Question about Garmin nuvi 885T GPS Receiver
Remove battery garmin 745 - Garmin nuvi 885T GPS Receiver
How to remove battery from garmin 205 ?
they are fixed in you have to take the hole thing to bits
Jul 27, 2014 | Garmin nuvi 205W GPS Receiver
My dell desktop asking for a password
If you want to create a new Basic Input/Output System (BIOS) password on a Dell Optiplex 745, reset the password. Resetting the password also applies if you want to remove an existing BIOS password. BIOS passwords are used to add an additional level of security to your machine. Without the correct BIOS password, your Dell Optiplex 745 will not complete the boot process. The password can be reset whether you know your current password or not.
Turn off your Dell Optiplex 745. Start the computer. Press "F2" the moment the Dell logo appears on the screen. You will only have two to three seconds to press the key. Enter your BIOS password. Navigate to the "Exit" screen. Select the "BIOS Password" setting. Enter your BIOS password and a new password if desired. Do not enter anything in the "New Password" box if you want to remove the BIOS password completely. Press "Enter" to save your password settings. Reset Forgotten Passwords Turn off your Dell Optiplex 745 and remove the power cord from the computer. Disconnect any external hardware and cables. Slide the release latch located on the back of your Optiplex 745. Lift the cover as you slide the latch. Hold the cover firmly and pivot it back on the hinges. Remove the cover from the hinges. Find the "PSWD" jumper on the motherboard. This is a two-pin jumper and should be clearly labeled. Use a flashlight and magnifying glass if you have trouble locating it. Remove the jumper from the motherboard. Replace the cover and slide it into place until the latch snaps into place. Reconnect the power cable and restart your computer. Shut down the computer after it has completely restarted. Disconnect all cables and remove the cover again. Replace the PSWD jumper. Replace the cover. Reconnect all cables and restart your computer.
b> Clearing forgotten passwords http://phubner.eng.ua.edu/Files/Optiplex 745/advfeat.htm - wp1117484
Mar 20, 2013 | Dell OPTIPLEX 745 PC Desktop
Remove broken headphone jack on an Optiplex 745
Since the Headphone jack is soldered onto the motherboard in most cases you could remove it by unsodering it from the MB. However, replacing it might cause another issue. You can always install a sound card that would allow you to have additional headphone jacks.
Jan 17, 2013 | Dell OPTIPLEX 745 PC Desktop
Optiplex 745 battery replacement
It uses a standard button cell battery, Open the top of the computer and you will see it by the slack slot on the motherboard, read the type number off it and get another from any electronics store, Then simply swap the dead one with a new one.
Mar 07, 2012 | Dell OptiPlex 745 Desktop/ Mini-Tower/...
How do i remove the battery out of my garmin 1300
Determine that you do have a Garmin GPS with a replaceable battery. Find the information by checking the manual or with a close inspection of the back and sides of the GPS unit. GPS units that have a battery that can be replaced by the owner will have a battery cover lock on the back or side; it looks like a small sliding piece of plastic with slots or ridges.
  • 2 Open and remove the battery cover by sliding the battery cover lock and pulling off the battery cover. In some models, you may have to hold the lock up while simultaneously pulling the battery cover off.
  • 3 Remove the battery by sliding the battery out of the battery cavity. You may need to use gentle pressure to get it to slide out.
  • 4 Put the new battery in by sliding it into the battery compartment. Line up the metal contacts on the battery with the metal contacts in the battery compartment to make sure it is properly installed.
  • 5 Click the battery cover back into place. The battery cover lock should automatically lock and secure the cover. If this does not happen automatically, slide the lock back to the locked position.
  • Mar 01, 2011 | Garmin nuvi 1300 Car GPS Receiver
    Bought a used Dell Optiplex 745 Desktop Computer. Seems to boot up okay, but no video. Want to check inside to see if any connectors are loose. How do you remove off the cover(s)?; I don't see any screws...
    To remove the side of the Dell Optiplex 745 cases you need to push the release latch on the back either top or side depending on whether it is a tower or a desktop. The latch just slides back and the side will release and the cover will pop loose. The normal issue with this model is not a bad video card, it is bad capacitors on the motherboard. We repair these boards all the time for a federal prison that is located near our office. Look over this guide we have posted on our site that explains what to look for and what to do about it. http://www.ccl-la.com/blog/index.php/dell-optiplex-745-repair/ The repair is easy to do if you can solder, We have 4 units in right now for repair. Check out your board, I would bet his is what your problem is.
    I hope this helps, if so please rate our solution.
    BuddyMc
    Jan 20, 2011 | Dell OPTIPLEX 745 PC Desktop
    Replacement of the memory battery of my Garmin 195
    Piece of cake. Remove screws from back of device. Separate the housing and carefully lift up circuit card off of pins. There is a battery holder underneath. Simply remove wafer battery and replace with like model battery. Put back together and you're off.
    Jun 13, 2009 | Garmin 185 Sounder GPS Receiver
    Garmin Nuvi 255 won't charge with the car charger.
    You may need to replace the battery.
    The video on the link below shows how to replace the battery in a Garmin Nuvi:
    How To Change The Battery On A Garmin Nuvi 760
    Feb 21, 2009 | Garmin Nuvi 255 GPS Receiver
    Garmin nuvi 885T GPS Receiver Logo
    18 people viewed this question
    Top Garmin GPS Experts
    SHARCNET-USA
    SHARCNET-USA
    TO Lady
    Are you a Garmin GPS Expert? Answer questions, earn points and help others
