Question about Konica Minolta bizhub 350 All-In-One Laser Printer
When a letter is folded the printed image transfers creating a double image
  • Konica Minolta Master
  • 6,696 Answers
Mean the toner is not fusing to the paper replace the fuser unit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jan 24, 2016
How do I transfer my iPad photos to my computer
I prefer using iMyFone TunesMate iPad Transfer, it is so fast to export my photos from iPad to computer. Once I transferred about 30 thousands iPhone photos to my pc, it only took two mins to finish the transfer. Very impressed with this!
Feb 19, 2015 | Apple iPad 32 GB WiFi Tablet PC
My canon irc 5185 double image in black images. any advice
Print Black images with any color piece (ex. page with black text and one red letter in up-right corner) 40-50 pages in one job.
Are you see a double black image?
No: Fuser trouble on high-speed.
Yes: Replace the Drum Unit (Black).
Sep 10, 2013 | Canon irc5185i
Horizontal print gaps on ml184+
The most common cause of missing sections in the letters is a bad print head. These types of printers (Dot Matrix) create the print with the print head which has a line of small pins called hammers that are activated by an electromagnet. Each pin has its own hammer. If the electromagnet fails or you have something jamming the hammer then it will not move to strike the ribbon and make the image or letter. You can get a replacement print head online for about $15.00, the part number is 50063802. Here is a picture of what the print head looks like. :
Dec 30, 2011 | OKI MICROLINE 184 Turbo Matrix Printer
I have a Xerox Phaser 6100. I just replaced the imaging unit and the transfer belt. Now my copies are coming out with lines across the whole page. one page that I printed came out wiht all colored lines...
Try doing a "stop test." Stop the print process at various stages, and see if which component creates the defect.
For instance, if a print takes 20 seconds, during the first 10 seconds, the drum is generating the image to transfer to the belt. If the image is bad on the drum, then that is your culprit. If not, then see which unit creates the problem.
Also, what color is the line?
After the unit gets to the transfer belt, you should check the transfer roller and fuser.
Whit www.iteminconline.com
Jun 07, 2011 | Samsung CLX-3175FN Printer
I have a hp color lj2600 that is creating double image on printouts. but if i printout a cleaning page it begins to reduce the double imaging. can the fuser cause this type of problem?
It may be the fuser, but if it is really it, then you should be able to notice some spots/lines that are there all the time, no matter what you print. I'd go for a magnetized corona, that fails to demagnetize the transfer roller.
Open up the printer, get to the print assembly and try demagnetizing the transfer corona (there should be a plastic bezel that slides along the rollers), or if nothing else then get some aluminum foil wrap it alongside the roller and touch the foil onto a metal part of the printer, to get it to ground the electric potential buildup.
Or it could also be the brushes that scrub the transfer roller clean from the residue toner. See if the excess toner tank is full. If it is full then it's the corona. If it's not full and you can see toner dust all over the printer then it's the brushes that fail to scrub off the toner in time.
Either case, you may be looking at a new print assembly purchase real soon.
Jan 17, 2011 | HP Color LaserJet 2600n Printer
The printing on some letters smudges
Hello sir; Try to print out one page, use you finger to rease it ,is the image come off ? if answer yes, replace fusing unit.
Jan 08, 2009 | HP LaserJet 1020 Printer
Hp color laserjet 1600 copies have a blurred image
This sounds like a registration problem.
Use the menu (on the printer) to print antest page AND a configuration/information page.
Look (critically) at the alignment of the seperate coloure Yellow Magenta Cyan. You will probably find that these are out of aligmnent across the page.
The cause of this, is that the printer can't perform a calibration properly (printer probably takes a long time when calibrating too) and is usually down to failure of one of the sensors on the transfer belt.
Sometimes you can clean these and solve the problem, but often is a failure of the component itself. Thes are NOT available as a spare part, and the repair to correct this would need a replacement transfer belt.
Transfer belt replacement in this printer is quite an involved task, though it is within the capabilities of someone with reasonable mechanical aptitude.
Nov 24, 2008 | HP LaserJet 1600 Printer
Laser printer not printing properly left side of page is very light, right side is normal, have tried redistributing toner and changing toner cartridge
Since you have changed the tone cartridges ...and it still does the same....
the next step is to check the transfer belt..transfer roller(this when hit by laser light stores the image and runs on the powder ink..the parts that have been created by the laser on the transfer belt is where the powder sticks)......remover the transfer belt roller and check to verify that its not worn out..its in the form of plastic paper more like Teflon.....view to see that it doesn't have severe markings...if its marked you will need to change the transfer belt to
If this doesn't fix the problem than you will need to change the laser scanner unit....
so basically its your cartridge...that provides color powder dust for image....
transferbelt...that transfers the image to the paper with the image being created by the laser scanner and the cartridge providing color
the last process is fussing ...heat is used to make stick the powder to the paper..and is done by the fusser unit...
as for your case the image is not either created by the scanner itself in the right manner..or the image is not properly created coz the transfer belt is worn out....
I suggest you replace the transfer belt next.
cheers!
Nov 10, 2008 | Office Equipment & Supplies
Print quality is very poor
I used to use an LX300 and have never had this problem. I'm not sure what unclear means so I will just do some guessing. Clarity of the print depends on 3 things, software, printhead and ribbon. These are your problem areas. Epson has an option to print NLQ or near letter quality. So that should give more clarify. I basically double prints the same letter to create a darker image. The printhead, if your printer is really old, you need to either find someone to refurbish the printhead or buy a new printhead because it could be the impact pins are bent and not giving the strongest image. Lastly the ribbon, obvsiously the more used the ribbon is the weaker the image. So either re-ink the ribbon or buy a new ribbon cartridge. Hope this helps.
Aug 05, 2008 | Epson Dot Matrix LX-300+ II Printer
Okidata c3200 - "needs new drums" message
Check your page count, drum life on a C3200 is roughly 15000 pages. This information can be found on the information menu map.
Information Menu ecblank.gif ecblank.gif dot.gif ecblank.gif Menu Item Default Setting PRINT MENU MAP EXECUTE Prints the MenuMap (menu listing) with current settings shown. Information about your printer is also
shown at the top of each MenuMap page.
Life Expectancy ecblank.gif ecblank.gif dot.gif ecblank.gifToner Cartridge
Life expectancy approximately 1,500 pages, assuming about 5% coverage, which means that 5% of the addressable dots in an image are printed with this color of toner. See Toner Cartridge..
Image Drum
Life expectancy approximately 15,000 pages, assuming an average of 3 pages per print job. If the average print job is longer than this, the image drums could last longer, but if the average print job is shorter, then image drums will be used more quickly. See Image Drum.
Transfer Belt
Life expectancy about 50,000 letter-size pages. See Transfer Belt.
Fuser
Life expectancy about 45,000 letter-size pages. See Fuser.
Feb 11, 2008 | OKI C3200n Led Printer
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
21 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
