Question about SMProAudio SM Pro Audio TB202 2 Channel Tube Mic Preamp and Compressor Microphone
SM Pro Audio TB101 Tube Preamp - SMProAudio SM Pro Audio TB202 2 Channel Tube Mic Preamp and Compressor Microphone
Numark pro sm
Great that you posted, what is the question?
Apr 14, 2013 | Numark PRO SM-1 Mixer Professional DJ...
I would like to ask anyone who has experiment on hook up....
Do you have necessary cables to hook up balanced output? its 3 pin cable.
Please let me know to help you further.
Sep 21, 2008 | SMProAudio SM Pro Audio TB202 2 Channel...
THERMOCOUPLE BAD ON MY REDDY HEATER MOD#TB101 CANT FIND PART # FOR IT
The Part # for the Thermocouple is 104146-05.
Keep in mind, DESA International is no longer in business, but I think you can find it at
www.reddyrparts.com
Feb 01, 2011 | Desa International TB101 Heater
Basic settings for behringer mic2200
basic would be all dials in the middle. and appropriate switching on/off of (phantom power) +48volts. this option is required for condenser mics but way too strong of a signal for normal dynamic mics,like the shure SM 58. or any non-balanced input
Dec 23, 2010 | Behringer ULTRAGAIN PRO MIC2200 2 Channel...
I have a Peavey Valve King 112. When I plug in my guitar I get nothing.The power light is on and the preamp is on as well.There is just silince.No humming or crackling.
This could be anything. You could try swapping the preamp tubes. If it were a power amp tube problem, it is likely the mains fuse would have blown, Since the pilot lamp is still on, we will assume that the problem is at the preamp level. This absence of signal can be caused by a dead tube, or more complexly, by a faulty resistor or capacitor in the signal path. If you can't resolve the problem by swapping preamp tubes with a known good one, you should take the amp to a tech experienced in servicing tube guitar amps. Any good tech should be able to sort this out within an hour of labor time. I doubt it will require any expensive parts. It may even be as simple as a loose/bad connection, either from manufacturing, or from normal use. Pro tube amps are subjected to levels of heat, vibration and electrical stresses that consumer electronic gear never sees.
Oct 06, 2010 | Peavey Audio Players & Recorders
Propane Tank Size needed for Reddy Heater TB101
Yes it will work but it will heat more efficiently with the 100 lb tank
Jan 05, 2010 | Desa International TB101 Heater
Phono Preamp buzz
Don't forget to ground the ground cable from the turntable.
Sep 15, 2008 | Technics SL-1200MK2 Turntable
Set up m-audio buddy dual mic preamp
ive got a problem cuz this thing doesnt have a ******* firewire port. and i was hopoing to use this for pro tools. i need to know where i can get an adapter of some sorts. but what you should do is hook the mics in to the back ports. adjust volume. then do the ****
Mar 25, 2008 | M-Audio Audio Buddy Dual Mic Preamp...
Marshall tube amp problems
There is a bridge rectifier and red and black wires jumping from preamp tube to preamp tube. These need to be resoldered, take it to your favorite pro audio service center. I'm doing this to the same amp right this minute! Send it to me, I'll fix it. Tom Peary Norman's Electronics Atlanta, Ga 770 451 5057 www.neiusa.com
May 01, 2007 | Marshall 82 WTS LITHIUM BATTERY, 3 LED...
46 people viewed this question
Top SMProAudio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a SMProAudio Audio Player and Recorder Expert? Answer questions, earn points and help others
