Question about Refrigerators
Trying to find how to unlock the wheels on my Maytag refrigerator.
How to release wheels on maytag fridge freezer
What is the model number of that Maytag refrigerator?
Appliance 911 Sea Breeze
Aug 31, 2016 | Maytag Refrigerators
How do i use the wheels on my maytag refrigerator model MBF2256HEW. They don't seem to lock in a down postion to roll
You probably need to turn the front leveling feet in so that they are higher than the wheels.
Jul 25, 2015 | Maytag Refrigerators
Maytag side by side refrigerator - refrigerator and freezer both not cooling.
I had same issue , required a new compressor and regas. All cooling for fridge side is blown in from freezer
Jan 25, 2013 | Maytag Refrigerators
How to turn off lock on maytag refrigerator #mzd2766gew
To unlock the indoor ice and water dispenser push the button with the key image 3 times within 10 seconds and it should be unlocked...if later on ya want to lock it again also push that button 3 times within 10 seconds.
Sep 17, 2011 | Maytag MZD2766GES Side by Side...
We are trying to replace the ice maker filter on a Maytag mf2557hes. Where is it located? Does this Maytag Refrigerator have a filter?
Maytag brand water filter removal and replacement:
refrigerator_maytag-filter.jpg Removing and replacing a water filter
There are two different types of Maytag brand water filters. Each one is removed in a different manner, depending entirely on where it is located in your refrigerator. There are two main locations. Select your filter location from the options below for specific removal and replacement directions.
  1. The upper right corner of the refrigerator compartment.
  2. In the center of the ceiling of the refrigerator compartment.
Jun 12, 2011 | Maytag MFF2557HES Stainless Steel French...
My maytag refrigerator has wheels both back and front. The front wheels are bigger and the back wheels are smaller and they have screws holding them. The back of the refrigerator is a little lower than...
Look behind the grille in the front bottom of the fridge... there are adjusting bolts there to adjsut the height of the front and back wheels to level it...
heatman101
Aug 26, 2010 | Maytag MFD2560HES Bottom Freezer French...
How to level a maytag plus side by side refridgerator I got the front wheels level, but the back right wheel is not coming down and the whole unit can tilt to the back right. How do I get the back right...
There is a bolt in the middle of the bracket that holds the wheel that you turn. When you tighten the bolt it pushes on the the wheel bracket and it goes down, bringing the fridge up. Loosen, it goes up bringing the fridge down.
Nov 27, 2009 | Maytag MSD2756G Side by Side Refrigerator
Turn off the change filter light on maytag refrigerator
For my Maytag Refrigerator Model # MSD 2756 GE, I had to hold the "Light" & "Lock/Unlock" buttons simultaneously until the "Change Filter" light went off instead of the "Water" & "Lock/Unlock" buttons.
Oct 09, 2009 | Maytag MSD2651 HE Side by Side...
Can't unlock ice water depenser on maytag side by side
On most brands all you have to do is hold the lock button until it unlocks.
Jun 10, 2009 | Maytag MSD2756G Side by Side Refrigerator
Can't unlock my ice dispenser
press the lock button three times in a row
Feb 10, 2009 | Maytag MSD2756G Side by Side Refrigerator
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
