Question about Sony Bravia KDL-40S4100 40 in. LCD TV
Kdl 40s5100 sony bravia 2009 shadows and lines across screen
Only the first 5 min or so
  • 20 Answers
SOURCE: I have a Sony Bravia KDL-46Z4100 46' I have a green vertical line
this is probly the lcd control module unfortunatley it comes with a new lcd panel
change these.
Posted on Mar 11, 2009
SOURCE: Picture problem
raystratton
I was wondering if you were able to solve this issue. i am having the same exact issue with my tv. and i did not get an extended warranty thinking that nothing would go wrong with a sony tv. i learny my lesson the hard way. Can you please tell me what the tech told you or what you did to fix this problem. All your help will be greatly appreciated. Thanks once again!!!
Posted on Jul 23, 2009
tvtek
  • 1284 Answers
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Posted on Dec 02, 2009
SOURCE: Sony BRAVIA KDL-46XBR 46 in. HDTV LCD
I hope this helps
It seems Sony is extending the warranty on your TV
http://esupport.sony.com/US/perl/news-item.pl?news_id=378&template_id=1
IF YOU FOUND MY SOLUTION HELPFUL PLEASE VOTE 4 THUMBS UP.
(any less hurts our averages)
Thank and Good Luck!
Posted on Feb 04, 2010
SOURCE: sony bravia kdl 46s4100 no picture
it sounds like your back light might be going out. You might be able to fix this by installing a new backlight inverter board.
Posted on Aug 05, 2010
Sony kdl 55xbr8 vertical lines
Check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 02, 2014 | Sony BRAVIA KDL-55XBR8 55 in. HDTV LCD TV
Sony 40 inch Bravia screen has sound, but picture have weird lines that go across screen
It could be caused by a bad T-Con board or defective LCD panel. The panel is more expensive than the TV, so hope that it is the T-Con board. Below is a parts list for your TV model.
http://www.tristatemodule.com/t-Search.aspx?q=KDL-40S2010
Nov 03, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
My sony bravia 32" is
hi ;
there's a problem in screen driver of your LCD, if you lost your receipt,that's bad luck.
if you know how to disassemble the back case of the TV , you can try some RESETTING of connectors from LCD screen driver to display driver board
its only 50% chance to remove the line.
thanks.....
Sep 11, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
What type of audio connection is needed to connect headphones to the Sony Bravia, model KDL-40S5100
The problem wiht this TV is that it does not have headphone output jack (spec: http://www.reviewed.com/product/Sony/Bravia-KDL-40S5100/specs.htm)
You will have to use:
1) AUDIO line out jacks (RCA RED and WHITE JACKS) of the TV connected to small headphone amplifier to drive your headphone.
2) you will have to trun off the TV built-in speakers using on screen audio set up.
3) Set the TV audio line out to be VARIABLE instead of FIXED level if you want to use the remote control to control the level of the audio output feeding the headphone amplifier.
As you can see, it is real simple setup.
Example of headphone amp;
http://www.radioshack.com/product/index.jsp?productId=2732095&CAWELAID=107598976
Same one at AMAZON: http://www.amazon.com/Upbeat-Audio-T613-BNC-Boostaroo-Application/dp/B000EIWCFE/ref=pd_sxp_grid_pt_1_0
Notes: you will need RCA plugs to mini-stereo phone jack adapter since this unit does not have RCA INPUT JACKS.
Please leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jan 12, 2011 | Sony Televison & Video
I have a Sony Bravia KDL-40s5100 and the screen is now red and dark and seems to be in almost slow motion. My warranty is up by 28 days and Sony will not honor the repair and told me it was my cost. From...
This problem can be caused by bad connections on the LVDS cable (the signal cable from the main pcb to the display control pcb.), sometimes cleaning the control pcb socket/cable plug can cure this. Other possibilities are: the display control PCB, or more probably, the display itself.
Jan 03, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Have horizontal lines across the screen and some
Yeah we have the same exact problem here. Defective TV....ours would correct itself after 30 mins, but now it's blurry all the time. I'm never dropping 2K on a SONY tv again.
Aug 01, 2010 | Sony Bravia KDL-46VL130 TV
Im trying o connect my dell inspiron 6400 to a Bravia LCD KDL-40S5100 and the screen shows that there is no signal with the computer, even though the cable is properly connected. I have another DELL PC...
The difference between the 5100 and the 6400 is the video card inside. The 5100 has an ATI videoand the 6400 has Intel graphics.
Try going to the Intel site to download new drivers for the Intel graphics. There is a driver checker on their website.
Mar 20, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony BRAVIA KDL-46XBR 46 in. HDTV LCD Television. I have a problem when the unit is switched on. The screen has 2/3 lines running across it. The picture stays like it for about 10 mins then goes back to...
I hope this helps
Jan 19, 2010 | Sony BRAVIA KDL-46XBR2 46 in. LCD HDTV
Lines across tv
try cleaning T-CON Board to Lcd panel cable
Jul 23, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Sony Bravia KDL-40S4100 40 in. LCD TV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
