Question about Photography
Avi problem with the Digital Picture Frames Philips SPF2017
Donladed music from computer but will not play on frame
I had the same problem. Certain digital frames will only play certain music files. The one I had would only play mpeg4 & avi files for music. If its not noted in the instructions, serach by the make & model of your digital frame.
Jul 29, 2014 | Photography
Cannot play videos on my fujifilm dp-8v
Just cnvert them to the right format. What I'm using is kigo video converter ultimate for mac, it works well for me.
Apr 07, 2013 | Photography
I uploaded vidoes in .avi format. It appears in my internal memory. But it wont play. How can i fix this???
The PANDIGITAL supported format ia AVI,U can not play one on it that may be something wrong with the size of the video.
you can use a video converter to choose the size features for PANDIGITAL.
Nov 27, 2011 | PANDIGITAL 8.0" Digital Photo Frame...
Vtech kidizoom pro which Videoformat is required? I try to upload some Video files into the /DOWNLOAD/VIDEO Folder but the machine didn't find them. what can I do? I converted into *.avi, mjpeg 320x240...
the avi video on vtech are of low resolution ( see image with tech details)_39.png
so convert your video's (flv, mov, mpeg, mp4, ...) to this format with the tool "pazero coverters suite" (free tool with no nasty malware) I use the stereo, 30 frames/sec parameters, it works fine ! (see image with parameters
Mar 01, 2011 | Vtech Kidizoom Digital Camera
I upload video in the avi mode in the memory of my photo frame. When trying to play it the frame shows the icon with the name of the video name.avi (that is the video is in the memory) but on the icon is...
digital photo frames are not usually able to play videos...
however if the frame has this capacity, it sounds like you have an encoding issue, you should check which codecs (encoding decoding) are compatible with your "frame" and change the configuration of your video encoding/recording system to use a compatible codec
Jun 19, 2010 | PANDIGITAL (DPF802) Digital Picture Frame
Saved movies to my sd card but doesn't saw them as being on the card went it put it my frame
I tried .avi files and it also wouldn't play them.
It is picky on the format of the original movie file.
fred
Dec 10, 2009 | PANDIGITAL (DPF802) Digital Picture Frame
My Kodak M820 8
yes avi should play on that.. but i think that kind of device(frame) is like some of the mp4s that includes avi in the features but will have problems playing avi type of files.... ... i dunno if this is useful coz i dont think i have the answers to correct it... maybe u can just convert the files in other filetype that your frame can read....
i read this from wikipedia
The AVI container has no native support for modern MPEG-4 features like B-Frames. Hacks are sometimes used to enable modern MPEG-4 features and subtitles, however, this is the source of playback incompatibilities.
AVI files do not contain pixel aspect ratio information. Microsoft confirms that "many players, including Windows Media Player, render all AVI files with square pixels. Therefore, the frame appears stretched or squeezed horizontally when the file is played back."[1] There are other video container formats that allow irregular shaped pixels.
More modern container formats (such as QuickTime, Matroska, Ogg and MP4) offer more flexibility, however, projects based on the FFmpeg project, including ffdshow, MPlayer, xine, and VLC media player, have solved most problems with viewing AVI format video files.
pls do update me if you've resolve the problem
Sep 13, 2009 | Kodak Digital Picture Frame
Not supported message for video files
The problem is usually that the video has the wrong codec and the codec is unsupported by the picture frame. The frame rate won't have any effect.
You can try converting the avi to use another codec or to another format such as mpeg. Unfortunetly I can't find the codec to use. I looked on the Smartparts support for you as well and they don't show it.
You might need to call them to get that information. All they said on the website was that the information was in the manual. Looked there too and it just says avi.
http://www.smartpartsproducts.com/content/aboutus/contactus/index.php
That will get you to he toll free number and other support numbers.
Sorry not much help but should get you in the right direction to get it working.
Jul 21, 2009 | SmartParts SPX8 Digital Picture Frame
Cant run converted video
try using a different converter software. Usualy dvd's without div X have problems with AVI. but try converting them to WMA
Mar 30, 2009 | Kodak EasyShare 8" LCD Wi-Fi Digital Photo...
Photography Logo
23 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
