Question about Star Micronics SP700 Receipt Printer
Star sp700 doesn`t want to print all the tickets
Shodow item when printing
Try to recheck the utilities and the properties, set it and chose photo.
Jun 30, 2014 | Star Micronics SP700 Receipt Printer
Star micronic sp700 ethernet problem
10.x.x.x subnet can't see 192.x.x.x network. There must be manufacture reset button on the Star micronics sp700?. You can configured your laptop/computer IP to 192.168.2.100 (not the same as printer) than use crossover ethernet cable (you can find it in best buy), connected directly between your laptop and printer, you should be able to see it on your browser now.
Most people big mistake when assigned static ip. First you need to reserve that IP on your router so it doesn't get pickup by DHCP and assigned to another devices.
Mar 20, 2014 | Star Micronics Star IFBD-HE07 - Print...
How would I reset an IP Address on a printer
It depends on the network setting if you have chosen to dynamically assign the IP addresses to the device (DHCP) The IP automatically gets reset every as an IP is assigned to it dynamically by the DHCP server.
Sep 26, 2013 | Star Micronics SP700 Receipt Printer
Why does my star sp700 printer only print in red ?
seriously people? he said it's printing red. obviously it's not out of paper, the door is not open, there's no paper jam, etc.
Apr 27, 2013 | Star Micronics SP700 Receipt Printer
LIGHT PRINTING ON PAPER
they usually have a metal plate in the bottom that you remove and there is a switch panel where you can adjust the deep ( how dark it will look )
Jan 29, 2013 | Star Micronics SP700 Receipt Printer
Hello there , there is no way that the system either Leopard, XP or Windows 7 detect the printer. Please help me with this issue. I need badly to use this device. Please HELP ME !!!!
Please contact support@star-emea.com with your issue. Does the pritner power on? Is it USB, Ethernet, etc?
best regards
Star EMEA Tech Support
Jul 31, 2011 | Star Micronics SP700 Receipt Printer
MY PRINTER IS PRINTING A LOT OF QUESTION MARKES.......??????????.....
your printer is printing garbage because the file you tried to print corupt or the printer driver is corupt restart printer and pc then try printing a test page from the printer driver if this works then that file you printed and did come out properly is corrupt suggest you delete or if it a word file copy and paste into a fresh word document should sort out the corrupt file if the test page also comes out as garbage the uninstall the printer driver and reinstall it then test again
Nov 23, 2010 | Star Micronics SP700 Receipt Printer
Star TSP400 label printer Hi, have the following problem: Just put in new paper roll. Now all red lights are on, beep sound indicated that something is wrong and I get no response at all when I want to...
I had the identical problem recently with a new batch of ticket stock in a TSP400. It was eventually solved by cleaning the roller at the front of the print-head with alcohol (surgical spirit).
The roller had no visible dirt on it but may have been greasy, and the feed mechanism is clearly very sensitive to such things. It turned out that our ticket stock had been recently re-sourced and the new paper was slightly smoother than the old.
CEM London
Aug 10, 2010 | Star Micronics TSP400 Label Printer
Star SP300
we have a link on how to fix your own printer through this link(check for search box further down page)
Mar 20, 2008 | Star Micronics SP300 Matrix Printer
Star Micronics SP700 Receipt Printer Logo
24 people viewed this question
Top Star Micronics Office Equipment & Supplies Experts
GoogleLaughs
Are you a Star Micronics Office Equipment and Supply Expert? Answer questions, earn points and help others
