Question about GE Spacemaker JVM1640SJ Microwave Oven
Jvm240bl001 Where can I buy a door handle
Counter saver plus 62702 kenmore
If you repair a door assy. you are required per DHHS rules to perform a leak test on and around the door after such repair.
Oct 07, 2013 | Hotpoint RVM1435 Microwave Oven
Power of GE JVM240BL001
You can view a PDF of the old owners manual for this model on the GE website. The manual states 750 watts.
Jan 15, 2012 | GE SpaceMaker Microwave Ovens
How to replace the door handle on a GE, JVM1490SD 003 microwave?
around the door you will see a plastic cover strip. gently pry it off and under there you will find the screws to open up the door and get to the door handle screws. you dont have to worry about breaching the seal.
Aug 13, 2009 | GE JVM1490 Convection/Microwave Oven
The handle is broken off
You can buy the door handle for less than $30 and you do not have to replace the whole door. This part is not too difficult to replace yourself if you know how to handle a simple tools.
Hopefully this video clip
Jul 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My door handle is broken. Is it posssible to
You should be able to buy only the door handle and avoid having to replace the entire door. Appliancepartspros.com carries the handle. Just type in the model number you provided and look for item #3 under the parts listing. The part number and price varies based on the color you need. Make sure you order the correct color. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions, please let me know. I hope you find this information helpful.
Jul 06, 2009 | GE JVM1640 Microwave Oven
How to replace a broken handle
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
May 24, 2009 | Microwave Ovens
Parts
I don't seem to be able to find a Door Handle for my Maytag microwave Model #MMV5207BAS can any body help me. I have tried numerouse sites but the handle does not seem to be available.
Apr 23, 2009 | Maytag Microwave Ovens
I have a GE Profile Microwave and the handle is broken....
I have the same issue. The Handle broke off my GE Microwave Oven (Model JVM1190SY 001). GE does not sell the handle seperately from what I can tell. I just ordered a new door. It's rediculously expensive. I tried to replace the handle with a nice drawer pull but couldn't find a size pull to match and I broke the plastic cover trying to get access to the screws for the handle, which is why I decided to buy the new door. Hopefully installation is not that difficult. This oven was manufactured in 2001, seems the handles have a 7 year life span.
May 28, 2008 | GE JVM1190SY/WY/AY/BY Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
