Question about Nordic Track Nordictrack Exp 1000 Treadmill Motor Control Board 13
Does my nordic track exp1000 treadmill need lubrication
SOURCE: I have a Nordic Track exp1000 i fit and the track is not working.
It's either the electronics console overlay -- this thing often goes on this model -- or your motor is shot.
Have you ever seen it working?
Repairs can expensive.
You can buy an excellent replacement console electronics part for $100 (http://www.treadmilldoctor.com/Nordictrack-Console-Keypad-Overlay) , but if it's actually the motor, then you've still got more to spend.
In home service can easily run $150 for the call plus cost of parts.
If you decide that you're not going to try and get it repaired and you're going to toss it, I'd like to buy some plastic housing parts off that non-working unit from you. Please email me directly.
Cheers,
Mark
emotif@gmail.com
Posted on Jun 27, 2009
  • 16 Answers
SOURCE: Need to put together a Nordic Track Elite 2900 treadmill.
Type into the serch, icon health and fitness, then click on the customer service, then click onto the manuals and the instructions should be in the owners manual.
Good luck.
Posted on Jun 29, 2009
  • 18 Answers
SOURCE: How do you replace the walking platform on the
First, remove the motor hood. There are 3 screws at the front, and 2 underneath. The screws underneath will have to be removed by tipping the treadmill over, or pulling the console towards the rear of the machine.
Next, remove the side rails. This is a little tricky because of the cushion adjusters on each side of the deck. If you look underneath the deck, you will see that the adjusters are on rails that are attached to the platform. Remove all of the screws from the side rail and push it toward the rear of the machine while also moving the adjusters rearward. You'll have to kind of move them together until the adjuster slides off the rail. Do both sides.
Remove the rear roller, by loosening the bolts. Don't mess with the front roller unless you intend to replace the motor belt. You don't need to remove the front roller or the walking belt.
There are 4 bolts holding the deck to the frame. The rear ones go through the frame to a lock nut. The front bolts screw into the isolators. Remove them and the deck will come loose. You can slide it out from the walking belt.
Place the new deck next to the old, and start moving the parts over. Make sure the safety decal is on the bottom like the old deck. All of the holes are pre-drilled except for the belt guides. You'll have to measure for these. Now do everything in reverse to reassemble the machine. I'm also attaching instructions on how to adjust the belt.
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} First, ensure that it is the walking belt that is loose. There is a belt hidden under the hood that connects the front roller to the motor (motor/drive belt). Start the treadmill at 3 or so and carefully apply pressure to the walking belt until it slips/stops. Watch the front roller. If it continues to spin when the walking belt stops, it’s the walking belt. It the front roller stops with the walking belt, the motor belt is loose and needs adjusted or replaced.
To adjust the walking belt, locate 2 hex head bolts, one on either side of the deck on the very back of the machine. These bolts will be recessed inside the plastic covers. Your treadmill came with a tool for this, but if you can’t find it, a standard (not metric) allen wrench kit will work. It’s helpful to have a wrench in each bolt so that you can adjust them at the same time, but one will work.
The allen bolts thread directly through each side of the rear roller. As you tighten the bolts, it pulls the rear roller away from the front roller, tightening the walking belt. This also centers it; if you tighten one bolt, it pushes the belt towards the center of the walking deck away from the bolt you’re tightening. So if the belt is too far to the right, tighten the right bolt and it will move towards the center.
Place your wrenches in the roller bolts and turn the machine on to 3-4 miles an hour. Keep your fingers clear of the belt, it will eat them. This method is quick, because you can see the belt move as you tighten one side or the other. It takes a few seconds, but if you tighten the right bolt for instance, you will see the belt move to the left. If the belt is loose but centered, tighten each bolt ½ turn and then get on the machine and see if it slips. The user manual will tell you to pull it up a couple of inches to test the tightness, which is a relative method and doesn’t necessarily work. My wife can pull on the belt and get 2 inches, and I can probably get 3 or even 4 if I’m showing off. The best way to test it is to gradually tighten it until you can run on it without it slipping.
