Question about Sole Fitness Exercise & Fitness
Sole treadmill makes noise
Noise only when running, on each foot strike it makes a noise like its rubbing
SOURCE: my treadmill makes noise every 30 seconds when
We took it apart and cleaned it :-)
Posted on Jan 29, 2010
ercupa190
  • 12223 Answers
SOURCE: my epic 425 mx treadmill belt hesitates and rubs
Dear Sir:
I will try to help you.
http://www.youtube.com/watch?v=CuMjcPLYehw&feature=related
http://www.youtube.com/watch?v=E5aWisfhT3Q&feature=related
http://www.youtube.com/watch?v=38w4PkiWIBY&feature=related
http://www.youtube.com/watch?NR=1&v=KiEZDNe0F8Q
http://www.youtube.com/watch?v=HmVt-SHSYAI&feature=related
With this you will fix it.
If you need further assistance, please reach me.sincerely. God bless you
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Posted on Oct 24, 2011
ercupa190
  • 12223 Answers
SOURCE: treadmill deck squeaking on left hand side
please do the following:
1) LUBE the deck belt , this happen because the lack of maintenance schedule.+adjust it each side see the diagram,worn deck probably.
2) Lube the rollers bearing too
3) test the motor for bearing need repair
4) test the drive belt for broken or worn.
5) test the puller for drive motor,can be worn, and replace.
God bless you
Posted on Jul 18, 2012
Testimonial: "Thanks so much - seemed to do the trick!"
ercupa190
  • 12223 Answers
SOURCE: my sole treadmil makes noise when changing levels
1) Lube the deck belt, very well, maybe you have WORN deck belt, time to replace, this happen because the lack of maintenance schedule.
2) LUBE the roller bearing TOO.
3) Measure the input voltage motor, if there are voltage , the motor NEED repair.
God bless you
Posted on Oct 15, 2012
ercupa190
  • 12223 Answers
SOURCE: treadmill makes loud grinding sound when I run in the middle of the tread. it doesn't make the noise if I run on the left side.
1)you must LUBE the DECK BELT, inmediately, for to avoid the friction
2)LUBE the rollers bearing.too
3) See the main motor for bearing and repair the motor for bearint too.
4) If the problem persist you have worn deck belt, and replace.
God bless you
Posted on Nov 07, 2012
Sole elliptical e55 makes thumping noise
If you wish to get some details about elliptical and treadmill ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Aug 28, 2016 | Sole Fitness Sole E55 Elliptical
Belt slipping
This is a common issue. Over time the belt stretches. You will need to adjust the tension on the running belt to alleviate this issue. If there is no adjustment room left, then you will need to replace your running belt and deck surface. The link below will take you to the products for your machine. Please use your serial number to narrow down your choices.
Precor Repair Parts for 9 27 Treadmills Consumer SPORTSMITH net
Jan 04, 2014 | Precor 9.27 Treadmill
The belt is slipping
Why did I suddenly lose resistance and smell burning on my sole e55 elliptical?
proceed according. iF THE problem persis after you LUBEt, TIME to replace the old board deck belt.God bless you
Apr 04, 2013 | Sole Fitness Sole E55 Elliptical
My sole treadmil makes noise when changing levels
God bless you
Oct 14, 2012 | RTO Sole F80 Treadmill
While running on the treadmill there is loud noise
Probablt don't need a new belt. You need to isolate noise. Listen and look for any signs of rubbing in the area that noise is comming from.
Jul 27, 2009 | Stamina Products InMotion Treadmill
Tread is sliding and rubbing agianst right side of track.
Make sure treadmill is running when you adjust belt. The treadmill belt tracks as the belt goes around. I usually put machine on 2-2.5 if belt is not rubbing instantly. If belt is already against plastic, turn adj. counterclockwise on the opposite side about one full turn. You can usually move belt with your foot to see if it aligns any with turning on the treadmill. Once belt is not rubbing, turn treadmill on and continue alighing the belt.
Jul 20, 2009 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
37 people viewed this question
Top Sole Fitness Exercise & Fitness Experts
Art Wilson
Art Wilson
Level 1 Expert
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Are you a Sole Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
