Question about LG BD650 BluRay Player
Factory reset button - LG BD650 BluRay Player
I need to reset galaxy tab 10.1. was my daughter's and she forgot pattern and email/password....nee d to get past the lock screen
hi Jon.
A factory data reset may help with a blank or frozen screen, apps crashing or freezing, keypad/touchscreen problems, can't hear, device making noises, can't make or receive calls, and device won't sync.
Perform a factory data reset only if absolutely necessary as it removes all data including:
  • GoogleTM account
  • System and app data
  • App settings
  • Downloaded apps
  • Media (Music, pictures and videos, etc.)
Notes:
  1. Power the device off.
  2. Press and hold the Volume Up button and then briefly press the Power button to power on the device.
  3. Release the Volume Up button and the Power button when the Samsung logo displays on the screen.
  4. Use the Volume Up button to select the small android with an arrow icon.
  5. Press the Volume down button.
  6. Use the Volume button to select Recovery Console then press the Power button.
  7. From the Recovery Console screen, use the Volume button to select Wipe Data / Factory Reset then press the Power button.
  8. Use the Volume button to select Yes then press the Power button.
  9. Once the Wipe Data / Factory Reset has completed, use the Volume button to select Reboot System Now then press the Power button.
    Allow several minutes for the factory data reset and reboot processes to complete.
    To set up the device after completing the factory data reset, refer to Initial Activation and Setup.
Related Topic: Factory Data Reset
Dec 20, 2017 | Galaxy Cell Phones
Tip
How to format a HTC desire
<span> <p>Warning : the following will erase everything on your phone, your settings, your data, etc!<br /> <p>The most convenient way to do a factory reset is via the phone settings.<br /> <ol> <li>From the Home screen, press MENU and then tap Settings.</li> <li>Scroll down the screen and then tap Privacy &gt; Factory data reset.</li> <li>On the Factory data reset screen, tap Reset phone, and then tap Erase everything.</li></ol> <p>Performing a factory reset using phone buttons<br /> <p>If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using the buttons on the phone.<br /> <ol> <li>With the phone turned off, press and hold the VOLUME DOWN button, and then briefly press the POWER button.</li> <li>Wait for the screen with the three Android images to appear, and then release the VOLUME DOWN button..</li> <li>Press VOLUME DOWN to select CLEAR STORAGE, and then press POWER.</li> <li>Press VOLUME UP to start the factory reset.</li></ol></span>
on Nov 24, 2010 | Cell Phones
How do i factory reset my verizon samsung 10 tablet?
To help you perform a factory reset if your Samsung tablet is working and powered ON, please follow the instructions mentioned below:
- It is recommended to back up all the data like Phone contacts, Email accounts, App settings and Downloaded apps, Music-Picture-Videos, Internet browsing data and Personal data from the tablet before performing factory reset.
- From the Home screen, navigate: Apps > Settings > Privacy.
- Click on 'Factory data reset'.
- Click on 'Reset tablet'.
- Click on 'Erase everything'.
- Allow several minutes for the factory data reset and reboot processes to complete.
Now, if in case you need to perform a factory reset if your Samsung tablet is powered OFF, please follow the instructions mentioned below:
- Press and hold the 'Volume Up button' and then briefly press the 'Power button' to power on the device.
- Release the 'Volume Up button' and the 'Power button' when the Samsung logo displays on the screen.
- Use the 'Volume Up button' to select the 'small android with an arrow' icon.
- Press the 'Volume down button'.
- From the Recovery Console screen, use the 'Volume button' to select 'Wipe Data / Factory Reset' then press the 'Power button'.
- Use the 'Volume button' to select 'Yes' then press the 'Power button'.
- Once the Wipe Data / Factory Reset has completed, use the 'Volume button' to select 'Reboot System Now' then press the 'Power button'.
GuruAid.com
May 24, 2016 | Samsung Tablets & eReaders
Forgot my password how do I reset it?
Press pwr button+vol up button at same time...
Choose factory reset 4m bios mode... then press power button for ok.
May 06, 2016 | Tablets & eReaders
I forgot security code to my HTC rezound beats audio phone
Performing a factory reset from settings
  1. From the Home screen, press MENU , and then tap Settings.
  2. Tap Storage > Factory data reset.
  3. Tap Reset phone, and then tap Erase everything.
Performing a factory reset using hardware buttons
If you can't turn HTC Rezound with Beats Audio on or access settings, you can still perform a factory reset by using the hardware buttons on HTC Rezound with Beats Audio.
