Question about Kettler Rowing Machine Kadett Rowing Machine
Display not resetting on bodysculptor 3050 - Kettler Rowing Machine Kadett Rowing Machine
How do i reset hp deskjet 3050 j61
To do a soft reset
1. Press MENU
2. Simultaneously press and then release the * button and the # button
3. Press the < or > until the message REINIT FFS appears on the 2nd line of the display
4. Press "Check mark"
5. The process will take about 2.5 minutes. The control panel display will change a few times before coming READY.
6. When READY appears press CANCEL
Dec 08, 2014 | HP Deskjet 3050 All-in-One Printer CH376A...
Manual for toner bmi 501
www.bodysculptor.com
I believe the above company may have manufactured it.
Jun 17, 2014 | RTO Power Plate my5 Vibration Training...
HP laserjet 3050-Not able to print and only display is load tray 1 which is already loaded. Try to reset many times. Didn't work.....
There are sensors in a printer and it sounds like the sensor is not recognized. You can place the printer in service mode and test the trays and all hardware components for exact cause. This is a common error.
Oct 20, 2011 | HP LaserJet 3050 All-In-One Printer
Cold reset of hp laserjet 3050
Turn off the printer press and hold 5 & * switch on the printer when permanent storage inti displayed on screen release the buttons,wait till ready mode comes.
Sep 12, 2011 | HP LaserJet 3050 All-In-One Printer
Accidently set the printer HP deskjet 3050 to wrong language how do i reset?
The way was hidden somewhere in the HP solution center:
1. Press the cancel and power buttons at the same time, while the printer is on.
2. Press the blue, green and gray buttons (in this order)
3. Change the menu options with grey button until you get to the "Resets" menu.
4. Press OK. "Country and Language reset" displays.
5. Press and hold OK for approx 2 seconds, then release. The printer will turn off.
6. Start the printer again - it should ask you to select language.
May 05, 2011 | HP LaserJet 3050 All-In-One Printer
Hi, I have bought HP Deskjet 3050 all in one printer and it's not in English how can i change the language display? Thankyou.
You will need to perform a reset on the machine.
1. Turn off the all-in-one.
2. Press and hold down the * and buttons.
3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout
the entire power-on sequence.
4. When Permanent Storage Init. appears on the control-panel display, release the buttons.
5. Allow the all-in-one to return to Ready before using it.
Once it resets it will prompt you to set the language, use the arrow keys to select English and then press the checkmark. Unit will restart in English mode.
Mar 11, 2011 | HP LaserJet 3050 All-In-One Printer
I want to cold reset my hp deskjet 3050 all in one J610 series so I can get my printer off Japanese and into english on the menu display. Can you help me with this?
After following these steps the printer should ask for language when it restarts. Keep in mind you will lose all other settings you may have put in.
Feb 21, 2011 | HP LaserJet 3050 All-In-One Printer
How do you reset a HP Deskjet 3050 printer?
To do a soft reset
1. Press MENU
Jan 02, 2011 | HP LaserJet 3050 All-In-One Printer
Comm. error
nothing hapen with your printer,because poor telephone line. Turn off and on,if this masseger still display you shoud "reset factory defaul" by press enter,right -hand arrow untill the display control appear"srevice" press enter again- choose "reset factory defaul" and double click enter. your printer will be reset
Jul 22, 2009 | HP LaserJet 3050 All-In-One Printer
Replacing Print Cartridge
Turns out there was an easy solution. I filed a support case and had an answer in half a day:
"Often this issue is caused by a sensor. â Therefore the first thing we should do is try to trigger the sensor.
1 Turn off the HP LaserJet 3050
2 Remove the toner cartridge from the HP LaserJet 3050
3 Remove all of the paper in the paper tray
4 Check the entire paper path for any obstructions
5 Reseat the toner cartridge and paper
6 Power on the HP LaserJet 3050
If the issue is still not resolved we will need to try some resets on the HP LaserJet 3050.
1. The first reset we can try is a soft reset, it is done by pressing the MENU key then holding *# together. â This will bring you into a Developers Menu. â Scroll through the options until you find reinit FFS and then press the ENTER key.
2. If this reset doesn't clear the issue we can try a harder reset. â We can do this by pressing MENU, scrolling over to SERVICE, pressing ENTER, scrolling over to RESTORE DEFAULTS and pressing ENTER to restore the defaults and ENTER to confirm.
WARNING: Restoring the defaults will clear your fax settings, phonebook numbers and headers so you may want to print a phonebook report and Config Report first. â We can do this by accessing the Reports menu.
3. If these two resets do not help there is a third reset we can try.This reset will completely put the HP LaserJet 3050 back to factory defaults.WARNING: Before doing this reset we will need to disconnect the power cord, the phone cable, and the USB cable from the back of the HP LaserJet 3050.We can do this reset by unplugging the power cord from the back of the HP LaserJet 3050 then holding down the MENU/ENTER key and * symbol at the same time,then powering the HP LaserJet 3050 back on with the keys compressed.We will release the keys as soon as PERMANENT STORAGE INIT appears on the display screen."
I tried all the steps in sequence; it took #3 to fix it. Fortunately I didn't have a big fax address book or custom settings, so a factory defaults reset didn't cause any extra problems. It retained the time and date, and now it works fine.
Mar 12, 2008 | HP LaserJet 3050 All-In-One Printer
Kettler Rowing Machine  Kadett Rowing Machine Logo
Top Kettler Exercise & Fitness Experts
Jim London
Jim London
ray gallant
Steven's...
Steven's...
Are you a Kettler Exercise and Fitnes Expert? Answer questions, earn points and help others
