Question about Toys
Bobcat 863g computer fuse short out. so i dis-connect the harness from the computer ( located on the left side by the left foot when you sit in)replace a new fuse and it ok. but if i re-connect the harness back togethe, the fuse is pop again. is it my computer has a short inside ? please help thankyou
3 Suggested Answers
SOURCE: Bobcat 553 f - traction lock problem...help
sounds to me like a bad connection or a weak solenoid causing the voltage drop. a good alt charges at 14.25-14.50. it takes voltage to open solenoids not close them.
Posted on Sep 05, 2009
mastermaid
  • 502 Answers
SOURCE: Bobcat 751 loses power after running for only
You can get the service manual from these guys. This should help a lot.
Posted on Feb 22, 2011
I have a bobcat 863. Sometimes it will not shut off when I turn it off. Any ideas?
Bobcat 863 863H Service Repair Manuals - YouTube
? 3:17
www.youtube.com/watch?v=Hsp-NAdM4Sg
Oct 30, 2010 - Uploaded by DiyRepairManuals
Bobcat 863 863H, Service Manual, Repair Manual.
Sep 15, 2015 | Toys
I have an 863 bobcat, I shut it off for just a few min, then when I tried to start it back up it turns over but won't start, I tried starter fluid which will start it but it will only run for a few seconds
I presuming it is a diesel bobcat, if so then your fuel solenoid has failed, you will need to replace the solenoid, it a large nut with a wire coming from it and it's located on the fuel injection pump,
Jul 24, 2014 | Cars & Trucks
Where is the obd connector on a 1991 mitsubishi 3000gt
The Data link connector is located on the side of the fuse block which sits above your left foot as you are sitting in the car, the fuse block has a black plastic cover, and the connector on the side and has a soft rubber boot.
Jan 29, 2012 | 1992 Mitsubishi 3000GT
Where is fuse box on a bobcat 863 ?
In the rear compartment down on your right under a couple dust covers.
Mar 23, 2011 | Bruder Cat Skid Steer Loader
Locating the fuse box
Check the Ford-Taurus-Owners-Manual for this location and fuse description.
Hope helps; remember coment and rated this.
Aug 05, 2010 | 2000 Ford Taurus
Need to know where the windshield wipers fuse is located
There are 2 fuse boxes / fuse panels in nearly every Ford product: one directly above the driver's left foot (when the driver is actually sitting in the driver's seat). The other is inside the engine compartment, on the right side - contains high current fuses.
The Owners Manuals have detailed illustrations and information regarding the two fuse box / panels, and the various vehicle systems each fuse connects to.
Jan 30, 2010 | 2009 Ford Taurus
2010 nissan frontier - no +12V at 7 pin connector
on the r/h side floor area by your right foot if you are sitting in the truck is a side cover. thas where the harnesses are for the hitch. they are hidden behind the cover. you should see a small harness with relays. thats the harness.
Jan 18, 2010 | 2008 Nissan Frontier
1990 honda accord, all tail lights not working, checked bulbs ok, could not find fuse.
There are two fuse boxes--one under the dash by the left foot rest which handles most of the interior circuits, and one under the hood on the left side to the rear of the battery for the headlights and other high-drain equipment. Each should have a diagram on the cover. Check all related fuses again.
If that doesn't solve it, you have either a grounding issue or a short in the wiring harness. Check each lead with a voltage meter to narrow down the location.
Crat
Oct 24, 2009 | 1990 Honda Accord
Jul 19, 2009 | Bruder Cat Skid Steer Loader
What do you have to remove to get to the fuel tank on 863 bobcat
for remove the bobcat fuel tank you need remove first the motor or if do you want to clean the fuel tank you only need remove in the botton side the steel bar with 3 screws and remove the fluel tank plug.
Jun 25, 2009 | Bruder Cat Skid Steer Loader
Toys Logo
43 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
