Question about Cameras
Can't charge my ION air pro
Ion air pro will not charge up. It appears to start charging but then stops quickly and the led flashes red.
  • 374 Answers
SOURCE: casio Ex-Z70
your battery is no good. you are going to have to replace your battery.
Posted on Sep 10, 2008
SOURCE: my casio lithium ion battery np 20 flashes when Im charging it...y?
Yes you need a new battery, call 1 800-706-2534 and ask for a new battery. If they say no, try again with somebody else until they send you one for free
Posted on Oct 28, 2008
SOURCE: Battery charger light flash
Its pretty simple to fix. The lithium battery has just depolarized. Just buy a 9V battery.... put them end to end... the 9V and the lithium and touch the metal parts of them. hold for 20 seconds... if it doesn't work, lick the 9V to conduct the electricity better.. hold for 20 seconds and put directly on the charger... I just did this, and it is charging as we speak! good luck!
Posted on Feb 18, 2009
  • 3 Answers
SOURCE: I lost my battery charger and i need to charge my camera battery
you now can buy chargers to replace lost ones, i work in a camera shop and sell a brand called Hanmel. they do a range of the most popular brands of camera chargers, just check the back of the hamnel packaging it to see if it it compatable with your battery
Posted on Apr 13, 2009
SOURCE: when the battery is in the charger it flashes red
I called casio and they told me that when you have a red flashing light on the charger it means the lithium battery is no longer any good. They offered to send me one free of charge. It's been several weeks and I have yet to receive it.
Posted on Jan 25, 2010
Why does my light not charging
Lithium ION batteries are ususally rechargeable. The use mode for these batteries is that there
are a set number of recharges that equate to the life of the battery. Usually that life is
approximately 1,000 charges.
If you use your battery to 50% then recharge, you can do this ~2,000 times. As the life of the
battery is used up, the maximum charge lessens which means where you may have had 8
hours of play time when the battery was new, you will only have 6 hours as the battery life is
used up.
In order for a Lithium ION battery to recharge there must be at least a small amount of charge
left as a "seed" for that recharge. If you drain a L-ION battery down to zero, it may never
recharge again or the max charge will be reduced to an insignificant amount of the original full
charge. eg instead of 8 hours you may only get 15 minutes, or 5 minutes, or no minutes.
You are much better off recharging when 50% depleted than using it up til your product stops.
L-ION batteries cannot be repaired only replaced. Most cheap products using L-ION batteries
cannot have their batteries replaced.
Jun 05, 2014 | American DJ megapixel led high powered led...
Just bought a Ruobi drill with 18V Lithium Batteries. Been chatging for over an hour. Still not charged. Just the bottom Green light stays on. Is this normal? How long does it take?
The Ryobi charger will flash green as it charges and then remain steady or slowly flashing green when fully charged. Flashing red means testing and if it remains steady or slowly flashing red it is defective.
Apr 11, 2013 | Ryobi Two 18V Lithium-Ion Batteries +...
Are all the Lithium batteries working like this. Mine work for a short time then stop dead. Wait a while then they will work again. Really a pain when you are working trying to do somthing and have to run...
I use the Ryobi Li-Ion tools the L-I batteries will cut off when they get to a low charge level this is to protect the batteries Li-Ion batteries life span is shortened when fullt discharged so when the tool suddenly stops put the battery on charge,also if the battery has a charge indicator light for a more accurite idea of the charge (green is charged,red discharged) hold the test button on then run the tool the light may go from green to red if it does that shows the the charge is about depleted if the light stays green you have a little run time left.
Oct 25, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
When putting the battery in the charger the red and green lights flash indicating a bad battery, cannot charge battery.
Have you tried just waiting a few minutes, it might start to charge anyway. But if not, is there some reason you would assume that you don't have a bad battery? There are lots of bad Li-Ion batteries.
Sep 03, 2010 | Makita BL1815-2 18 Volt 1.5 Ah Compact...
I have a li-ion Makita BL1830 18V 3.0Ah battery that can't be charged...when on the charger the bottom two lights flash red..it will charge my other battery, so it doesn't seem to be the charger
Sorry Mate your battery is dead...
The makita lithium batterys dont like getting worked hard quickly.
There is a chip in them that recognice each battery to each specific charger. Try another charger. This has not worked for me. Try anyway
Nov 01, 2009 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
First charger flashes red for five seconds, then the charger flashes green. I put battery in circular saw and it runs for about thirty seconds and somewhat quickly dies out. this is after being on the...
When it is brand new only. If charged overnight and still does not last take back to purchase place and have them test battery..then make them replace it if it is bad...:)
Sep 07, 2009 | Ryobi Two 18V Lithium-Ion Batteries +...
Cameras Logo
102 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
