Question about Radio Communications
How to turn off vaas bluetooth headset - Radio Communications
2 Suggested Answers
casouzaj
  • 1118 Answers
SOURCE: HBM 730 Bluetooth Headset Wireless Headset: what is the mfb on my bluetooth headset and do i t...
I don't know your headset in depth, but MFB stands for Multi-Function Button. Headsets usually have one big button used to make, answer, and end calls. There may be other buttons, too, like volume up and down. To turn your headset on, press and hold the MFB for some seconds, until its indicatior light flashes. To turn it off, press and hold the MFB again, until its indicator light is turned off. To put it in paring mode (starting with the headset powered off), press and hold the MFB much longer than the time required to turn it on (you'll notice that it will flash as if it was turning on, but keep pressing the button). Headsets indicate they are in pairing mode when the light either keeps flashing rapidly (sometimes in more than one color), or stays solid lit, As I've said, I don't know how yours will behave, but you will find out. Once it is in paring mode, make the bluetooth application on your phone search for new devices. After a while, the HMB-730 will appear on the phone screen. Select it and make the application proceed. If a paring code (or PIN, or passkey) is requested, enter '0000' (four zeros).
Hope it works for you.
Cheers! Carlos
Posted on May 20, 2010
How can i listen to music from my samsung r355c via wep460
Turn on your bluetooth headset. On your mobile, turn on bluetooth and search for bluetooth devices. When your bluetooth headset is detected, select it and it will be "paired"with your phone and whenever the headset is turned on all audio output(such as call, music etc.,) can be heard through the headset.
Sai.
Sep 18, 2011 | Samsung WEP460 Bluetooth Headset
Connect to iPhone 4
Hold the "Answer/End" button on your Jabra Bluetooth headset down until the LED light on the headset turns solid blue. The location of the button may vary based on which headset you have, but its appearance will be the same; it is the button that has an image of a telephone on it.
Click on the "Settings" icon from the main screen of your iPhone 4 .
Click on "General" in your iPhone's "Settings" menu.
Click on "Bluetooth" to access your iPhone's Bluetooth menu and then click the option to turn on your iPhone's Bluetooth connection. Once your iPhone's Bluetooth is turned on, it will search for available Bluetooth devices.
Select your Jabra headset by clicking on the icon that appears on your iPhone's screen.
Enter the passkey for your Jabra Bluetooth headset. The default passkey on Jabra headsets is "0000."
Click on "OK" on your iPhone 4 to complete the connection to your Jabra headset.
Tips & Warnings
The LED light on your headset must be solid blue to pair to your iPhone. A flashing light indicates your headset is not yet in pairing mode and your iPhone will not be able to connect to the headset.
Having your iPhone 4 Bluetooth turned on will drain your phone battery faster than normal.
Apr 13, 2011 | Jabra Bluetooth Headset - BT2070
Cannot 'pair' the HPBLU H1 to my Blackberry..? Not 'finding' it... need a users Guide... where can I get one...?
Instructions
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Feb 23, 2011 | Cellular Innovations HFBLUH1 Bluetooth...
I AM NOT ABLE TO PAIR JABRA BT135 WITH MY BLACKBERRY 9700. WHAT SHALL I DO?
Hi,Instructions on how to pair blue tooth device with black berry.
Tips & Warnings
Have a nice day .
Feb 16, 2011 | Jabra BT125 Headset
How do I connect my blackberry cel phone to my bluetooth ce0678
Hi, you can use this instruction to pair your blue tooth with your cell phone:
Instructions
Tips & Warnings
Good luck to you..
Feb 01, 2011 | Cell Phones
My blackberry bold phone does not locate my Plantronics VBH-300 bluetooth headset whilst trying to pair them. It was paired with a previous nokia phone,which I no longer have.
Hi,you will have to delete the previous paired phones first before you can be able to pair the blackberry phone with your blue tooth device.
You can use the below steps to know how to pair properly:
Instructions
Tips & Warnings
Hope it helped.
Thanks for usingf ixya..
Jan 13, 2011 | Plantronics Explorer 320 Wireless Headset
I need a security passkey for a plantronics 6400 bluetooth headset
Step 1: Set the headset to be discoverable
1. Turn off the headset.
2. Press and hold the headset button for about eight seconds, until you hear the startup tone and then five quick high beeps.
The headset is now discoverable and will remain so for about five minutes. The status light blinks while the headset is discoverable.
Step 2: Turn on Bluetooth on the other device and search for devices
1. On the device, turn Bluetooth on and set the device to search for other Bluetooth devices.
2. On the device, choose iPhone Bluetooth Headset and enter the PIN code 0000.
See the instructions that came with your other Bluetooth-enabled device for more information about pairing it with Bluetooth devices.
Remember all blue tooth use the same codes.
hope that helps...
thanks for using fixya........
Jan 07, 2011 | Plantronics Explorer 320 Headset
Blackberry 8530 cannot find / pair with bluetooth Samsung stereo headset. Tried putting both into discoverable mode, no help. This headset will pair with my Blackberry 8320 phone, but the music speeds...
1. Turn on Bluetooth headset and Blackberry hand-held.
2. Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
3. Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window
4. Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list
5. Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically
1. Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset 2. Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
3. Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Dec 03, 2010 | Insignia Bluetooth Wireless Headphones...
I just need a pin number so i can pair my headset to my iphone
On the device, choose iPhone Bluetooth Headset and enter the PIN code 0000. let me know does thsi help regards golu_fixya
On the device, choose iPhone Bluetooth Headset and enter the PIN code 0000. user_offline.gif
Aug 29, 2010 | Cell Phones
Can't hear headset
Here is a list of compatible bluetooth headsets taken from the Blackberry web site.
  • Flamingo™ Bluetooth Headset *
  • Jabra® BT250v
  • Jabra JX10
  • Jabra BT125
  • Logitech® Mobile Pro™ Headset
  • Motorola® Bluetooth Headset H500 **
  • Motorola Bluetooth Headset HS820
  • Motorola Bluetooth Headset HS850
  • nXZEN™ 5000
  • Plantronics M3000 Bluetooth Headset
  • Plantronics Discovery™ 640 Bluetooth Headset
  • Plantronics Explorer™ 320 Bluetooth Headset
  • Plantronics Voyager™ 510 Bluetooth Headset
  • scala-500™ ***
  • Sony® Ericsson® Akono™ Bluetooth Headset HBH-602
  • It may be a compatibility issue with the H700. You may want to make sure the volume is turned up fully on the headset as well.
    Good Luck
    Jun 28, 2008 | Motorola Mobility H700 Wireless Headset
    Radio Communications Logo
    16 people viewed this question
    Top Radio Communications Experts
    eradiostore
    eradiostore
    Mike Charette
    Are you a Radio Communication Expert? Answer questions, earn points and help others
