycling through and on the hour.
Sep 06, 2010 | Watches
Nixon lowdown - hourly chime
It is so simple. I struggled with this forever then called customer service. To turn off the hourly chime just press the bottom right (wave/reset) button while in the normal time/tide screen. You do not need to go through all of the modes. Just one button press from the home screen. When you see the target icon disappear you have done it.
Apr 06, 2010 | Nixon Lodown Tide watch
Beeping hours
I do not know which watch you have but generally this seems to be what you need to do:-
Press the "mode" button and keep pressing until you reach a display that says something like "hourly beep". It may be abbreviated (hb?).
I would expect it to say on/off which you can toggle by pressing one of the other buttons (some experimenting may be required).
You the press the mode button to return to normal operation.
If you are still having trouble, yu can go their web site ("makersname.com" usually) and download instrructions.
If you have any trouble with this ask for instructions and give your watch brand and model.
Jan 27, 2010 | Watches
Innovage Gear wristwatch beeps every hour
To turn off the hourly beep: While holding the lap/reset button down, press the mode button. When all 7 day flags show, the hourly chime is on. When no day flags show, the chime is off.
Mar 11, 2008 | Watches
Nixon The Genie Watch Logo
Top Nixon Watches Experts
Ansel Alberto
Ansel Alberto
rhodesworks
Are you a Nixon Watch Expert? Answer questions, earn points and help others
