Question about Generac Electrical Supplies
Why does it just click when I try to start it?
It has a new battery.
  • Greg Hoffman
    Greg Hoffman Jul 04, 2015
    Possibly the contactor or starter
    Guru:
  • 147 Answers
Could be battery solienoid contacter fuse
Posted on Jul 09, 2015
3 Suggested Answers
SOURCE: Generac Guardian 15 kw overspeed fault
Did you remember to set the overspeed shutdown threshold on the control board?
Posted on Jun 07, 2010
Kizii
  • 69 Answers
SOURCE: Where can I find used 5 kw generator for Comfort Pro?
In a second hand electro shop.
Posted on Nov 11, 2012
2011 f150 want start just click has new battery worked fine yesterday today want start just click
Possible internal starter problem. Try tapping on starter motor while key is held in crank position. If vehicle starts, suspect a starter motor problem and replacement will be required
Feb 28, 2016 | Cars & Trucks
Cannot start loud fast clicking noise
Clicking noise would indicate starter solenoid faulty! This would also be the case if battery low but since you have a new battery you can look at the starter solenoid!
Aug 22, 2015 | Cars & Trucks
New battery and car only clicks like bad battery
Check both ends of the battery cables to insure they are not loose. If this isn't the cause I'd take it back to whoever installed the battery and make them fix it. If you installed it yourself and a loose connection isn't the problem I'd let a dealership mechanic check it out.
Feb 25, 2015 | Cars & Trucks
Charge up a new battery and installed it. Tried to start and only get a clicking noise
Hi Jeff,
Welcome to Fixya.
Double check all the connection wires from the battery gioing to the starter and going to the ground. Clean the terminals if there are any corrosion.
Try tapping the starter using a hammer while someone is turning the key to start the engine and see if it will start.
Let me know if this helps.
Jan 18, 2015 | Ford Explorer Cars & Trucks
1998 kawasaki VN1500 Vulcan Classic Motorcycles
try cleaning the start button inside the housing as weather gets in and could be a dirty contact ! check the earth contacts around the engine also ! are the wires to the solinoid in good condition , battery wires also ?
Apr 24, 2014 | kawasaki VN 800 Vulcan Classic Motorcycles
Car won't start. New battery installed recently. Only clicks when trying to start.
one single click any time you turn the key usually indicates a bad solenoid on the starter. A new starter will typical get you going.
A series of rapid clicks when you try to start usually indicates a weak battery. There could also be a bad connection at the terminals on the battery or even a poor connection at the starter.
If you get a single click and everything goes dead for a couple of seconds than you definitely have a bad connection at the battery.
Let me know what you find or if you have any questions.
Dec 28, 2011 | 2007 Chevrolet Tahoe
CAR CLICKS WHEN I TRY TO START THE ENGINE
The starter will click like that when there isn't enough juice in the battery to turn the car over. Try jump-starting it, take the cables off the car right after it starts. Turn on the headlights right away. If the lights are dim or go dim after 5 minutes, then you need a new alternator. If the lights stay bright, drive it around for about 10 mins. Turn the car off and try to start it again. If it clicks again, you need a new battery. If it starts up, you're good to go - you must have just left something on and drained the battery.
Jul 31, 2010 | 1999 Toyota 4Runner
While trying to start my 2002 jeep liberty limited edition 2wd 3.7l engine I only get a click, after any number of clicks it finally starts.
It sounds like you need a new battery. If it's a 2002, then it's probably on it's second battery already and due for a new one. The clicking is the starter solenoid trying to engage the starter with the flywheel. If the battery can't supply enough "cold cranking amps" or "power", then it makes that clicking noise.
Dec 24, 2009 | 2002 Jeep Liberty
My 1999 new beetle won't start
Sounds like the battery is dead..Sometimes you have to clean the jumper cables and terminal on the battery to make a good connection try that and let your battery charge for a few minutes before trying to start it. If that doesnt work you may have a seized starter! Good Luck!
Sep 15, 2009 | 1999 Volkswagen Beetle
Electrical Supplies Logo
60 people viewed this question
Top Generac Electrical Supplies Experts
Craig Butler
Craig Butler
dennys23601
Don  Farrell
Don Farrell
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
