Question about Samsung CLP-500 Laser Printer
Samsung C9210 CTD sensor error
Where do i find the samsung C9210 CTD sensor
Ctd sensor error
The protection sheet on the imaging unit is probably still on, remove that and the error should go away.
for more help visit CBR Tech Solutions
Jul 11, 2013 | Xerox Office Equipment & Supplies
Phaser 6128 mfp error sensor ctd
Open up the side panel that houses the toner cartridges. One by one pull out the toner cartridges, with a clean dry cloth clean off the injection port(?) on the cartridge and the injection port on the printer(this will be just inside the where the cartridge locks in. Sometimes these ports get clogged with toner and need a good cleaning, causing a CTD sensor error. Our 6128mfp does this error all the time and we have not had to purchase the new parts to fix the error.
Aug 07, 2012 | Xerox Phaser 6128MFP AllInOne Laser...
CT sensor error Error code 092-310 error code 00002000 restart printer. please note will not restart also unpluged still no respond
The CTD Unit is a Sensor on or near the Transfer Belt Unit on your Dell Laser Printer. This error is advising that the sensor is dirty and may need cleaned.
If you receive one of these errors please clean the CTD Sensor on the Printer.
  1. CBR Tech Solutions orhttp://www.cbrtechsolutions.com
Apr 10, 2011 | Office Equipment & Supplies
I have an orange error light.
If it's not blinking it one of: The PHD (Print Head Device), or belt unit, life is coming to an end. Clean the CTD sensor. Try to clean the CTD sensor with a dry cotton swab. The sensor is located on the front cover (inside).
Mar 23, 2010 | Dell 1320c Laser Printer
Dell 5100cn has error message: Clean CTS Sensor -
I've included a link below to the manual for your printer. Please follow the instructions listed under "Cleaning the Automatic Density Control (CTD) Sensor".
http://support.dell.com/support/edocs/systems/5100cn/en/UG/section21.html#1097283
Jan 19, 2010 | Dell Office Equipment & Supplies
There is a "CTD Calibration Error" at display! where is the "ctd"?
CTD detects the amount of toner on the drum and is used by the printer to determine charge levels required for good image production. It is a part of the transfer belt unit and cannot be replaced on it's own. First try removing and refitting the transfer belt, making sure the electrical contacts are clean and undamaged. If that doesn't work, fit another transfer belt.
Apr 18, 2009 | Samsung CLP-500 Laser Printer
CDT Calibration Error
CTD (not CDT) stands for Color Toner Density Error. Your bad sensor is not on the printer, but on one of the color toners.
Oct 15, 2007 | Samsung CLP-500 Laser Printer
Samsung CLP-500 Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
