Question about Ricoh AFICIO MP 3010 COPIER. REFURBISHED. Comes with PRINT/SCAN/RADF
Code sc 820 ricoh mp 3010 - Ricoh AFICIO MP 3010 COPIER. REFURBISHED. Comes with PRINT/SCAN/RADF
Bubbabear64
  • 2794 Answers
SOURCE: ricoh aficio 2027
SC542 is a warm up error from the fuser.
SC 870 is an address book error.
Turn the power off on the copier. Wait 30 seconds and then turn the power back on. See if it goes away.
Let me know if it doesn't.
Posted on Jul 12, 2008
Bubbabear64
  • 2794 Answers
SOURCE: RICOH 2015 error code sc 500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
It can be a lot of troubleshooting to do.
Posted on Oct 19, 2008
  • 86 Answers
SOURCE: Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Posted on Jan 17, 2009
  • 1297 Answers
SOURCE: ricoh 1045 error code sc 672, 961
Controller to operation panel comucation error at start up.Check the controller stall,controller board installed correctly operation panel connectors.Enter im the service menu ,press the SP mode,open the front door,turn off the copier,unplugged the machine.Wait 10 seconds,plugged on the machine,close the front door,turn ON the copier and make a copy.
Posted on Dec 28, 2009
  • 161 Answers
SOURCE: Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Posted on Jan 16, 2010
SC 820 AT STARTUP ?
SC-820: Control board or software
Call Ricoh for service.
Mar 06, 2016 | Ricoh Aficio MP3350
RICOH MP4500 SC 390 DISPLAYS WHAT TO DO
Hello.
That error is related to TD sensor error.
I advise you to call a trained Technician
Mar 16, 2015 | Ricoh Savin Lanier Genuine Toner Type Mp...
I want to relocate my Ricoh Aficio MP 3300
disconnect the finisher reset it and then it will be a monster roll
Jan 05, 2014 | Ricoh SR 790 - Finisher - 1000 sheets -...
Ricoh afficio mp 1600 "sc 559 " help me
This code is related to a jam in Fusing Unit.
First of all you need to repare that jam problem. (Probably a stripper pawl out of the place) and after that you can disable that message by in SP mode. The main problem is the jams. After that reply to me and i help you disable the message
Apr 22, 2011 | Ricoh Aficio MP 1600L Black and White...
Ricoh 1515 is locked up with error message SC:820 code 612. How do I fix the problem
820 Self-diagnostic error: CPU
Symptom:
• An unexpected exception or
interruption occurs during the self-
diagnostic test.
• An error is detected in the MBU.
Possible Cause:
• Defective controller
• Defective firmware
• Loose MBU jumper
Code 820
MBU error (The jumper is loose.)
Set the jumper (on the MBU) correctly.
The following codes are displayed:
• SC: 820
• code: 612
• detail: 40000000
Feb 03, 2011 | Ricoh Aficio 1515MF All-In-One Laser...
Problem with the Ricoh mp c2800 Ricoh error code sc 672,
If the model ia a MPC 2800 it a controller board issue maybe the operation panel. -carl
Nov 15, 2010 | Ricoh Aficio 1035 Copier
Sir, My copier model RICOH MP 2000Le shows error . ADD TONER & some time it shows SC 302
sc 302 - charge roller current leak. strip the drum unit (dmu) and clean the unit
Sep 04, 2010 | Ricoh Aficio MP 2000 Black and White...
Ricoh AFICIO MP 3010 COPIER. REFURBISHED. Comes with PRINT/SCAN/RADF Logo
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