You should lube the belt a couple of times a year. You can get them from iconfitness.com
Good Luck!
Posted on Mar 11, 2010
  • 34 Answers
SOURCE: Nordic Track Ifit Treadmill has power but walking pad not working
If everything on the display console is working correctly then we know it is either a problem with the wires from the console to the controller or the controller itself. In most cases this means you need a new controller. To verify, take off the motor hood and find the green circuit board called the motor controller. With the power on go into manual mode and push the speed up button to a slow speed. If you see an LED light with "spd ctrl" next to it flickering but the belt still does not move then we know the problem is with the controller sending the signal to the walking belt, in which you should check the wires that go to the motor. If they are connected correctly then we know a new controller is in order. If you do not see a flickering light then it means the speed signal never got there and the problem will be with the wires going from the console to the controller. This is called an upright wire harness.
Posted on Aug 18, 2010
SOURCE: our belt is slipping on our nordic track c1900
I have the same unit. First, remove the hood. Then, the motor has an adjustment screw on the belt side of the motor. Loosen the nut a little, adjust the motor up or down to make the belt as tight as you can by hand, then re-tighten the nut. This always fixes mine.
Posted on Jan 03, 2011
Nordic track exp1000 stops suddenly while in use
If you wish to get some details about treadmill repair ; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 07, 2017 | Nordic Track Nordictrack Exp1000 Treadmill...
Nordic track commercial 1750 treadmill. over the last day or 2 it has developed a humming that gets more pronounced the faster you go as well as what feels like a small vibration
Try to lubricate the treadmill deck and belt
Watch the video to know how to lubricate the treadmill.
Treadmill walking belt lubrication
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Dec 23, 2016 | Nordic Track Exercise & Fitness
Why does my treadmill stick when I'm running
Vernon, Time to lube the belt,Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
DIY How to lubricate your treadmill belt
Treadmill Belt Lubricant
How to Lubricate Treadmill
Treadmills To lubricate or not to lubricate Insights
Apr 04, 2016 | Nordic Track Exercise & Fitness
Just purchased the nordic track 2550 pro treadmill and was wondering if you had to lubricate the belt, i was told that it was self-lubricating and never needed oiled.
You do not need to lubricate the belt, unless you speek with or read something from Nordic trac. Oiling wont hurt anything, but is not needed.
Dec 29, 2010 | Nordic Track NordicTrack A2550 PRO...
I own a nordic track exp1000 series and only recently had trouble with it. The panel lights up when the key is inserted but will not start up when the start button is pushed. What do I need to do to...
# get a 12-18 volt dc battery fully charged(like one from a cordless drill)
# Make sure it is fully charged, because it won't work if not
# attach the + and - to the motor red is + and black is -
# If the motor turns slightly your motor is ok, if not the motor is bad and would need replaced
# if the motor is ok then your motor controller(the board with the metal) is malfunctioning and would need replaced.
Jul 05, 2010 | Nordic Track NordicTrack T7 si Treadmill
Nordic Track treadmill trips GFI.
Have you lubricated the the running deck? The lack of lubrication can increase friction thus causing the GFI to trip. simple test start the treadmill do not walk on a see if the GFI is tripped in it does trip then lubricate, then if after lubricate it still the you have a worn belt and possibly damaged deck depending replacement price and on what you paid for the treadmill it may or may not be worth fixing.
May 20, 2010 | Nordic Track NordicTrack Treadmill, A2550
Our EXP1000 treadmill is about 10 years old and we have not had any problems with it. The belt recently has been going slower than before. for Example, we used to walk at a speed rate of 4.5, now it...
If belt hasn't been replaced that's your poblem. If that's more than you want to put in a 10 year old treadmill, try lubricating it. That may bandaid the problem for a while. This will progressively get worse over time.
Nov 16, 2009 | Nordic Track NordicTrack Treadmill, A2550
Cheers,
Mark
emotif@gmail.com
Jun 09, 2009 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track Nordictrack Exp 1000 Treadmill Motor Control Board  13 Logo
83 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
