Question about Troy Garden
Snowblower doesn't have power
I have a 3 year old Murana 28" , 357cc snowblower which since new never cleared snow like such a big machine should . Even if I overlap rows by 50% , I still have to stop and go repeatedly so it won't clog . Even then , it "blows" the snow maybe 4 feet . I've read the manual which suggests adjusting the speed governor , which I did numerous times , but it's still the same . I think the problem is that the motor isn't reving enough but I don't know how to raise full-throttle rpm . The machine seems to operate smoothly with no other apparent problems . Thanks for any suggestions .
    New Friend:
What engine is on your machine? The manual for the machine suggests referring to the manual for the engine that was shipped with the machine.
I'm not familiar with this machine and don't have any around here to look at but it sounds like there is a problem with the carburetor settings, either a manual setting or the governor. When you start the machine, do you move a lever to choke it and then move it again to the "Run" setting? Is there an idle setting?
You mentioned the governor. Have you adjusted it? Did you follow a procedure for your engine? If done correctly, the governor will keep the engine at whatever speed you set the throttle to. If not properly set the governor could hold the throttle closed (low speed).
This machine should throw snow nearly 30m according to the manual, anything less means there isn't enough RPM's to the auger to provide it with the "Power" to throw the snow.
Posted on May 12, 2017
5 Suggested Answers
wiringlunati
  • 576 Answers
SOURCE: Toro snowblower///// tecumseh# on motor is H35-45598R SER 5283B
Usually that is a sign of the carb not being adjusted right. Run it at full throttle and adjust the main mixture needle (usually on the bottom) until it runs the smoothest. Set it in the middle of the range where it runs smooth. Then set it down to idle and adjust the idle mixture until it runs smooth at idle. Accelerate it rapidly and if it bogs or hesitates turn the idle mixture a little leaner (clockwise) and try again until it works right. That should get you very close. Try tweaking it a bit from there. as the microscopic specks clean out of it, it may need more adjusting.
Posted on Nov 25, 2009
kel1guy2002
  • 3740 Answers
SOURCE: We have Tecumseh TSH 359/22272/81
Hi and welcome to FixYa. I am Kelly.
The fact that the engine blew out most of the oil during normal operation is an indication that there is a problem with the crankcase breather. You can usually resolve this by removing the breather from the side of the engine at the base of the valves and cleaning it with engine degreaser and carb cleaner. What I think happened was there was a bit of condensation in your breather and it FROZE in the closed position forcing the crank case to over-pressurize and porting the oil into the breather.
If by chance you over-serviced the engine oil before the last operation it will present the symptom you describe. Also if you tipped the unit more than 30 degrees.
It most likely will not start now from an oil fouled plug.
You can use this manual for locating "How to" repair your engine:
http://www.cpdonline.com/692509.pdf
Here is what the service manual says on page 82.
BREATHER PASSING OIL
1. Check the oil level, make sure the engine is not overfilled. Also verify that the viscosity rating on the container of
the oil being used is to specification.
2. Check the angle of operation. Avoid prolonged use at a severe angle.
3. Check the engine R.P.M. setting for excessive R.P.M. using a vibratach or other tachometer and compare it to the
R.P.M. settings found on microfiche card # 30 according to the engine model and specification number. Adjust the
high and low R.P.M. as necessary.
4. Check for leaking or damaged gaskets, seals, or "O"-rings. External leaks may not be evident; however, the leak
may prevent the engine from achieving a partial crankcase vacuum.
5. Check the breather for damage, dirty condition, or improper installation. The oil return hole(s) must face down.
6. Check the engine compression using a compression tester. If the engine has weak compression, determine the
cause of weak compression: worn rings, leaking head gasket, or leaking valves. Follow the compression tester's
procedure.
I can help more... the engine number you passed did not cross.
Thanks for choosing FixYa,
Kelly
Posted on Jan 29, 2011
  • 36 Answers
SOURCE: We have Tecumseh TSH 359/22272/81 motor on a Stiga
Northern Tool and supply should have what your looking for.
Posted on Feb 08, 2011
mindlessforu
  • 7 Answers
SOURCE: Snowblower- 8HP Yard Machine-Auger(s) won't turn
Sounds like you broke the belt. The auger housing should be held on by a few bolts between the auger and the engine. Remove the bolts and it should come apart into two pieces. You will most likely find a broken belt there.
Posted on May 23, 2013
Auger belt burns out
un-seize the auger action
replace rusted bearings
Feb 07, 2016 | Garden
I started this snowblower in the summer and it worked fine...both winters I've tried to use it it won't start. The first year I had it it worked very well.
So you are saying it wont run in the cold. Will it run if you left it in the house until you wanted to use it?
Are you going thru the procedure of Choking the engine ? Is there a Primer Bulb that you have to push on this machine?
I'm just saying that engines don't like the cold to begin with, just make sure you are going thru the 'Cold Start' procedure properly.
Jan 20, 2016 | Toro Power Clear Snowblower 418ZR - 38272
Auger clutch cable breaks at hook
find out why it is binding at that point they should not break that easy , do not force it , that is what is happeing find out what the problem is
Feb 14, 2014 | Craftsman Snow Blower / Snowblower Bottom...
Torro snowblower won't throw snow. Gets stuck in auger and blades.
make sure its turning a good speed, check belts
now that you have all that other junk on it it will be hard to do what you should have done. paint those parts. then spray with wax pledge will work. I buy and resell these and it works for me. nny
Dec 14, 2013 | Toro Power Clear 221 Electric Start 21...
208cc b&g craftsman snowblower governor settings
sounds like last years ethanol gas messed up your carburetor.
Probably have to drop the carburetor Bowl and clean the Jet
Nov 22, 2012 | Craftsman Snow Blower / Snowblower Bottom...
Craftsman 247 88190 0 snow blower auger frozen
my auger and impeller froze too. fixed by clearing all snow, ice,stone build up behind impeller it works fine now.. hope that helps
Jan 19, 2009 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
119 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
