Question about Dell Dimension 3100 PC Desktop
Dell dimension 9150 beeps - Dell Dimension 3100 PC Desktop
    New Friend:
  • 4 Answers
Got some Dell Manual,check these manual for your problem http://www.manualbirds.com/brands/free-dell-manuals
Posted on Nov 13, 2015
  • 155 Answers
SOURCE: No 9 pin video socket
Most video cards use a 15 pin VGA connector.
There is also a 9 pin VGA connector, but they are a lot less common - I'm guessing this is what you have.
Is the video cable hard-wired into your monitor or is it connected via a plug? If it's a plug, is that a 15 or 9 pin? If it's a 15 pin, then all you need to do is buy a new 15-15pin VGA cable.
If it's hard-wired, you'll need to buy some sort of adapter. These are available and don't cost much either, but you might need to try a more specialist computer store to find one.
Hope this helps!
Matt
Posted on Feb 29, 2008
ghassun
  • 499 Answers
SOURCE: I have a Dell Dimension 9150 and i did a restore
check the update control from control panel
Posted on Jun 08, 2009
  • 15 Answers
SOURCE: dell dvd and cd wont read some cd's
Since it can read some disks them something as simple as cleaning the lens and/or the disks would be a great place to start. You can also check your connections inside, be sure the IDE cable is secure. If that dose not fix it I would replace the drive. There cheap and go bad.
Posted on Oct 07, 2009
RescueTechLA
  • 2653 Answers
SOURCE: Error when starting Dell Dimension 9150 desktop
Try re-seating the memory and / or the video card.
Posted on Nov 20, 2009
  • 37 Answers
go to www.dell.com and check for a bios update if one is not present contact support and tell them your problem
Posted on Jun 01, 2010
Good video, no sound with my dell dimension 9150
You can try to get the drivers off of your CD or you can download the drivers from here:
http://www.dell.com/support/drivers/us/en/19
1. Just choose "Select A Different Product"
2. Then choose "No, Choose from a list of all Dell products" and
select "continue"
3. Then select "Desktops"
4. Then select "Dimension"
5. Then select "Dimension 9150/XPS 400"
6. Now just scroll down and pick the drivers you need.
Don't forget to install your chipset and network drivers as well.
Jun 04, 2012 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Dell Demension 9150. I push the button to turn it on and it just beeps. I tried it several time and had the same result. Any ideas on how to fix it? I do not have hardware experience. Thanks
if you the beeps are long, means that you need to replace the memory module. if it is a short beep, and your monitor is black:
  1. remove the video cable if your monitor display 'No signal' so the problem is in the central unit.
  2. if the monitor does not display 'No signal' so the problem is in the monitor you have to replace it.
Dec 21, 2010 | Dell Dimension 9150 (DIM915MIN) PC Desktop
I can't find Ethernet Controler for Dimension 9150 Service Tag DB22PY81
You can find all drivers for your 9150 here.
The Intel driver for your built-in network card depends on your OS (WinXP or Vista).
(Your service tag might be outdated, so it doesn't work.)
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Oct 27, 2010 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Error when starting Dell Dimension 9150 desktop PC: X300XT BIOS P/N 113-A33437-102
May 31, 2010 | Dell Dimension 9150 (DIM915MIN) PC Desktop
I have a dell Dimension 8250 and replaced the memory cards with a higher memory. I got a memory error beep code so I replaced the original. I'm still getting the beep code. Any ideas? I was careful...
Please check the following link for complete information on Dimension 8250
http://support.dell.com/support/edocs/systems/dim8250/
Check the technical specification section to see if u bought the correct memory type for this computer to upgrade..if yes then proceed to the adding and replacing parts section to check for the instructions on adding memory.
Jun 27, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Lights 3 &4 stay on.
Computer beeping at you is usually a problem with the video card or memory. Try re-seating both and see if you still have the same problem. If you do, individually remove each component and power on to test if the beeps persist.
Jan 06, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Dell Dimension 3100 PC Desktop Logo
64 people viewed this question
Alun Cox
