Question about Konica Minolta bizhub 200 Printer
Fix pc drum - Konica Minolta bizhub 200 Printer
  • Konica Minolta Master
  • 6,161 Answers
Have a tech come clear counters,remove the image unit and replace the developer/cleaning blade & drum then run required F8.
Posted on Jan 24, 2016
How to fix the drum
Drums need to be replaced there really inst a fix if the drum is bad its bad. On larger models 50ppm+ The drums can be polished but if this was the case id assume the tech would have done so.
Mar 07, 2012 | Canon Office Equipment & Supplies
How do I change the drum in my HL-5240
First check whether it is possible to buy a new drum for your model, if possible buy a new drum then remove the toner from your printer, separate the drum unit from the toner, if you check thoroughly the left and right sides of the drum unit how the drum has been fixed in to it you will be able to find the way remove drum from the unit, then replace the new drum and fix it. Don not tough the edge wiper blade, rotate the drum and check whether it rotating smoothly in both direction.
Mar 03, 2012 | Brother HL-5240 Laser Printer
I have a message, please change the pc drum. how i can fix it?
This message means the pc drum life is over. You should call service center to replace the drum and reset the message (if you are not a technician).
Oct 05, 2011 | Konica Minolta Bizhub 362 Copier
How do I get rid of blurry streaks down center of copy? The glass is clean.
Check the drum unit, if the drum is covered with streaks replace the crg.
Check the fixing unit.
Jun 03, 2010 | Canon PC-940 Black and White Copier
We are getting spots of toner on our copies.
Vacume the interior of copier, check the drum.If there is spots on drum, change the drum.
Also check the fixing section.
May 25, 2010 | Canon PC-940 Black and White Copier
It is very hard to install heads on three of the toms. The heads are the correct size, so I'm guessing the toms are out of round? The bass drum was cracked on arrival. Can I use glue to fix it? I've been...
This seems to be your only recourse:http://www.hbdrums.com/c=tu3xe85QyTj8bUxK0MQc8kkeR/returns.cgis Try a local drum shop to find someone who might work on them for you if you can't return them.
Mar 14, 2010 | Orange HB Drums Duke Series 7 pc Lacquer...
Copies have lines about six inches apart
The transfer roller seats under the drum unit. You most likely need a new drum unit. Have you pulled the drum out and dose it have black lines on it? If so, that is where the problem is.... Or it could be coming from the fixing unit..
Nov 20, 2008 | Canon PC-940 Black and White Copier
Print error
Replacing the drum should fix this issue. The PC drum, aka, photoconductive drum, is light sensitive, if it has been exposed long enough to light, it can cause this problem.
Jun 19, 2008 | Dell 1720dn Laser Printer
Rock band
Open it up and fix up the technology under the green drum.
Apr 14, 2008 | Activision Guitar Hero II for Xbox 360...
Konica Minolta bizhub 200 Printer Logo
20 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
