Question about Waring BB160 2 Speed Blender
Unused for 23 years. Started right but up smells a little. Need oil?
I am afraid it needs oil....
I have 3-year-old Kitchenaid Blender, model KSB1575CCUO. The motor started occasionally making a grinding sound, especially on high speeds, but blades still turn. Does the motor need oiling?
it could be failing bushes for the motor
take it to an appliance repair shop for an inspection of the motor to check for bush/bearing problems
Dec 10, 2016 | KitchenAid Blenders
Blender does not blend, only buzzes. So I took the blender jar off the motor base and tried running it. It ran just fine. Put the jar back on the base and it only buzzed. Figured a piece of frozen fruit...
Smart move. The blade assembly is almost frozen and the motor does not have enough torque.. You need to remove the blade assembly and completely clean out the bearing and reassemble after the Mr. clean operation. A lite dab of oil is also called for.
Sep 10, 2017 | Oster 006832000000 10Speed Blender
I tried to blend large piece of the frozen mango. It won't move and I continue trying . I smell little burned and the machine wont move again.
It sounds as if the motor has burned out. You may need to purchase a new blender or send it to the manufacture for repair if it's still under warranty.
Jul 14, 2011 | Cuisinart Blenders
Waring 34BL87 blender is loud and gives off a strong burning smell whenever used. Burning smell apparent since first day of use and getting worse with age. Is this odor normal or does it indicate the...
no, that is not normal. it could be from a loose or misallignment rotor or shafting. if its under warranty you should return it from the store...
Jun 17, 2011 | Waring TG15 Blender
After starting the microwave, I get a "F-7" message on the display and it shuts down. What can I do to fix this? This is a whirlpool model # GH5184XPS-4.
hello,
what this error means indicate is as follow
The F-7 error code indicates that the water or oil (any liquid form) temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F).
what you need to do to fix up your is to do general cleaning up on your oven both internal and external do this with care and allow it to dry up it self.
please when doing this you will have to put off any form of power supply connected to the oven .
thank you and thanks for using fixya.
Jun 01, 2010 | Blenders
K-Tec Champ HP-3 Burning Smell and Light Smoke
That burning smell is kind of a death sentence. At least a switch or more likely coils are burnt out.
Mar 27, 2010 | K-Tec Champ HP3 Work Top Blender
Burning smell when used
No need to oil it. The carbon brush maybe sparking already it is located inside the motor. It is due to damaged Armature or overloaded motor.
May 25, 2009 | Waring BB160 2 Speed Blender
Jack La Lanne's Health Master 100
First determine..if it is indeed the motor that is fried. Do this by not using the caraffe. Plug in the motor and run it by itself. If it runs fine without smoking again..It is the caraffe that is defective.
If its the motor you are out of luck completely. Jack Lalanne is out of business.
If it is the caraffe..which I suspect it is not...oil the rim of the bearing that is on the outside of your caraffe ..it surrounds the knurled part that is inserted into the blender...even if you are able to get the motor repaired..get in the habit of oiling the caraffe bearing after each time you use it. If you dont it will fail within months to a year of use
Lalanne had they made in China..and using unsealed bearinga that rust out and the contents of the blender come out!! So I discovere dthat oiling that part each time after use..keeps my blender running smoothly.
You might want to take yoru motor to a small appliance repairman..he might find something simple happened.. like a loose wire connection inside! If he does...you have a simple solution and a motor that works!
Remember to oil the bearing a couple drops each time after use...and if yoru caraffe ever fails you can buy a new one..( Oil that one too!) at Cooking Toys..you can google for the address
gmcgeary@gmail.com
Jan 06, 2009 | Jack Lalanne Health Master 100 Blender...
Waring BB160 2 Speed Blender Logo
27 people viewed this question
Top Waring Blenders Experts
karen renee may
Level 1 Expert
eyecam
Are you a Waring Blender Expert? Answer questions, earn points and help others
