Question about Samsung SyncMaster 245BW Monitor
Samsung 245bw capacitors are good but still blank screen
3 Suggested Answers
prashanthcl
  • 460 Answers
SOURCE: samsung syncmaster 245bw menu buttons don't work
It is a hardware problem. you can repaired it from service center.
Posted on Nov 13, 2009
budmrtn
  • 11361 Answers
SOURCE: Samsung syncmaster 245bw is black
You need to check and see if you are getting the 24vdc feeding the backlights inverter board, also check the fuse on the inverter. Does the backlights flash on for a second at all?
http://s807.photobucket.com/albums/yy352/budm/SAMSUNG/Samsung%20245BW/
Please read my guide to understand how the monitor works.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Aug 31, 2011
No screen power up
There are one or two open capacitors in the power supply, they often have a bulge at top due to leakage.
May 07, 2012 | Samsung SyncMaster 245BW Monitor
Samsung syncmaster 245bw is black screen. Open the monitor and no bulged capacitors.
Aug 30, 2011 | Samsung SyncMaster 245BW Monitor
Samsung SyncMaster 245BW - no image - screen flickered once or twice and then went dark. Reconnected cables, tried different cables - all with same result - no picture. Any usggestions?
It may ahave 24vdc power supply problem due to bad caps, ect, or bad backlights inverter board, worst case will be the lamp assemblies. It will require in-depth troubleshooting.
Please see my pictures here:
Please read my guide if you are going to DIY repair.
Aug 25, 2011 | Samsung SyncMaster 245BW Monitor
Samsung Syncmaster 245BW displays no image. Unit receives power and the blue LED on the power button is lit but the screen is not illuminated. I can't tell if the pixels are changing at all, but there...
laqbot7000, If you have opened unit, what is the brand name of capacitors (electrolytic's) printed on them. CapXon, Elite, Jun-Fu, are some you don't want to find on the smps board. Are any of the rubber seals pushed out of the bottoms of any capacitors? Is fuse still ok? Did you use a magnifying glass or low power "inspection" microscope(5x - 20x) to possibly find any "thinner than hair" fractured solder connections to component leads soldered to the copper foil circuit traces?? Also "visual" the black bodies of all solid state (transistors, bipolar, mosfet) devices for "burns" and "distortion" from overheating. 12fixlouie
Sep 21, 2010 | Samsung SyncMaster 245BW Monitor
My Samsung Syncmaster 245bw LCD displays a blank screen.
wardysbiz, I should think SAMSUNG would ship you a replacement unit. It might be what is called a REFURBISHED unit of same model.
In future try not to use the word BROKEN. I thought an elephant stepped on it, or it fell from a great height. Try "nonfunctional" or "inoperative", "has failed" , "never worked" "out of box failure" "Dead on arrival unit" Also contact NEWEGG and ask lots of questions about quality and reliabilty of lcd monitors. Find Your sales receipt or card statement to prove pop. Don't let them off the hook!! I would think turn-around process to be about 14-20 days. 12fixlouie
Dec 10, 2009 | Samsung SyncMaster 245BW Monitor
My syncmaster 245 bw will only display a blank screen through the dvi port. Another crt monitor works fine through the vga port . I'm running a nVidia 7800 GS video card.
You need to adjust the monitor refresh rate to 60 Hertz or 70 Hertz.
Use the CRT first to adjust it, then after adjust,plug in your Sync Master to see is it perfect or not,find the best frequency that work best.
To adjust it,right click on the screen,enter properties, then click setting tab.
Then in advanced tab, click it then you see the monitor tab, find the perfect screen refresh rate.
Samsung syncmaster 245bw menu buttons don't work
Nov 13, 2009 | Samsung SyncMaster 245BW Monitor
Blank (dark) notebook screen after hooking up digital ext monitor
I notice a difference in the setup of the two monitors, have you installed the correct driver for the new screen?
Try F8 on startup to get into safe mode, this should allow you to use the default VGA screen, and to reset the correct monitor drivers.
Dec 08, 2008 | Sony VAIO VGN-A790 Notebook
245BW monitor not working (stranges colors ad aeternam...)
I had the same problems as almost all of these people and the answer seems to be that I uninstall the current Nvidia Drivers and use a previous set. The 169.28 were a real problem for me. Just when I thought it was working I would get the strange wash out and I could not turn it off except with the back power switch, aslo using the DVI turns off all the on screen controls.
Good Luck
Dec 27, 2007 | Samsung SyncMaster 245BW Monitor
Samsung 245B
Call Samsung. The unit sounds faulty.
Dec 14, 2007 | Samsung SyncMaster 245BW Monitor
Samsung SyncMaster 245BW Monitor Logo
91 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
