Question about Music
How do i insert a battery in a digitech wireless digital door chime transmitter
2 Suggested Answers
  • 20 Answers
SOURCE: Hi I have a vhf digitech AM-4071 wireless microphone system and the problem is that both microphones are going only through one RF, on the transmitter. The second mic goes but its not receiving on tr
You need to check that they are both operating on different channels there should be a switch or POT on the microphone and possibly one on the reciever. If they are static or preset you need to swap one for the other channel. Some (usualy cheap) mics have a preset or static channel often ch-A and ch-B, there should be one of each in the box. If you bought the extra body packs they will also come with the preset channels.
- thegorisb
Posted on Nov 03, 2012
How to connect digitech high powered wireless router YN-8330
You may have problems getting this device to register on you network due to the available subnet.
You need to check what IP address range your existing router uses first, then connect the digtech directly to a laptop via ethernet cable, go to the default address (192.1.0.1), log in using admin/admin and reconfigure the router address to one within the acceptable range of your router..
I just configured one of these on both a TP-Link router, and on a Thompson router.
For the TP-Link (Base IP 192.1.1.1) I set the digitech to 192.1.1.100 (easy for me to remember).
For the Thompson (Base IP 10.0.0.1) I set the digitech to 10.0.0.100 (same principle).
Note: you can use any IP that is within the network range of your router.
Also remember to write down the new device ID and put it in a safe place (email to yourself or stick on the back of the router)
Other than this, all config is like any other router.
Feb 04, 2014 | Music
How to install the digitech security audio door phone 2 to 2
HOW TO INSTALL DIGITECH SECURITY AUDIO DOORPHONE 2 TO 2
Dec 24, 2013 | Music
- thegorisb
Sep 07, 2012 | DIGITECH VOCALIST LIVE 2
All it does is hiss.. sounds like a ground problem cant tell
Make sure the transmitte and receiver are on same channel. Often people get systems that are mis-matched and cannot work together. Also, use ONLY alkaline batteries in the transmitter... rechargeables quickly fail. The hiss is typical of electronics when no signal is present.
Mar 06, 2011 | Samson Concert 77 Wireless Guitar System
Hiwhat is the best way to connect my DigiTech RP10 to my Marshall MA100H Guitar Amplifier
Read your manuals for both pieces of gear carefully first. You only have one amp so you won't be able to take advantage of all the FX on the Digitech as a lot of them are designed for stereo. The Digitech manual shows guitar into the Digitech and output from the Digitech into input of any guitar amp. Since you have a Marshall and can already get some great sounds by running your guitar straight into the Marshalls input, you would probably be better off using your Digitech in the FX loop. Run a guitar cord out of the send on the loop into the input of the Digitech and a guitar cord out of the left / mono output jack on the Digitech into the effects return jack on the Marshall. Start out with the effects level on the Marshall all the way down. Do the same with the Digitech with both the input and output levels. (Read the manual carefully) I think the choice of the Digitech isn't that great because it is already trying to reproduce a lot of what you can already get with just your Marshall but with a little experimentation and some careful adjustments you should be able to add to the sound of the Marshall. Hope this helps.
Oct 23, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Change ring tones on wireless ringer SL-6166-RX-A Door Chime
The chimes have jumper plugs to select the preset songs.
You CANNOT load your own like cell phones allow.
Jul 22, 2010 | Music
Music Logo
49 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
