Question about KitchenAid KDRP463LSS Dual Fuel (Electric and Gas) Kitchen Range
Kitchenaid kdrp467kss0 dual fuel range.
I have a After a self cleaning cycle the oven door will not open, the display is dark. The surface burners still have power. A continuity check on the thermal fuse at the back of the oven shows it is functional. Do I replace the oven Zodiac control part #8300203?Or can I find out if it is working or not without replacing it.
aborcass
  • 2651 Answers
SOURCE: KGRA806PSS00 oven dead after self cleaning
heres the part number for the saftey thermostat 8300802
Posted on Apr 08, 2008
  • 4 Answers
SOURCE: KitchenAid oven shut down during self-cleaning
I've had the same problem and have had the thermo-protector switch replaced four times. After the last time I was so ********** I wrote to the CEO at Whirpool/Kitchen Aid in Benton Harbor, MI with my complaint. Today I received a call from an extremely nice lady in his office who said that they were sending me an updated kit for repair free of charge. The part number is 9759243. She offered that this was a known problem but was limited to just one production run - my luck!
If you are having this problem with your KGSA906PSS write to the CEO at Whirlpool!
Posted on Feb 02, 2009
solasknows
  • 199 Answers
SOURCE: Control panel black -No display
no reset fuse inside, by the power cord, also lcd display might be gone hope i helped
Posted on Jul 20, 2009
  • 25 Answers
SOURCE: inoperable KGRE801PBS00 Kitchenaid oven
1) unplug and turn your gas valve off
2) with a #2 phillips remove all the silver screw on the back of your stove (this will make is to you can remove the stainless splashguard)
3) there are several black screw holding on a removable (stainless) panel that covers the back of the stove - your culprit (thermal fuse) is under here).
4) on the back of the oven you'll see the back of a couple of fixtures (stove light, temp sensor etc). <-- do not touch these..
5) there is another attachment (attached with black #2 robertson screws).. it has two black wires plugged into it.. this is your thermal fuse - mine has a number 8300802 on it.
I had to replace this (18bucks) from my local hardware store. Unfortunately, these stupid ovens have this part recurring so buy a few.
At your own risk - when reinstalling, slip a little cardboard between the thermal fuse sensor (stainless flat side) and the stove.. you may save a few headaches..
this repair was an easy one compared to replacing the board on this stupid oven.. (i would not recommend buying one - typical north american engineering designed to keep the repair folks working)..
i guess you need to find a different way to screw the consumer eh KitchenAid? lol
have fun
CA
Posted on Jul 22, 2009
  • 17 Answers
SOURCE: I have a kitchenaid gas range and the door is stuck in lock
hold the oven door lite switch closed and put it on selfclean it should activate the door lock
Posted on Nov 14, 2009
LED screen fogs up when an oven and range are on at the same time.
The seal on the display is broke and you will need to replace the board. Eventually it will short out from the moisture. Here is that part to order.
All parts come with a 365 day, any part, any reason return policy.
Oct 21, 2013 | KitchenAid KDRS483VSS 48" Commercial-Style...
My KitchenAid Architect Series II Electric Range after I ran the self clean option the oven door will not open and the display does not light up, the top burners work just fine, tried ressetting the b
Hello Gene,
On the back of the oven is a thermal fuse that probably went outduring the sefl clean cycle,ya would need to pull the oven out and remove the back panel to test it, That thermal fuse is not resettable and must be replaced,it probably looks something like this 11_15_2011_7_41_32_pm.jpg
GENE
Nov 15, 2011 | Kitchen Ranges
I entered the "quick" option for self-cleaning my
It has a safety that will not allow the door to open while the temperature is high in the oven. oven temps can reach 700 degrees during the self clean cycle. allow the unit to cool completely and see if it works then. if not, let us know.
Nov 20, 2010 | KitchenAid KGSI901PBS Gas Kitchen Range
I was using the self cleaning function on my kitchenaid dual fuel range when about half way through the cycle the digital display went blank (i.e. no lights were on at all) and now 2 hours after the cycle...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Aug 19, 2010 | KitchenAid KDRP467KSS Dual Fuel (Electric...
I started the self cleaning cycle and forgot to make sure everything was out of the oven. I opened to check. The door had begun to lock, but had not yet locked. When I tried to the start the cleaning...
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
heatman101
Apr 22, 2010 | KitchenAid KDRP707RSS Dual Fuel Kitchen...
Kitchenaid DF Range F04 error code
I have a dual fuel kitchenaid convection range and I put it in self cleaning mode last night. Afterwards it said F 04 on the display. The doors open again, but neither of the ovens work
Nov 17, 2009 | KitchenAid KDRP487MSS Dual Fuel (Electric...
Door locked: display panel not lit.
Unplug the appliance and the next day it will work again. Do not use the self clean cycle or I will have to spank you! Did you not know that 900 degrees for 3 hours can harm delicate expensive electronics. Get some easy off and clean that oven or get ready to spend some serious dough on fixing this puppy down the line.
Apr 10, 2009 | KitchenAid KGRA806PSS Gas Kitchen Range
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
I need direction on how to start the clean cycle on my jenn air
CLEAN PAD
Use to set a self-clean cycle or a delayed
self-clean cycle. One press of the Clean
pad sets up an immediate clean cycle. A
second press of the Clean pad sets up a
delayed clean cycle.
• Clean oven
frame, door
frame (area
outside of gasket)
and
around the
opening in the door gasket with a nonabrasive
cleaner such as Bon Ami*. These
areas are not exposed to cleaning temperatures.
• Remove air grille.
• Remove oven racks. If racks are left in
during a clean cycle, it may impair function
and they will discolor. Turn off the
oven light and close door.
* Brand names for cleaning products are
registered trademarks of the respective
manufacturers.
TO SET FOR IMMEDIATE START:
1. Press Clean pad once.
2. Press the Auto Set pad for 3 hours of
cleaning time, press again for 4 hours
and again if 2 hours of clean time are
desired.
3. CLEANING and LOC plus the clean
time will appear in the display.
4. When the clean cycle is complete,
CLEANED will be displayed. LOC will
remain on until the oven has cooled
(approx. 1 hour).
5. When the oven is cool, LOC will no
longer be displayed and the door may be
opened.
6. Wipe out the oven interior with a damp
cloth. If soil remains it indicates the
cycle was not long enough.
TO CANCEL SELF-CLEAN:
1. Press Cancel pad.
2. If LOC is NOT displayed, open oven
door. If LOC is displayed, allow oven to
cool.
Thanks for using Fix Ya, Please take the time to rate this solution.
clarkco
Feb 08, 2009 | Jenn-Air JDS9860A Dual Fuel (Electric and...
Dacor ERD36SCH/H will not self clean
Door lock motor suonds like it is bad. Not an easy part to replace. You may need a technician.
May 12, 2008 | Dacor Epicure ERD36 Dual Fuel (Electric...
Open Questions:
See all KitchenAid KDRP463LSS Dual Fuel (Electric and Gas) Questions
KitchenAid KDRP463LSS Dual Fuel (Electric and Gas) Kitchen Range Logo
56 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
