Question about Empire Heating & Cooling
No main gas suplie - Empire Heating & Cooling
STR3BR1065 NOT WORK POWER SUPLY IS DEAD
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Aug 19, 2014 | Televison & Video
My akai lcd 32.5" tv will not stay on and all it does is flash the blue screen with akai then turns right back off and i was thinking power suply might be bad. what could it be?
You could be right it sound like the power suply, has it got a AC adaptor power suply,bit like a laptop charger? goes from mains to a black box then from box to the TV?
does it stay on at all?
Oct 01, 2010 | Akai LCT3285TA 32 in. LCD Television
Fans on both indoor and outdoor units are running but compressor wont restart, even after turning power on and turning back on. also, if compressor resets and runs, it'll run for a few minutes then trips...
the compresor have delay protection and this wil not alow compresor to run only after few minits (turn off the unit and disconect from the main power suply, wait 30 minits and after that turnit on) or the refrigerant gas in the plant missing. in this case you must call specializated personel to find the leack and fixit, after that they wil refil whit refrigerant gas (r404, r 134, or what your unit have)
Feb 14, 2010 | Heating & Cooling
No sound or vision set tripping power supply ?
no, you need the main board
if the tv turn on you need the main board if your
tv do not turn on you need the power suply
Aug 13, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Clarke en 130 parts
If you are just looking for consumables you can get parts online at
www.welding-direct.com/fistmiggunre.html
May 08, 2009 | Clarke Power Products Clarke 130EN...
I Need a power suply
These units don't have a separate "power suppy" per se. There is a power transformer and a separate board that contains the standby power supply components. The main power supply components are on the main board.
Rather than looking for a "power supply", what is the problem with the unit? Is there a standby light?
Dan
Mar 13, 2009 | Sony Audio Players & Recorders
No power, suspect main board problem.
change your SMPS alsomcheck your main power suply and earthing problem.
Oct 25, 2008 | Compaq Computers & Internet
Cold water suply filling up header tank in loft thru hot water suply on shower.
hi did you run a seperate cold water supply from the storage tank to the shower pump & also a seperate hot supply from the hot water cylinder, it sounds as though the cold water is crossing into the hot service & pushing its way up to the tank as its the only way it can go, sounds as though the cold water connection to the shower is not tank fed & possibly directly off the water main.?
Oct 05, 2008 | Home
My Worcester Greenstar HE boiler is showing an error sign (EA) and I dont have the manual for it. The system has not been turned on for over a year.
i have the same boiler and this code refers to gays suply error, i would suggest a engineer to yake a look at it but first check if ur gas suply is ON ...!
Sep 24, 2008 | Heating & Cooling
Heating & Cooling Logo
16 people viewed this question
Top Empire Heating & Cooling Experts
paulcarew
rudyjoe
Level 1 Expert
Dan Webster
Dan Webster
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