  1. Remove the battery, wait for a few seconds, then reinsert the battery.
  2. Press and hold the VOLUME DOWN button, and then press and hold the POWER/LOCK button.
  3. Wait for the screen with the three Android images to appear, and then release the POWER/LOCK and VOLUME DOWN buttons.
  4. Press VOLUME DOWN to select FACTORY RESET, and then press the POWER/LOCK button.
Resetting HTC Rezound with Beats Audio
Apr 03, 2015 | HTC Cell Phones
How to do a reset for irulu 9 inch tablet?
In order to factory reset your device you will simply need to perform the following steps directly in order to reset your device.
1. Turn your device off
2. Press and hold the volume up button
3. Press and hold the power button
4. Release these buttons
5. Use the volume up and down keys to highlight the factory reset option
6. Press the power button in order to select the option to factory reset your device
Nov 12, 2014 | Tablets & eReaders
Factory reset
Use Default Settings If you want to return the initial language setting such as Language, Video, Audio and etc. to the factory default, do the following: 1) Press SETUP button. 2) Press / button to select Misc. 3) Press button to select Use Default Settings, then press ENTER button. 4) Press / button to select "Yes", then press ENTER button. The original setting will be restored. Screen saver : On Do you want to use default setting? Note When you reset the DVD player to the factory default, the DVD player will take 3-5 seconds to reset.
Oct 15, 2014 | Toshiba SDK990 Player
How to restore HTC One V T320e smartphone
If you can't turn HTC One V on or access settings, you can still perform a factory reset by using the hardware buttons on HTC One V.
1. Press and hold the VOLUME DOWN button, and then press and hold the POWER button.
2. Wait for the screen with the three Android images to appear, and then release the POWER and VOLUME DOWN buttons.
3. Press VOLUME DOWN to select FACTORY RESET, and then press the POWER button.
[img title="unlock HTC ONE V hard reset forgotten password" alt="HTC ONE V hard reset" src="http://www.hard-reset.com/images/htc_one_v_hard_reset.jpg" height="350" width="180">
will remove any applications you've downloaded and installed. Be sure to back up
any data and files you want to keep before you do a factory reset.
1. Slide the Notifications panel open, and then tap Settings.
3. Tap Reset phone, and then tap Erase everything.Performing a factory reset via settings
The most convenient way to do a factory reset is via the settings.
1. From the Home screen, press MENU, and then tap Settings.
2. Tap SD & phone storage > Factory data reset.
HTC One V not responding?
If HTC One V frozen and does not respond when you touch the screen or press the buttons, you can still restart it by press and hold the POWER button for at least 10 seconds, and then release it. HTC One V then restarts.
Sep 26, 2013 | HTC One V T320e - 4gb - Grey Unlocked...
How to format HTC WILDFIRE A33333
Factory reset is not a step to be taken lightly. It will permanently delete all your data and customized settings, and will also remove any applications you've downloaded and installed. Be sure to back up any data and files you want to keep before you do a factory reset
Performing a factory reset via settings:
From the Home screen, press MENU, then tap Settings.
Scroll down the screen, and then tap Privacy > Factory data reset.
Performing a factory reset using phone buttons:
Press VOLUME DOWN to select CLEAR STORAGE, and then press POWER.Press VOLUME UP to start the factory reset.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Feb 25, 2011 | HTC Computers & Internet
My htc hd2 refuse to respond to my screen password, can you help me to do factory reset
  1. On the Home screen's Settings tab, tap Menu > All Settings > System > Clear Storage.
  2. Enter 1234.
  3. Tap YES to perform the reset, or tap NO to cancel the reset.
  1. With your phone powered off, press and hold the VOLUME UP and VOLUME DOWN buttons.
  2. While holding the volume buttons, press the END/POWER button briefly and then release it.
  3. When you see a warning message on screen, release the VOLUME UP and VOLUME DOWN buttons.
  4. Press the VOLUME UP button to perform the reset, or press any other button to cancel the reset.
By the way, do remember to backup your data first before hard reset
Feb 12, 2011 | Cell Phones
LG BD650 BluRay Player Logo
29 people viewed this question
Computer Repairing
Computer Repairing
