Question about Dryers
Flavel calibre balanced flue gas fire
Contious beeping sound i have changed all batteries
3 Suggested Answers
Obertelli
  • 3006 Answers
SOURCE: Hello, I'm having problems getting a new gas fire
Older fires have an exhaust flue and get their air supply from the well ventilated room in which they're fitted. Balanced flue fires are the correct choice for rooms which lack sufficient fresh air ventilation. They have a flue which draws in outside air necessary for combustion whilst also acting as an exhaust for the combustion products. To work the appliance must be completely sealed so that no air is drawn from the room; the pressure of the incoming air and the pressure of the outgoing exhaust is equal so the flue is described as balanced.
The lack of a requirement for fresh air ventilation means that less energy is used; open outside vents let heat out as whilst allowing fresh air to enter.
Balanced flue appliances which exit directly through an exterior wall should cost very little more to fit than a regular appliance: the only additional cost may be in blocking up the old flue outlet and creating a new one but this rarely takes more than half an hour. A sealing collar is fitted to the outside of the flue (included in the flue kit) so there may be additional costs in hiring a ladder (or even erecting scaffolding) if you're higher than the ground floor.
Budget-level balanced flue fires typically cost between £350-£500 and the fitting charge may be fair depending upon your property, but it's also worryingly vague. A properly qualified and experienced gas fitter should be able to give you a precise quote and will already possess all of the tools needed to fit a new flue.
Also, ensure that you have your landlord's written permission to fit the new fire. If you don't then the landlord can claim that you have damaged the property and demand that you restore the property to original condition when you leave. If you get permission then you can also expect your landlord to insist that when you leave the property you do not take the new fire with you and that you supply an original copy of the gas fitter's installation certificate. Without this the landlord is within his/her rights to commission a safety inspection at your expense. Note that subsequent annual gas safety checks are required to be carried out by the landlord at his/her expense as per normal.
Posted on Oct 20, 2009
Testimonial: "Thank you for the info its good to have it written down finally. I think you're right that the quote is a little flimsy so I will enquire further"
  • 560 Answers
SOURCE: Just had a flavel calibre balanced flue gas fire fitted , fumes seem quite strong and the room looks smokey any suggestions?
Open the flue. Check to see if the chimney is clogged.
Posted on Dec 06, 2014
No beep sound on remote
Try to change the batteries then try again. Also check the contacts in the battery compartment - they might have carbon or rust.
May 20, 2016 | Hitachi Televison & Video
Whrre is the battery compartment for flavel cascade 50 cooker please
Flavel : Manuals
www.flavelappliances.com/Products/Manuals
If you've lost or misplaced an instruction manual to one of your Flavel products, don't ... Electric Fan Oven with Separate Grill ... 60cm Side Control Gas Hob.
Sep 09, 2015 | Ovens
Two fire/smoke sectors occasionally beeping - no battery inside - connected to NetworX 1448E security system. We have changed the large battery in security - still beeping
If the units are more than 5 to 7 years old they have reached the end of life cycle and need to be replace. Smoke detector typically are only good for 5 to 10 years.
Sep 04, 2014 | Home Security
Fumes from flavel regent gas fire when burning
This is normal .It should definitely burnt off in a few hours.
Normally the heat exchanger is coated with a corn oil so it wouldn't get damage while sitting in their warehouse for too long.
Normally installer should have burnt it out before it gets blown into space
May 31, 2017 | Heating & Cooling
I have a riva 67 balanced flue gas fire. The duracell batterys last 2 weeks before the fire turns itself off. Fit new batterys its fine.I have replaced gas valve, control box and battery box. Wiring seems...
check all wiring carefully cause i have ran into cases where i find the smallest piece of wire rubbed through the insulation and causes random shorts
Oct 22, 2013 | Heating & Cooling
IBM Thinkpad T41 beep sound on system startup
Here are the beep codes for the Thinkpad:" Continuous beeping System board failure One beep; Unreadable, blank or flashing LCD LCD connector problem; LCD backlight inverter failure; video adapter faulty; LCD assembly faulty; System board failure; power supply failure One beep; Message "Unable to access boot source" Boot device failure; system board failure One long, two short beeps System board failure; Video adapter problem; LCD assembly failure One long, four short beeps Low battery voltage One beep every second Low battery voltage Two short beeps with error codes POST error message Two short beeps System board failure.
Dec 26, 2012 | Dell Optiplex GX620 Pentium 4 3.4GHz (Open...
While starting its get bip sound upto window will start
Bip sound contiously might caused by 1.Fan stops working 2.Sticky key on keyboard
Try cleaned those two part, specially the heatsink ( something might blocked the fan )
akee_akee@live.com
Aug 17, 2011 | Acer Aspire 5738Z-423G32Mn Notebook
Pilot light keeps going out after about 10 seconds on my Gazco Riva 67 inset fire.
Most likely it is the flame sensor thermocouple not working. Make sure the probe is right abaove the pilot flame and make sure it is clean and not covered in soot. The probe needs to sense the flame or the gas valve closes. These can be found at almost all harware suppliers and stores.
Mar 08, 2011 | Heating & Cooling
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
